Topic: foo_discogs (Read 882405 times) previous topic - next topic
Re: foo_discogs
Reply #2775
If you have not edited many Discogs entries in the past, your changes will probably be held until somebody approves them, so you may not be able to do it immediately.
Discogs edits now happen immediately and anyone with a Discogs account can edit a release. If some other user disagrees with the edit, they can choose to comment, vote or revert the change. Any edits have to conform to Discogs RSG
Re: foo_discogs
Reply #2776
I've updated the page on discogs and it is working fine now.
I'll know what to do in future.
Thanks for all the help.
Re: foo_discogs
Reply #2777
Discogs edits are immediate but the Discogs API can cache older info so sometimes you have to wait a few hours for the new info to come. foo_discogs also caches info so you'd need to clear the cached releases in the component settings (or restart foobar2000).
Re: foo_discogs
Reply #2778
Hi zoomorph,
First, thank you for continuing the development of that Foobar plugin, it probably is the best option to get the most metadata from Discogs nowadays.
I do vinyl restoration regularly and I was thinking about writing matrix / runout infos in audio files, I'm guessing it's not implemented in the plugin at the moment? I tested the "barcode" field for CDs and this works great though.
Seems like the field for vinyl is called "Matrix / Runout" in the Discogs API.
Correct, it's currently not available in foo_discogs. There can be multiple Matrix / Runout variants for a single release. Not sure how this should be handled.
Late reply on my end.
If there are matrix variants for a single release, I seem to recall each should be separated in its own release page. I don't think I've seen one release page with multiple matrix variants, but I could be wrong.
Re: foo_discogs
Reply #2779
See: https://support.discogs.com/hc/en-us/articles/360005054893-Database-Guidelines-5-Barcodes-Identifiers
One edition of a release may have many different matrix numbers on individual copies - especially for major label releases. These are considered manufacturing variations for the purposes of cataloguing on Discogs, and not unique releases, so one Discogs 'release' may contain multiple variations in matrix numbers etc. For smaller releases, or in special cases, the matrix variation may indicate a unique release / edition, so please ask in the Database Forum Topic if in doubt.
Re: foo_discogs
Reply #2780
Oh, very late reply, sorry!
@kode54
I'm on Win7 64Bit. (Both the VMs and my working computer).
Don't trust my User Agents as I use a lot of different browsers with a lot of different addons which -some of the time- will fake the User Agent/the OS.
If there ever is something special you or anybody else, that needs to be tested, you always can ask and I'll try to brute test it...
@fuffi It may also depend on which OS you're running foobar2000 on. I can't guess what you're running from your user agent, because that's kind of prying, and the two user agents I have seen from you don't agree completely.
Windows virtual machine? Which Windows? It may be a case of legacy Windows versions not being tested properly, if you're using the long out of support XP. It almost makes me wonder why Peter and I continue to build with the XP supporting toolchains, when at least I don't actually bother to do any testing to see if anything actually blows up there, and I don't know what Peter does for old OS testing, other than maybe doing some targeted testing when someone points out a bug.
@zoomorph
I know, that I'm out of the ordinary, when using your fine component. Most of the time (90% of 100%) if works very well and it is so damn useful, I couldnt live w/o it!
The other 10%, well, I'm trying to reproduce it as best and precice as I can, so others might reproduce it as well and we might track the cause down and maybe fix/improve the component. If not, well, 90% are being top when using a software nowadays! :-)
About the "not always returning country":
I pers. think, its not a problem with the API, but with your caching routine.
You can clearly see the country is shown at first, and after some clicking (no reloads from the API, just fooling around with some buttons in the component) the country vanishes.
Seems to me, that the concatenation of the used strings to be shown in the list of releases has a bug, when using cached information.
I also miss the useful info like CD, 2xCD, 3xCD,... in the list of releases. They appeared some months/years ago and suddenly vanished completely. (I'm not sure, if its a new boundary of the API, but it was very useful to filter all non-LP releases)
Thank you for testing. Strange....I don't know if something changed on the discogs side, because their API give and gave the correct result.
