Re: foo_discogs Reply #2925 – 2020-11-27 09:18:41 Quote from: alec.tron on 2020-11-24 20:33:08Quote from: zoomorph on 2020-11-10 16:45:19That does appear to be a bug.Out of curiousity - if you can you reproduce iton your end - are there plans to fix or leave as is ?Quote from: zoomorph on 2020-11-26 05:00:29Unfortunately, I have no plans to continue working on foo_discogs at this time. If I were to do so, I'd have to migrate my development environment to Linux which I now use exclusively.Thanks for the info zoomorph - what a bummer... end of an era then, seemingly.But, a lot more thanks for all the work you have invested in this component since you took over and have carried it for years!Fingers crossed someone else with the skills required feels strongly about this and takes over from you some time - source is all here:https://bitbucket.org/zoomorph/foo_discogs/src/master/correct ?Cheers & all the bestest!c. Last Edit: 2020-11-27 09:23:01 by alec.tron
Re: foo_discogs Reply #2926 – 2020-11-28 08:27:56 Is anyone else finding that this is now incredibly slow? 10+ minutes to find results?
Re: foo_discogs Reply #2927 – 2020-12-06 13:26:57 Quote from: NateHigs on 2020-11-28 08:27:56Is anyone else finding that this is now incredibly slow? 10+ minutes to find results?Same here, been slow for the past week or so for me.Maybe Discogs are doing some rate limiting?
Re: foo_discogs Reply #2928 – 2020-12-09 06:17:50 Many thanks zoomorph (and all the people helping with tests and proposals)I hope you'll find the way to continue working with this component, maybe under Linux...Done a fine work anyway!QuoteQuote from: alec.tron on 2020-11-24 20:33:08 Quote from: zoomorph on 2020-11-10 16:45:19 That does appear to be a bug.QuoteFingers crossed someone else with the skills required feels strongly about this and takes over from you some time@alec.tron, in the meantime, if you'd like, please check:https://bitbucket.org/fooDaYuyu/foo_discogsContains sources and binary to include foo_discogs into fb2k preferences paneland a rookie attempt to solve the tag write/update bug.Best regards, (sorry for bad english)
Re: foo_discogs Reply #2929 – 2020-12-09 10:09:22 Quote from: da yuyu on 2020-12-09 06:17:50@alec.tron, in the meantime, if you'd like, please check:https://bitbucket.org/fooDaYuyu/foo_discogsContains sources and binary to include foo_discogs into fb2k preferences paneland a rookie attempt to solve the tag write/update bug.Hello @da yuyuI gave it a spin - and write+update seems to work now and spotted no other issues on a hand ful of test runs.Thanks muchly for taking on the bug fix!!!All the best.c.
Re: foo_discogs Reply #2930 – 2020-12-09 12:27:50 Quote from: da yuyu on 2020-12-09 06:17:50 ...in the meantime, if you'd like, please check:https://bitbucket.org/fooDaYuyu/foo_discogsContains sources and binary to include foo_discogs into fb2k preferences paneland a rookie attempt to solve the tag write/update bug. Thanks for this. Is there any way to watch this page for any new releases? https://bitbucket.org/fooDaYuyu/foo_discogs/downloads/. I cannot see anything like github where you can subscribe to any new releases.
Re: foo_discogs Reply #2931 – 2020-12-11 16:29:51 Quote from: alec.tron on 2020-12-09 10:09:22I gave it a spin - and write+update seems to work now and spotted no other issues on a hand ful of test runs.You are welcome, I am glad the fix is working so far!Well, I found a crash scenario, clicking on 'Write tags..." followed by closing fb2k (havingwrong OAuth settings and/or no internet connection). Did not happen on zoomorph's original v2.23.It is now fixed in the latest mod release.Quote from: stevehero on 2020-12-09 12:27:50I cannot see anything like github where you can subscribe to any new releases.Thanks for the suggestion, that could surely come quite handy...(repository is now located at GitHub: https://github.com/ghDaYuYu/foo_discogs)Although the intention was just fixing the write/update and next mod updates will surely focus on solvingglitches introduced by the mod itself.Best regards
Re: foo_discogs Reply #2932 – 2020-12-12 00:06:58 @da yuyu Thanks. Seeing as the original plugin is no longer being developed, this seems like a good alternative, thanks to @zoomorph for working on it til now.
