Topic: foo_discogs (Read 1386399 times) previous topic - next topic
Re: foo_discogs
Reply #3025
Is use %MASTER_RELEASE_MAIN_RELEASE_DATE_RAW%.
Re: foo_discogs
Reply #3027
I'd like to do a search about "written by" tag inside credits from discogs, but I noticed that sometime it is written as "Written By", other times as "Written-By" etc.
So how do I catch the word "written"? I'd like to do a search both inside track credits and inside album credits.
Re: foo_discogs
Reply #3030
Just me? Can anyone reproduce or confirm?
It's working for me in the sense that I'm currently authorized. Not keen to wipe it out in case I can't re-do it, but as far as I can see it's OK?
Re: foo_discogs
Reply #3031
Just run a test with a new portable installation, authorization is working here too.
Re: foo_discogs
Reply #3033
Worked after what I think was the 30th attempt. @Da Yuyu, thanks for your help!
Re: foo_discogs
Reply #3034
Really struggling to get OAuth working now
(FATAL) Error: Authorization Failed (401) [Is OAuth working?](url: https://api.discogs.com/oauth/access_token)
[ESCAPE to close]
Sometimes it happens due wrong time on computer. My working PC is part of domain, so admin set domain time "-5 min" of current time, so Discogs said me what you quoted. After the time was fixed -  no errors from Discogs.
Re: foo_discogs
Reply #3035
Hi people.
I install the new foo_discogger.fb2k-component and i have a problem with the release window, the master didn't expand.
I tried with previous version from https://github.com/ghDaYuYu/foo_discogs/releases and the last version that expand was v2.23-mod.16.1
Every version after that has the same problem.
I'm running foobar with wine in ubuntu.
Anyone having this problem?
Re: foo_discogs
Reply #3036
looking at wine sources...
FIXME("I_CHILDRENCALLBACK not supported\n");
I couldn´t find the fixme message in my logs though.
If someone want to ask for a fix this might be the place: https://www.winehq.org/mailman/listinfo/wine-devel
I´ll get back to this if/when I find some spare time, and maybe regretfully restore the last working version to be run just under wine environment.
Re: foo_discogs
Reply #3037
Thanks @da yuyu.
Re: foo_discogs
Reply #3038
@paregistrase,
good news, nodes are now expanding also in wine.
fix will be included in the next patch, thanks for reporting!
Re: foo_discogs
Reply #3040
Another basic Wine support question: what do I need to do/prepare/install/configure in order to get the OAuth flow working? Here (Arch-based EndeavourOS under KDE 5.24, current Wine 7.4), the Authorize button fails to open a browser window. I guess I must somehow redirect that request to use the native browser, but I did not manage to make any progress.
Or can I somehow perform these steps manually?
Re: foo_discogs
Reply #3041
I never tried with KDE but in gnome (arch and ubuntu) always work for me.
Maybe you can take a look at the wine registry with wine regedit
In HKEY_CLASSES_ROOT -> http (and https) -> shell -> open -> command i have "C:\windows\system32\winebrowser.exe" -nohome
Also you can try to make a new key in HKEY_CURRENT_USER -> Software -> Wine called "WineBrowser". Under the newly created "WineBrowser" key, create a string called "Browsers" with the following value: xdg-open,firefox,konqueror. Don't worry about the browsers order in the above code. Just make sure "xdg-open" is the first one, as that will make sure that when you click a link in a Wine application, your default native Linux browser will be used to open that link.
composer and performer
Reply #3042
Any help with formatting string for composer and performer. I cant seem to get it right
Re: foo_discogs
Reply #3043
Good to know; on next install on a device, I'll try that path.
That is all set by default; also: weblinks on foobar's "Help > About" window open in my default browser just fine. Only peculiarity: links to htm(l) files, like the link "License && Credits" spawn KDE's default text editor. But that's probably due to these defaults:
[HKEY_CLASSES_ROOT/.html] ContentType = "text/html"
I tried that, but did not change anything, as expected. Winebrowser seems to be linked to xdg-open just fine, but it seem Discog's [kbd]Authorize[/kbd] opens the link through another code path where my registry does not link back to any browser, not even Wine's internal one.
Re: foo_discogs
Reply #3044
I suppose that you had tried with a new wine profile profile .
In the old times when ie8 winetrick verb was necessary i used a trick to avoid using it. Like ie8 hijack the links i used to install a old firefox version and made it default browser in the profile. With
wine ~/.wine/drive_c/Program\ Files/Mozilla\ Firefox/firefox.exe -silent -setDefaultBrowser
Maybe it can help you as a workaround
Re: foo_discogs
Reply #3045
A new version of foo_discogger is out.
It fixes a few issues running the component on Wine.
download link
Re: foo_discogs
Reply #3046
Awesome & many thanks that you are maintaining it further!!
Tested, and a few things I noticed/worth noting potentially:
 - requirements have changed, I was on foobar 1.4.6 still, and this new version now requires a newer version for foobar sdk updates.
- after updating to foobar latest 1.6.10 I get this upon startup:
foo_discogger initialization
Error loading configuration.
OK
- and immediate crash of foobar when calling foo_discogger.1_06. via shortcut.
- also crashing foobar when attempting to access foo_discogger settings to check the configuration file in the components window
So as is I'm a bit stuck with 1.06, and revert to 1.05 for the time being.
Anything I can do to test 1.06 further ?
Cheers.
c.
ps. bummer, old version foo_discogger1.05 is not compatible with foobar 1.6.10 anymore.
Let me know if you need anything else.
Re: foo_discogs
Reply #3047
download link
Working great in wine. I had to delete all configuration files to avoid an initial crash but after that all fine, including import of old discogs tag mapping
Thank you very much
Re: foo_discogs
Reply #3048
You are welcome, thank for testing!
@alec.tron,
Touch wood the installation error should be fixed now.
Please redownload v1.06, and try installing again.
If you are still stuck in the installation process try the fix suggested in the download page.
About the requirements change, it was a decision that had to be taken (mostly on the testing aspect of it) as I could not afford supporting a pre-Windows 7 sdk... surely you do have good reasons to like 1.4.x
you might have to maybe run foo_discogger in an independent portable installation?
@paragistrase
Glad is working!  :D
Re: foo_discogs
Reply #3049
@alec.tron,
Done, worked!
All good, requirement change is completely understandable, just caught me by surprise so thought I'd mention it. Also running portable anyway, and version 1.4 reason was mostly that it works, & no new features for me I noticed, so it just stuck around... :D
Cheers.
c.