I just wasn't shown in the releases tab of the fine component.
I guess its the same strange phenomen in the component like here: https://hydrogenaud.io/index.php?topic=50523.msg967983#msg967983 (you clearly see it in the animated gif)
The component swallows some information retrieved from the cache under some unclear circumstances :-)
If it worked the first time, then it should continue to display the same result while the info is in the foo_discogs cache (unless there's a bug in foo_discogs). Not working 5 hours later suggests to me that some or all of the info was probably kicked out of the foo_discogs cache by then and so it was reloaded from the Discogs API. The Discogs API could have returned something different at that point, or there could be a bug in foo_discogs (ie. maybe something goes wrong if part of the data is cached while another part is reloaded).
It's always hard to investigate a bug that can't be reliably reproduced. This seems to happen rarely so perhaps it's not worth putting much effort into. I played around a little with a small cache size in foo_discogs, but wasn't able to trigger it.
As for that other one about the country being displayed in the find release dialog, I suspect that one is probably related to the Discogs API search endpoint sometimes returning country and sometimes not (at least that's how it used to be). The release endpoint, which is loaded after you press "Next>>", always returns country. So when the results are repopulated when you go back and change the filter, the new information is reflected there.
Re: foo_discogs
Reply #2782
Not sure if dev wants individual releases that cause errors, but here's one:
https://www.discogs.com/Sonny-Rollins-The-Freelance-Years-The-Complete-Riverside-Contemporary-Recordings/release/5315647
That would be an:
(FATAL) Error: Error loading release 5315647: JSON Parser ExceptionError parsing release credits.
[ESCAPE to close]
error.
I guess, this is (on of the) the problematic part (taken from the credits part of the link you posted):
Thelonious Monk (tracks: 1-1 to 1-)
(The  "to 1-" which indicates, a  missing tracknumber)
Unfortunately, the fine component cannot do anything about it (otherwise it would lead to false tagging of your files), so you have to correct the release on the discogs site/db yourself or kindly ask in the discogs forum anyone to do it.
Next time, please show us the error message too (not only the link to the release), so it is easier for us to guess the problem :-D
Re: foo_discogs
Reply #2783
(f2k 1.5, but earlier version too and component Version: 2.20, Compiled: Aug  7 2019, but earlier versions too)
Today I'd like to show a screenshot of a greyed-out NEXT button. :-)
I had this from time to time (and when this is comming, its time to restart f2k, otherwise the finde component will cause a crash the next couple of invocations), but closing the Find Release window (via Cancel) and start the component again will help to reappear that NEXT button. So its not critical (the crash is, but its not reproducable. I guess, the more I have used the compoent = big cache and other stored things in RAM...)
The NEXT button is never greyed-out from the beginning (aka start of the fine component), I have to go to the Match Tracks windows and go back a few times and and check other releases too.
So its not really reproducable ...
Just wanted it to mention, maybe others can better reproduce or I'll find a way the next years :-)
Beside the (from time to time) crashes, I'm very thankful for such a usefull, solid and reliable helper here in foobar2000!!
Re: foo_discogs
Reply #2785
why track 2 & 4 would cause foo_discogs to spew out:
"(FATAL) Error: Error generating tag DISCOGS_ARTISTS_ALIASES [] for file file://D:\* *\02-Kraut feat. Bachan-Lentamente.flac
Interesting...
