Topic: WavPack 4.40 released (Read 59078 times) previous topic - next topic
WavPack 4.40 has been released. This is a list of what's new (since 4.32):
  • new hardware-friendly "high" mode compresses almost as well as old "high" mode but decodes significantly faster (works better on Rockboxed iPods)
  • old "high" mode has been renamed "very high" (-hh)
  • "extra" mode levels 1-3 completely revamped, now fast enough to be usable
  • --optimize-mono option added to improve compression of mono material in stereo files (requires at least version 4.3 decoder)
  • cuesheet extraction from command-line and during self-extraction
  • wav header generation on decode for files with missing RIFF information, or forced with -w option
  • expanded summary information including wrapper info and channel assignments
  • other improvements for more robust decoding of corrupt files
  • winamp plugin now quietly skips deleted files in playlist
  • Windows 95 no longer supported (except for self-extraction)
  • source code organized to create a standard library that should more easily integrate into other applications
  • all new documentation on library use and file format details
Many thanks to all the beta testers!
WavPack download page
thanks, david!
i packaged svn r57 for rarewares/debian yesterday.
should be a few days/weeks before the debian devs wake up
later
Thank you very much, David.
Wonderful christmas present.
lame3995o -Q1.7
opus --bitrate 140
Great news!! Thanks, David.
Reason is immortal, all else mortal
- Pythagoras
Thx a lot David!
Allegari nihil et allegatum non probare, paria sunt.
Thank you.
wavpack 4.8 -b3hx4cl
Thankyou!
daefeatures.co.uk
Fantstic! Thank you very much!
Could you share what you're going to concetrate on for the next update please?
I mean, clearly after the holidays at least  !
WavPack 5.4.0 -b384hx6cmv / qaac64 2.71 -V 100
Thank you, David! This coincides well with my plan to (eventually) re-rip my CDs using the new reference offset . . . That should be fun.
Thanks, David.  I've posted an announcement on the Rockbox forums as I believe that this will certainly be of interest to Rockbox users.
Many thanks!
Thank you sir.
we was young an' full of beans
RE: http://www.hydrogenaudio.org/forums/index....st&p=451360
The Winamp plugin is now 196 KB uncompressed, does it mean MSVCR80.DLL/VC 2005 Runtimes are no longer necessary please?
RE:  http://www.wavpack.com/wavpack_doc.html
WavPack consists of two complimentary executable programs, WavPack and WvUnpack.
I prolly mean complementary, tho they're surely complimentary too  ...
EDIT: Docs part.
Awesome release and it contains a lot of great improvements.  WavPack just keeps getting better and better.  Hopefully, a DAP company will notice and make a player with native wavpack support.
Zune 80, Tak -p4 audio library, Lossless=Choice
Thanks a lot for update, David. Excellent as always.
And also a question. Some time ago you said something about possibility to improve noise shaping in hybrid mode for lower bitrates. Do you still have such plans ?
I grabbed it and used it to encode a few CDs.  They sound great of course.
How much extra compression in lossless mode does -hh give you over the default lossless parameters on average?
http://www.hydrogenaudio.org/forums/index....mp;#entry434911
http://www.hydrogenaudio.org/forums/index....mp;#entry435146
I'm relatively new to WavPack...
Thus far it's worked flawlessly for me. I've been making lossless images of all my discs using v4.31... a few hundred of them actually. Would there be any reason to transcode to the new version? From what I understand... if I use the -hh switch instead of -h, things will be the same... is that correct?
Thanx for the prompt and succinct response.  If I'm reading the first chart correctly it looks like you only gain ~1% greater compression with -hh vs the default lossless parameter. OTOH the encode/decode times increase roughly 50% over default.
It looks like it's pretty well tuned for lossless encoding at the default settings and that's how I'll use it.
Thanx again.
Here are some of the things I am thinking about, although I could certainly end up never getting to some of them:
  • handling W64 and/or RIFF64 files to get over 4 gig WAV limit, and also updating the library to accept a 64-bit WavpackStreamReader to allow WavPack files over 4 gig (this would be done in a backward compatible way)
  • add binary APEv2 tag fields to the library and wavpack.exe (for album art embedding)
  • MMX and other possible optimizations to improve decoding and encoding speed on x86
  • smart noise-shaping in lossy mode, perhaps a simple quality-based VRB mode (based on tonality)
  • winamp plugin enhancements: specify output resolution, multichannel output (if someone can tell me how) and (maybe) tag editing
  • audition plugin enhancements: write RIFF info to APEv2 tags, write cues to embedded cuesheet
  • add option for new CRC covering raw block data (for decoding robustness & quick verify)
  • accept WavPack files as sources to wavpack.exe (with tag copying)
  • option to wvunpack to decode a specified time range (or track, if cuesheet present)
  • raw encode
and also these related things:
  • add WavPack support to SlimServer so I can finally use my SqueezeBox with my favorite format
  • repackage tiny_decoder to get out the improvements from Rockbox (including ColdFire and ARM assember code) and some TMS stuff I did for someone else
  • release a tiny_encoder that I did for someone else
  • do assembler optimization of Rockbox encoding and maybe add lossy encoding too
  • add lossy file handling and perhaps seeking support to ffmpeg (if they'll accept my patches...)
Yes, I took the dependencies out of both the winamp plugin and the audition plugin. I may try to build with MSVC 6 at some point in the future, but this is easier for now.
No, I meant that the two programs are very polite and they compliment one another all the time!
Thanks, I'll fix that...
With this release I changed the -hh mode back to be identical to the old -h mode. However, you could transcode to the new version with a -hhx which goes pretty quick and would probably give you another 0.2 percent or so (with no decode penalty). But I wouldn't bother...
Edit: added 4 items to "to do" list that I forgot.
With my test corpus I actually get about 1.5% improvement from default to -hh, so it does depend a little on the type of music (my corpus has a little of everything).
However, with this release, I would recommend using either -x or -hx. They improve the compression over the default about 0.5% (with no decode penalty) and 1.25% (with 1/2 the decode penalty of -hh), respectively. The -x about doubles the encode time, but it's still faster than most rippers.
My top goals for this release were to greatly reduce the use of -hh and greatly increase the use of -x (that's why you see what you see in the "short" help version).
BTW, thanks to everybody for the support!!
