Topic: REACT 2 Released (Read 1290153 times) previous topic - next topic
REACT 2 Released
Reply #1125
I haven't actually switched to the new XUI version yet (for REACT) since it has such a slow startup time. I wonder if that's improved with the new release?
I have only used once so far seems a little faster.
In my pc it's really slow to start and it uses over 300Mb of memory when only using my own image directory with under 50 images as a source. I tested a directory with only 1 picture and the damn program takes about 50Mb of RAM. It's horrible but I hope it gets better. Knowing that it's build with .NET technology.. and requires .NET Framework 3.5, it's never going to happen.
About the bug I mentioned, it only happens when using II.%extension% string in path switch & the path contains at least one subdir & the localImagesPath directory contains either .png or .bmp file!!    Talk about special situation when a bug occurs.
also, the new accuraterip version... Isn't AR 'built in' to EAC now? do we even have the option of replacing or upgrading this component ourselves?
All I did is replace the AccurateRip.dll that's in the EAC folder and it's working fine
NO NEED! It's the same version. Just compare file sizes and file versions... it's the same. EAC author just publishes IMHO crap changelogs.. some authors do that, others don't... I like the style of others.
REACT 2 Released
Reply #1126
They looked the same, but changed it to be on the safe side.
In my pc it's really slow to start and it uses over 300Mb of memory when only using my own image directory with under 50 images as a source. I tested a directory with only 1 picture and the damn program takes about 50Mb of RAM. It's horrible but I hope it gets better. Knowing that it's build with .NET technology.. and requires .NET Framework 3.5, it's never going to happen. sad.gif
About the bug I mentioned, it only happens when using II.%extension% string in path switch & the path contains at least one subdir & the localImagesPath directory contains either .png or .bmp file!! rolleyes.gif Talk about special situation when a bug occurs.
It does use up a lot of resources
For me the only issue I have is that doesn't close correctly sometimes after I save the album art. The window closes, but the program still shows up in the task manager. So on the next rip it doesn't start up, this is annoying. I have to keep an eye  too make it opens after I hit F10. Or check before I start a new rip, but I forget sometimes  When doesn't open right away, that's a sign that I need to check the task manager. End the process manually and open it manually. It doesn't have often thankfully.
Has anybody else had this issue?
BTW it happened with newest version
REACT 2 Released
Reply #1127
I am currently visting my parents house and trying to see if their drives will read the hidden track at the begging of my QOTSA - Songs For The Deaf.  Whatever I do I cannot rip tracks or images properly.
The first problem is it keeps showing me EAC dialogs asking me where I want to save the .cue file and suggesting the root rather than the rip location setup by outroot etc.  It also wants to save the artwork in the root, and also it sometimes asks for a folder "Save Wafeform" and in the edit box it says external compressor.  Finally it keeps saying it cannot find the cue file.  If I try the filespec show in the .cfg files in a DOS box "@albumfile@.
  • .cue" DOS cannot find it, so trying dir "c:\Songs For The Deaf.
  • .cue" or even "c:\Songs For The Deaf.*.cue" does not find it despite it being there as "c:\Songs For The Deaf.cue".  If I do a normal dir command with the exact name it of course can see it fine.
    This is the first time this PC has had EAC and React2 on it.  I installed React2 and configured it before overwritting with the ssb16o mod.
    I have never had to interact with react once f4 or f10 have been selected.
REACT 2 Released
Reply #1128
Do your parents use Vista?
This may be a combination of issues with Vista, React and EAC. For now, try running EAC as admin.
REACT 2 Released
Reply #1129
No its XP Home
REACT 2 Released
Reply #1130
No its XP Home
Well there goes my theory.
Unfortunately, you seem to have run into one of the bigger persisting bugs that I just don't seem to be able to fix. In the meantime, try pressing ctrl+f2 to re-set REACT settings, and try again. Try pressing F9 and going to the directories tab and make sure that "use this directory: ..." is chosen and is set to a real directory that is writeable to you as a user.
Beyond this, I am not sure what causes this error, though I suspect it might be something to do with EAC. In theory, REACT forces EAC to save a cuesheet to a certain directory, but for some reason, sometimes EAC asks anyway-- I haven't found out yet if this is due to a failure on REACT's part to change the proper settings, or if this is an EAC bug that we need to work with.
Akkurat or Synthetic Soul may have additional information for you. Until then: Sorry! The super bowl is on. Have some greasy american food and kick off the sunday shoes.
REACT 2 Released
Reply #1131
EDIT: Side note, can somebody help ChuckW? I don't know about ALC, AAC, etc.
Oh, sorry ChuckW. This thread is a big mess and I frequently miss posts.
I am not sure if iTunesEncode.exe has the ability to support ALAC...
According to the iTunesEncode program:
-e EncoderName  Lets you specify the encoder iTunes will use.