My error is not in ALBUM ALIASES, but in ALBUM ARTISTS:
(FATAL) Error: Error generating tag ALBUM ARTIST [] for file file://E:\test\test.mp3
[ESCAPE to close]
Here is my code:
$multi_if($multi_and($any($contains($first(%<<RELEASE_FORMATS_DESCRIPTIONS>>%),$array(Compilation,Mixed))),$multi_greater($length($unique($flatten(%<<RELEASE_TRACKS_ARTISTS_NAME>>%))),$div(%RELEASE_TOTAL_TRACKS%,2)),$multi_greater($length($unique($flatten(%<<RELEASE_TRACKS_ARTISTS_REAL_NAME>>%))),$div(%RELEASE_TOTAL_TRACKS%,2))),Various Artists,$joinnames($multi_replace(%<RELEASE_ARTISTS_NAME>%,'Various','Various Artists'),%<RELEASE_ARTISTS_JOIN>%))
Lets compare it with your code, maybe we find the culprit...
but i guess, its the empty VARIOUS .... https://www.discogs.com/artist/194-Various
Re: foo_discogs
Reply #2786
Hai.
Does anyone see anything on here:
https://www.discogs.com/Various-Confluencias-I-Selva/release/11123050
"(FATAL) Error: Error generating tag DISCOGS_ARTISTS_ALIASES [] for file file://D:\* *\02-Kraut feat. Bachan-Lentamente.flac"
If you click through on Bachan (2) and Yeahman!, both artists give 404 pages.
I've seen this happen now and again lately - I'm not sure how it would happen, because surely when they're listed on a release they would get an artist page of some sort, even if they have no releases other than appearing on this compilation?
Could be worth posting in the Discogs forums about them?
Re: foo_discogs
Reply #2787
Good catch, thanks!
Will flag this on the forums and see what comes out of it.
Churs.
c.
question about %RELEASE_SEARCH_FORMATS%
Reply #2788
question about %RELEASE_SEARCH_FORMATS%,
used in
Find Release Window
configured via
Configuration->Searching Tab->Master Sub-release formatting string
short:
The formattingstrings output now shows:
"Raging Beauty, Stereo, Creative Tapes, none, Germany, 1984"
And I'd like to have
"Raging Beauty, Cassette, Stereo, Creative Tapes, none, Germany, 1984"
Is this possible?
long:
The "formats" shown in the json from this release https://api.discogs.com/releases/1285086
are "Stereo", C40, chrome" and "cassette",
but the fine component's default string only shows "Stereo".
So I'd like to change the formatting string, but cannot figue out, how to get the "cassette" string from the array.
My attemps with $join() or $zip() did not change anything...
Anyone an Idea?
Re: foo_discogs
Reply #2789
used in
Find Release Window
configured via
Good question. The %RELEASE_SEARCH_FORMATS% field comes from this API endpoint, since it's a master release:
https://api.discogs.com/masters/164846/versions
foo_discogs currently uses the "format" field. It looks like "Cassette" is not in there, but it's below in a "major_formats" field. I'm not sure if it was always this way or if they changed it.
For releases that aren't part of a master release, %RELEASE_SEARCH_FORMATS% comes from the artists/<id>/releases API endpoint. That endpoint still returns "Cassette" in the "format" field, there is no "major_formats" field.
foo_discogs would need to be changed to better support this.
Re: foo_discogs
Reply #2790
Thanks for the reply/explanation!
So I cross my fingers, that some night, you wake up from an enlighten dream and know what to code :-D
Re: foo_discogs
Reply #2791
Hi guys, been using foo2k for years now with discogs tagger along to it. Recenty I formatted my PC, and installed foo2k with discogs but when i try to update the tags on files it always says access denied. I have tried every obvious solution I found on the webs but I cant make it work. Any luck here?
Re: foo_discogs
Reply #2792
Sup y'all? I just jumped in here real quick to let you know that everything was working fine until the last 20 mins or so. I've been tagging for the past few days, using it until literally just now when the Discogs site said it was down shortly for maintenance. Sure enough, it came back online shortly after, but since then, the plugin no longer works.
It's not the first time Discogs have changed something to which you (bubblegumm and other rockstars like you) have to patch, but this is the first time I've personally seen it occur while I'm actually using it so maybe I'm just one of the first to notice this time.
