Topic: USB Sound Card for my specific needs (Read 3709 times) previous topic - next topic
Hi, I'm currently researching for a USB external sound card that can suit my specific needs. I have a Benchmark DAC-1 that I would like to use as a D/A converter, so I need one with digital outputs.
That's the relatively easy part. Now, for the hard stuff :
Since DAC-1 is only stereo, would you suggest that I get a card that can do 5.1 DVD/Gaming surround stuff? I'm thinking of using DAC-1 for the front and using the soundcard's analog output for the others. Or maybe, I can just use the analog output and use another (cheaper) 5.1 system? I don't need pristine sound quality for gaming (most of the SFX and music in games are pretty bad to start with).
What are my options?
But which one has bit-perfect out via digital out?
Anything that does not resample i.e. that supports both 44.1 and 48kHz S/PDIF. Select a few that are in the price bracket that you want and send an email to the manufacturers.
See my post on 12/10/2006...
http://www.hydrogenaudio.org/forums/index....showtopic=50912
First, I had a heck of a time finding a card that I could do pure bit-for-bit transfer with.  Most cards just don't advertise this as you probably discovered.  I used the SoundBlaster Audigy 2 ZS PCMCIA card because I found, buried in their website, that they have a switch to set for bit-for-bit transfer and a switch for 44.1K.  However, this does not mean that is really is doing this.  For example, just putting an equalizer or even a volume control in the path screws with the bit stream.
So just in case, I de-installed their mixer/volume/equalizer control software via Windows XP's control panel (the ability to do this is buried in some XP menus).  I did this after I installed the card and you can't change anything as there are no controls for it.  Sorry to those I am about to offend: most folks don't really understand what happens inside the card and I discovered that listening is the only way to be sure.  Some folks will shoot from the hip and say that having every control set to 0 leaves the stream alone but I found this not to be always true.  I found that any manipulation of the bit stream results in a serious reduction in sound quality so it is pretty easy to tell.  I think this is so because these cards do such a lousy job of it.  To be completely honest so you know where I am coming from, I haven't tried many cards.
Anyway, check out my post on my audiophile set up.  I just finished it and am curious to get some feedback.
The fact that there are no controls in a particular control panel doesn't mean you are getting bit perfect output. The standard for exclusive output (necessary for bit-perfection) to a sound card is ASIO. Others are vista's exclusive mode (not yet supported by software), xp's kernel streming (not quite a proper interface but it works someties). But if you want to trust creative then by all means do so.
