Topic: BatchEncoder (Audio Conversion GUI) (Read 22361 times) previous topic - next topic
Re: BatchEncoder (Audio Conversion GUI)
Reply #76
I am working on tools dialog for BatchEncoder that will enable users to download command-line tools and set paths to executable's.
Here is quick demonstration of tools dialog functionality in preview builds.
https://youtu.be/UsuaYlXBaow
Any feedback is welcome.
Download preview (alpha builds): https://ci.appveyor.com/project/wieslawsoltes/batchencoder/build/artifacts
Reply #77
Best front end around, good job.
Reply #78
The latest v2.0 alpha builds have support for eac3to.
Downloads : https://ci.appveyor.com/project/wieslawsoltes/batchencoder/build/artifacts
Any comments and suggestion regarding presets or command-line parameters are welcome :)
AC3 format and presets:
<?xml version="1.0" encoding="UTF-8"?>
<Format id="EAC3TO_AC3" name="AC3 (ATSC A/52) - eac3to" template="$EXE $INFILE $OUTFILE -progressnumbers $OPTIONS" input="false" output="false" function="GetProgress_Eac3toEnc.progress" path="eac3to/eac3to.exe" success="0" type="0" formats="RAW,LPCM,PCM,WAV,W64,RF64,AC3,EAC3,DTS,DTSES,DTS9624,DTSHDHR,DTSHDMA,MLP,THD,THDAC3,FLAC,AAC" extension="AC3" default="3">
    <Presets>
        <Preset name="192 kbit/s" options="-192"/>
        <Preset name="224 kbit/s" options="-224"/>
        <Preset name="384 kbit/s" options="-384"/>
        <Preset name="448 kbit/s" options="-448"/>
        <Preset name="640 kbit/s" options="-640"/>
        <Preset name="Extract the AC3 core of a TrueHD track" options="-core"/>
    </Presets>
</Format>
DTS format and presets:
<Format id="EAC3TO_DTS" name="DTS (Coherent Acoustics codec) - eac3to" template="$EXE $INFILE $OUTFILE -progressnumbers $OPTIONS" input="false" output="false" function="GetProgress_Eac3toEnc.progress" path="eac3to/eac3to.exe" success="0" type="0" formats="RAW,LPCM,PCM,WAV,W64,RF64,AC3,EAC3,DTS,DTSES,DTS9624,DTSHDHR,DTSHDMA,MLP,THD,THDAC3,FLAC,AAC" extension="DTS" default="0">
    <Presets>
        <Preset name="768 kbit/s" options="-768"/>
        <Preset name="1536 kbit/s" options="-1536"/>
        <Preset name="Extract the DTS core of a DTS-HD track" options="-core"/>
    </Presets>
</Format>
Progress function in Lua:
function GetProgress(s)
  if string.match(s, '^Done.%s-') ~= nil then return "100";
  else return string.match(s, 'process: (%d+)%%'); end;
end
Reply #79
v2.0 is almost ready for release, looking for help to update some translations:
1. Spanish translations: https://github.com/wieslawsoltes/BatchEncoder/issues/84
2. Korean translations: https://github.com/wieslawsoltes/BatchEncoder/issues/42
Reply #80
BatchEncoder v2.0 has been released today.
Changes:
- Added configure tools dialog.
- Added dynamic layout support for dialogs.
- Added multi-selection support for presets list.
- Added multi-selection support for formats list.
- Refactored configuration file storage.
- Installed version config is stored in %appdata%\BatchEncoder path.
- Portable version config is stored in .\BatchEncoder path.
- Installed version tools are stored in %appdata%\BatchEncoder\tools path.
- Portable version tools are stored in .\BatchEncoder\tools path.
- Refactored worker threads to use lambdas.
- Refactored common code as submodules.
- Refactored xml configuration code.
- Added eac3to support.
- Updated tools to latest versions.
- Updated QAAC AAC format to use --no-optimize instead of --adts.
- Updated TinyXml-2 to version 5.0.1.
Download portable version:
BatchEncoder-2.0-Win32.zip
BatchEncoder-2.0-x64.zip
Download installer version:
BatchEncoder-2.0-Win32.exe
BatchEncoder-2.0-x64.exe
Reply #83
Got it, figured for the first one, even the second? Fair enough anyway, no big deal. Thanks again for another great front end, I still like and use foobar2000 for almost all my audio needs but many people will find BatchEncoder very useful.
Reply #84
I think yes, both links expire. No idea how to get permanent link.
Reply #86
Found SSRC here too, I think it's the official source? https://raw.githubusercontent.com/shibatch/SSRC/master/bin/ssrc.exe
And http://ftp6.nero.com/tools/NeroAACCodec-1.5.1.zip (Nero AAC Codec 1.5.1 with neroAacEnc 1.5.4)
Will test them tomorrow. Thanks for help.
Reply #87
BatchEncoder v2.1 has been released today.