I could be wrong; It could be something my end and if so I'll come back and say. But literally nothing's changed except Discogs shut down for a little while and now I'm getting exception errors.
(FATAL) Error: Network exceptionSecurity error (url: https://api.discogs.com/database/search)
[ESCAPE to close]
Re: foo_discogs
Reply #2793
The same here!
Re: foo_discogs
Reply #2794
[ESCAPE to close]
Same. It's something on their side that they've done. Maybe they messed up their TLS. I'd give it a couple days as I know yadg works still.
Re: foo_discogs
Reply #2795
Yes, lets wait some days, meanwhile, thats the errornumber I get:
[10:25:34] foo_discogs: Networking Error: Network authentication error (80090326) - Retrying: 1
[10:25:37] foo_discogs: Networking Error: Network authentication error (80090326) - Retrying: 2
[10:25:39] foo_discogs: Networking Error: Network authentication error (80090326) - Retrying: 3
[10:25:41] foo_discogs: Networking Error: Network authentication error (80090326) - Retrying: 4
[10:25:44] foo_discogs: Networking Error: Network authentication error (80090326) - Retrying: 5
Re: foo_discogs
Reply #2796
Meh. FWIW, I just updated foobar from 1.3 to 1.5 and foo_discogs from 2.14 to 2.20 but no change. Also did a Win7 update to enable TLS 1.1 and 1.2 (this has been an issue for some users in the past) but that did nothing either.
I get that these things happen and I might just have to wait it out but I'm so pushed for time I'm desperate to get this working again. For now, I'll keep trying. lol
Re: foo_discogs
Reply #2797
So. I've just installed foobar on another (Win 10) machine and run a test and it's all working so I'm gonna pack up and move over to that station. I'd still like to resolve this, seemingly Win 7 issue on this machine, but at least I can continue for now.
I'll come back to this thread but before I go, I just wanted to say that I've tried, tested and learned a few things since this first happened...
1. I mentioned bubbleguuum earlier because that's who I remember set this up initially, but I also wanna shout out zoomorph and anyone else who contributes to this free tool and others like it. And big up fuffi as well. You seem like you're very active and quick to help others on here. Thanks.
2. I followed all the steps to enable the TRS 1.2, but that doesn't seem to have worked. I did it from the official windows update file (http://www.catalog.update.microsoft.com/search.aspx?q=kb3140245) as well as manually and with another tool that was recommended. None of them worked.
3. it's not the system clock (fixed the issue for others).
4. It's not because I had my artwork set to fetch automatically 9fixed the issue for others).
The fact I literally watched it 'break' right after a Discogs maintenance update and the fact others are having the issue leads me to think it's something that got broken as opposed to something I broke. Not sure I can do any more except to tell you I'm running Win7 SP1 on a Bootcamped Macbook Pro. Same on the other machine except it's a Bootcamped iMac running Win10.
Anyway, i hope it gets resolved soon and thanks to everyone for all your efforts. This little 'event' reminded me just how vulnerable my system is as it relies on several key components to work and I have no alternative or backup if things go wrong. I've been doing it like this a long time and it just works. But because of that, I think I've become complacent as to how and why it works and it's reminded me how much I appreciate all that goes on behind the scenes.
This plugin is one of the best things on the Internet. And has been for many years. Thank you to all who keep it evolving.
Re: foo_discogs
Reply #2798
Thanks for summarizing all the possible flixes to get this fine component back to work, which are loose mixed in a lot of different posts here.
definately!
I second that!
Re: foo_discogs
Reply #2799
Yeah, changing to a different OS just because discogs wants to be in cahoots with unnecessary TLS certs, or even microsoft for that matter (if it's the case) is stupendously ridiculous - and something I could see discogs staff doing as they're known assholes. I like this plugin, but there are fine alternatives if discogs just up and decided to give us the middle finger.
Also, the TLS registry change to 1.2  you were referring to is as follows (in a .reg file):
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\Client]
"DisabledByDefault"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client]
