Topic: foo_discogs (Read 1392129 times) previous topic - next topic
foo_discogs
Reply #625
works as usual here...
@deucalion: release 3098056 do not exist, we're at 1500000 or something.
More probably parse error are due to firewall getting in the way...some of them will eventually remove Accept-Content with gzip in HTTP headers.
foo_discogs
Reply #626
@bubbleguuum
Thanks for the quick reply!
A firewall getting in the way is rather inprobable in my case (I only do routing, no firewalls involved here... same at the ISP side), but when I tried searching for the release it worked out fine.
Oh... and I just noticed: I mistakenly copied the Catalog# and not the discogs id... I suppose that'd explain why it couldn't find anything. Sorry, my mistake.
Would it be possible to implement a little error handling that hints at what's wrong - e.g. invalid id?
(Although I admit I'm clueless as to how detailed the error message the discogs API returns is. But it'd be greatly appreciated if you included such a feature, if it's possible... thx! ^^ )
foo_discogs
Reply #627
still doesnt work for me, i disabled the firewall completely.
i'm using a router, do i need to open ports or so?
foo_discogs
Reply #631
I've tried anything allready, in 3 different computers that logged on in one router, i dont know if thats the router config or something else, its pissing me off that i cant use this great fiture.
2 weeks ago it worked fine for one day, than i wasnt home for a week and when i came back i found it that it aint work.
please help me figure out a way to use it, i would be very thankfull.
foo_discogs
Reply #632
Possible bug with v1.15, ANV processing does not work for me anymore (yes I've checked it in options).
foo_discogs
Reply #633
A couple of things that would make this already extremly useful plugin even better (for me anyway):
* Some characters seems to make some bands impossible to search for, e.g. the ! in Testbild!.
* Sometimes there's a video included in the release, wouldn't it be possible to have some sort of option to ignore this? Or at least mark it as a video in the release window.
* An option to search for album, and not just artist. For VA-albums mostly.
* I still got alot of releases where the tracknumbers are in the wrong order. I guess it's something weird with the discogs-page, but any sort of button that sorts the tracks by number would be nice (don't forget vinyl!).
foo_discogs
Reply #634
Yes please, i've been using this plug-in for a while and tagged a few hundreds of albums with it but this is the one thing i just can't figure out. And it gets very frustrating when you have a 4cd box set where -all- the tracks appear in a random oder even though they are not.
Beside that great plug-in. =)
foo_discogs
Reply #635
The random order is probably caused by foo_discogs matching tracks based on length. You can disable it in options.
foo_discogs
Reply #636
Can you add a feature to merge tracks?
Some releases have one track which is splitted in to different parts like in this one
http://www.discogs.com/release/702461
3          Starship Trooper (9:23)
(i)         Life Seeker
(ii)         Disillusion
(iii)         Würm
which will be used in you plugin for four different tracks.
foo_discogs
Reply #637
How can I set the artist art to save at *artist's name*.jpg instead of...whatever's being used now?
foo_discogs
Reply #639
Thanks for the prompt and succinct reply
foo_discogs
Reply #641
this plugin is so AWESOME, thanks a ton for putting it up!
foo_discogs
Reply #642
Not obvious I guess but still feel a bit stupid for missing that one, thanks!
foo_discogs
Reply #643
hey for some reason my foobar isnt using the artwork after discogs downloads it i see it in the folder and when it trys to upload it to foobar it tells me theres been an error and to look in the console so i do it i get this message for example
Location not parsable: "C:\Documents and Settings\HP_Administrator\My Documents\My Videos\Torrent Downloads\Green Day - Warning (2000)\album_art.jpg", reason: Unsupported file format
what settings do i have wrong? im using discogs 1.15 and foobar .9.6.3
foo_discogs
Reply #644
The message in the console is only a message from the media library autowatch feature that simply tells you that foobar2000 can't add it to the media library because it's an image and not an audio file. Try to look for other messages in the console and post here.
foo_discogs
Reply #645
Location not parsable: "C:\Documents and Settings\HP_Administrator\My Documents\My Videos\Torrent Downloads\Rise Against\this one\album_art.jpg", reason: Unsupported file format
foo_discogs: error: problem creating file 263017_1.jpg [Object not found], skipping...
any of that make any since?
foo_discogs
Reply #646
You have to set artist art directory in discogs configuration
foo_discogs
Reply #647
alright because i have no idea what im doing ill have to ask a stupid question how do i set up the directory the album art and artist art are located in the same folder as the music tracks are. for example
how would i set the directory up to find that im still getting the same console error messages.
Thanks in advance Josh
foo_discogs
Reply #648
Right click on a item -> Discogs -> Configuration...
Select "Album/artist art" tab and insert $directory_path(%path%) in Artist Art directory to tell Discogs to save artist art in the same directory of the tracks.
foo_discogs
Reply #649
alright thanks for the help but what is happening now is im not getting an error message but its also not giving me the artworki see the picture saved in the folder but no artwork on foobar and the only thing in the console is
which i know you said means that it isnt an audio file. Any ideas?
I am using a skin if that would cause any problems. This skin--
http://www.hydrogenaudio.org/forums/index....=69046&st=0