Changes:
- Updated tools download urls.
BatchEncoder-2.1-Win32.zip
BatchEncoder-2.1-x64.zip
BatchEncoder-2.1-Win32.exe
BatchEncoder-2.1-x64.exe
Reply #88
BatchEncoder v2.2 has been released today.
Changes:
- Added AvsDec tool to support .avs Avisynth scripts.
- Added rewavi tool to support .avs Avisynth scripts.
- Added rewavi tool to support .avi files.
- Added .mka decoder support using ffmpeg.
- Added Japanese translation.
BatchEncoder-2.2-Win32.zip
BatchEncoder-2.2-x64.zip
BatchEncoder-2.2-Win32.exe
BatchEncoder-2.2-x64.exe
Reply #89
You should add refalac as well since it doesn't need any library.
Reply #91
Will add in the next release :)
hi
may i know how can add monkey mac.exe & winamp mp4 ?
about monkey i need only mac.exe but i have to create folders like the mp4 i can find in winamp
ps qaac doesn't work status error:progess did not reach 100% , but i have put the same files i have in foobar
and thank you so much for you beautiful program!
Reply #92
@francesco get the files from my foobar2000 package, it has all the libraries, remember though no links here.
Reply #93
Not sure what do you mean by mac.exe & winamp mp4. mac.exe is already supported.
Not sure what this should do: create folders like the mp4 i can find in winamp
Did you download qaac using Configure tools dialog? The executable is not installed when you install BatchEncoder, you have to download it and configure path if its different than default.
Reply #94
hi
i have used the program to download the free encoder , BatchEncoder downloads zip files and extract in folders
well i have tried to download from BatchEncoder monkey but it download the installation file , i have the free encoder
i have to create a folder and copy the encoder inside , but how can i know the name of the folder BatchEncoder uses for monkey encoder?
@eahm I know it
Reply #95
hi
The download location is "%appdata%\BatchEncoder" for installed version, for portable is "tools" folder located in same folder as BatchEncoder.exe.
The monkey encoder is downloaded as installer, just download it and run installer, install to default location. If you install in different location use Configure formats dialog to set mac.exe path https://github.com/wieslawsoltes/BatchEncoder#configure-formats.
Reply #96
BatchEncoder v3.0 has been released today.
Changes:
- Added refalac support.
- Added twolame support.
- Updated rewavi tool.
- Updated AvsDec tool.
- Added $OUTPATH variable to format template.
- Added additional preset options per item.
- Added support for split multi-channel WAV files.
- Using sol2 to for lua scripting.
- Fixed convert loop crushing with more than 64 threads active.
- Improved performance of remove item from the list.
- Changed script file extension to .lua for progress functions.
- Using xml extensions for configuration.
- Using auto detection of xml file type for drag and drop.
- Using Tools.xml for download url in download.ps1 script.
- Added generate-xml.ps1 PowerShell script.
- Added validate-tools.ps1 PowerShell script.
- Added update-config.ps1 PowerShell script.
BatchEncoder-3.0-Win32.zip
BatchEncoder-3.0-x64.zip
BatchEncoder-3.0-Win32.exe
BatchEncoder-3.0-x64.exe
Reply #97
BatchEncoder v3.1 has been released today.
Changes:
- Added auto select tool in configure tools dialog.
- Added validation for loaded configuration files.
- Improved configuration files loading and saving.
- Fixed $OPTIONS not being set properly.
- Fixed delete all items crash in formats dialog.
- Fixed delete all items crash in tools dialog.
BatchEncoder-3.1-Win32.zip
BatchEncoder-3.1-x64.zip
BatchEncoder-3.1-Win32.exe
BatchEncoder-3.1-x64.exe
Reply #99
Version 4.0 released.
Changes:
- Added download tools automatically.
- Added try to download tools option.
- Added toggle selected items using space key.
- Added items list search using keyboard.
- Changed output path variables.
- Added more variables for output path.
- Added relative output path support.
- Added load and save output path patterns.
- Automatically rename a file if it already exists.
- Append copy suffix for newly added tool, format or preset.
- Append copy suffix for duplicated tool, format or preset.
- Try to find x86 tool if x64 was not found on x64 platforms.
- Improved performance of loading and saving items.
- Improved performance of removing items.
- Reduced the size of an executable.
- Using virtual list for items.
- Using virtual list for presets.
- Using virtual list for formats.
- Using virtual list for tools.
- Reduced memory usage.
- Added basic logging support.
- Added tools utilities class.
- Added separate core project.
- Using std::wstring instead of CString.
- Using std::map container.
- Using std::vector container.
- Using std::thread for workers.
- Using std::mutex for syncing workers.
- Refactored worker classes.
- Added unit tests.
BatchEncoder-4.0-Win32.zip
BatchEncoder-4.0-x64.zip
BatchEncoder-4.0-Win32.exe
BatchEncoder-4.0-x64.exe
