Topic: foo_discogs (Read 820680 times) previous topic - next topic
Re: foo_discogs
Reply #2475
Hi zoomorph,
can we have the album art fetching *before* the generating of tags is processed ?
on huge releases, its takes some time and users could check the art files meanwhile.
i.e. now, on a release with about 30 artists, I have to wait about 30 seconds before I can check the fetched album art.
that would be a nice  timesafer.
anyways. just wanted to mention, that tagging is a pleasure, since you started pimpin' the fine component. I cannot imagine, what else to use, because I don't want to leave f2k "just" for tagging....
Re: foo_discogs
Reply #2476
Hello,
I'm trying to figure out if it's possible to derive all of these (when tagging bands/multi-people-entities' releases):
Group - Artist Real Name - Artist Aliases
in a discogs_foo go...
eg. for this release:
https://www.discogs.com/artist/2204038-Owiny-Sigoma-Band
I correctly get:
DISCOGS_ARTISTS_MEMBERS
Charles Owoko, Jesse Hackett, Joseph Nyamungu, Louis Hackett, Sam Lewis (2), Tom Skinner
But I would also love to see:
Elmore Judd ; Louis Slipperz;  Hello Skinny
(for the 3 of the bands' members who do have 1 or more 'Aliases' stated on their artist page)
in a discogs_foo field...
Admittedly, that might be too much spiderspaghetti-ing (as it would also need to query the separate artist pages for aliases values...), but might be this is already possible somehow ?
Churs.
c.
Re: foo_discogs
Reply #2477
hi
is there a way to download only the album art?
right click ->discosg->update album/artist is gray , can 't use it
thanks
Re: foo_discogs
Reply #2478
Hello,
I correctly get:
Churs.
c.
Based on the help file it doesn't look possible at this time.
hi
thanks
These features use standard tags for Discogs release_id and artist_id. If those tags are missing the features are disabled. You could download only the album art by writing tags + downloading art and disabling all the tags so no tags are actually written.
Re: foo_discogs
Reply #2479
hi
thank you so much
Re: foo_discogs
Reply #2480
.... query the separate artist pages for aliases values...), but might be this is already possible somehow ?
Thanks alot for double checking & getting back about it!
Guess I'll need to hand edit the info for the artists/releases which are important to me to see the other involved artists' aliases.... I know I already give up on Atom Heart/Atom TM/etc before starting... :D
c.
Parsing error
Reply #2481
Bumped into a parsing error. Couldn't see an (obvious) issue with the data at discogs.
(FATAL) Error: Error loading release 1042699: JSON Parser ExceptionError parsing release credits.
Cheers.
Re: foo_discogs
Reply #2482
When fetching album art for more than one release and it gives an error like this, ALL the fetching is stopped.
would it be possible to just continue with the remaining images in the queue, instead of canceling them all, just because one image has an error?
(FATAL) Error [release 2862947]: HTTP Error (502)(url: https://api-img.discogs.com/l-7t_nVGwshpmP-jaBRtnUufCM8=/fit-in/200x200/filters:strip_icc():format(jpeg):mode_rgb():quality(90)/discogs-images/R-2862947-1304522147.jpeg.jpg)
(FATAL) Error: HTTP Error (502)(url: https://api-img.discogs.com/l-7t_nVGwshpmP-jaBRtnUufCM8=/fit-in/200x200/filters:strip_icc():format(jpeg):mode_rgb():quality(90)/discogs-images/R-2862947-1304522147.jpeg.jpg)
[ESCAPE to close]
Re: foo_discogs
Reply #2483
 I have a problem.
I have many music files with Album tag being empty. as foo_discogs  need album tag to be correct I can't make use of discogs tagging with these files unless I can map album to title because when I manually search for title in release section of this component  when I choose Write Tag in the menu, I do get the correct release listed.
I tried to figure out how to change the configs but failed.
Any help T_T?
Re: foo_discogs
Reply #2484
Trying to get this working again on a new Windows 10 install.
In Step 1 of setting up OAuth, I get this error on the console:
(FATAL) Error: Authorization Failed (401) [Is OAuth working?](url: https://api.discogs.com/oauth/request_token )
That URL seems to open OK for me in Chrome.
Re: foo_discogs
Reply #2486
Hi everyone,
from some time, when I use Discogs tagger in foobar  (tagging > Discogs > Write tags..) I have the answer:
(FATAL) Error: Authorization Failed (401) [Is OAuth working?](url: https://api.discogs.com/database/search)
[ESCAPE to close]
I also went in configuration panel, but I did not find a solution for this...
Someone could help me with this issue? Thank you!
How do you solved this problem? The same is happening with me.
Re: foo_discogs
Reply #2487
I just started getting
(FATAL) Error: Network exceptionSecurity error (url: https://img.discogs.com/VdDqxxuVoeoESd92V22G4K4Fkyo=/fit-in/150x150/filters:strip_icc():format(jpeg):mode_rgb():quality(40)/discogs-images/R-10821224-1504867991-5988.jpeg.jpg)
when attempting to retrieve release info. I was able to bypass it by unchecking 'Show preview in release dialog' in the artwork options, but it still fails while fetching full artwork as well. Anyone else seeing this now?
Re: foo_discogs
Reply #2488
There is a setting in Advanced Preferences, under Networking, where you may whitelist img.discogs.com.
Re: foo_discogs
Reply #2489
I've the same trouble.
I tried to whitelist img.discogs.com, but doesn't work....
Re: foo_discogs
Reply #2490
Identical issue at my end, as well.
Re: foo_discogs
Reply #2491
Same problem here with Windows Vista 64bit. Whitelisting discogs.com did not help. The discogs plugin might use its own HTTP client, in which the global foobar2000 setting would be ineffective. Pasting the URL given into Firefox will display the image, and the certificate is fine, so I don't think this is a certificate problem in the first place. Also the OAuth test in the plugin configuration works fine.
Flexx
Re: foo_discogs
Reply #2492
This is the workaround in the components preferences:
Turn OFF  (at the top)
Album art
Fetch [ ]
(Of course, the preview too as stated above. everything fetching images.)
Fetching the release info still works.
Re: foo_discogs
Reply #2493
Maybe a recent system upgrade made some trouble....
Re: foo_discogs
Reply #2494
Album art
Fetch [ ]
Switching off the get-artwork option was working for me yesterday. Today it's not pulling the release info either.
Re: foo_discogs
Reply #2495
Discogs API using OAuth appears to be broken right now.
Re: foo_discogs
Reply #2496
Strange... no problems here with foo_discogs 2.13, and I've been tagging things for the last few hours.
c.
Re: foo_discogs
Reply #2497
c.
I was still on a previous version.  Haven't tested things out with 2.13 yet, but thanks for the heads up.
Re: foo_discogs
Reply #2498
Hi zoomorph, any news on this? still not working for me...  i always get the '(FATAL) Error: Network exceptionSecurity error' message.
Big fan of your plug-in btw, thank you for the effort you put on it. Cheers!
Re: foo_discogs
Reply #2499
This is a different error. Discogs seems to have fixed the API problem from last week. This error is probably related to SSL certificates.... I would suggest searching this thread as it's probably been covered before.