                  Choose from "AAC Encoder", "WAV Encoder",
                  "MP3 Encoder", "AIFF Encoder",
                  or "Lossless Encoder".
                  (Default is "AAC Encoder".)
So try changing the -e "AAC Encoder" portion of the command line in tracks.cfg or images.cfg to -e "Lossless Encoder".
You should also probably change the references to .m4a to .alac (is it alac?)
Thanks Nago, a little bit of playing and I think I have it mostly working.  Appreciate your help.
REACT 2 Released
Reply #1132
Managed to fix the asking aspect by going to the directories tab and make sure that "use this directory:", remembered that yesterday from earlier in the thread, but I still have the cue sheet deletion failure.
There is also another problem, one of the flac stages cannot find the file as it is looking in the wrong directory.  It seems to be looking at the directory I put in the "use this directory" section, wheras I can see the file inside the flac-images folder relative to that location, strangely the aac tracks still get generated
C:\PROGRA~1\CDEX_1~1\REACT2\tools\flac.exe -5 -f    -T "artist=Queens Of The Stone Age" -T album="Songs For The Deaf" -T totaltracks="16" -T date="2002" -T genre="Psychedelic Rock" -T comment="Created with EAC/REACT2, 2008-02-04" -T encoded-by="William" -T encoding="Flac 1.1.3 -5 -f" --tag-from-file="cuesheet=C:\Documents and Settings\Andrew\My Documents\My Music\Peter's Rips\Queens Of The Stone Age - [2002]Songs For The Deaf.cue" --tag-from-file="eaclog=C:\Documents and Settings\Andrew\My Documents\My Music\Peter's Rips\Queens Of The Stone Age - [2002] Songs For The Deaf.log" "C:\Documents and Settings\Andrew\My Documents\My Music\Peter's Rips\Qtmp54266.wav" -o "C:\Documents and Settings\Andrew\My Documents\My Music\Peter's Rips\Queens Of The Stone Age - [2002] Songs For The Deaf.flac"
Unfortunately I live in the UK and so there is no greasy american food to be found.  Have a great Super Bowl!
REACT 2 Released
Reply #1133
Hacked the .cfg files yesterday and seem to be getting nearer to propper extraction, so have managed to get a flac image with cue sheet.  Well the drive that had accurate ability was the DVD drive, but that failed to read the hidden track which had just silence, but the CDRW which did not have accurate ability has extracted sound.
Is anyone any good at modifying cue sheets to get at the hidden tracks because my attemp does not produce the right result.
Original Cue Sheet
REM DISCNUMBER 1
REM TOTALDISCS 1
REM GENRE "Psychedelic Rock"
REM DATE 2002
REM DISCID F20F6510
REM COMMENT "ExactAudioCopy v0.99pb4"
CATALOG 0000694934352
PERFORMER "Queens Of The Stone Age"
TITLE "Songs For The Deaf"
FILE "Queens Of The Stone Age - [2002] Songs For The Deaf.flac" WAVE
  TRACK 01 AUDIO
    TITLE "You Think I Ain't Worth A Dollar, But I Feel Like A Millionaire"
    ISRC USIR10211295
    INDEX 00 00:00:00
    INDEX 01 01:32:61
  TRACK 02 AUDIO
    TITLE "No One Knows"
    ISRC USIR10211291
    INDEX 01 04:45:23
  TRACK 03 AUDIO
    TITLE "First It Giveth"
    ISRC USIR10211285
    INDEX 01 09:24:04
  TRACK 04 AUDIO
    TITLE "A Song For The Dead"
    ISRC USIR10211293
    INDEX 01 12:42:33
  TRACK 05 AUDIO
    TITLE "The Sky Is Fallin'"
    ISRC USIR10211296
    INDEX 01 18:34:67
  TRACK 06 AUDIO
    TITLE "Six Shooter"
    ISRC USIR10211292
    INDEX 01 24:50:50
  TRACK 07 AUDIO
    TITLE "Hangin' Tree"
    ISRC USIR10211288
    INDEX 01 26:10:07
  TRACK 08 AUDIO
    TITLE "Go With The Flow"
    ISRC USIR10211290
    INDEX 01 29:16:26
  TRACK 09 AUDIO
    TITLE "Gonna Leave You"
    ISRC USIR10211287
    INDEX 01 32:23:37
  TRACK 10 AUDIO
    TITLE "Do It Again"
    ISRC USIR10211284
    INDEX 01 35:13:52
  TRACK 11 AUDIO
    TITLE "God Is In The Radio"
    ISRC USIR10211286
    INDEX 00 39:17:72
    INDEX 01 39:18:43
  TRACK 12 AUDIO
    TITLE "Another Love Song"
    ISRC USIR10211283
    INDEX 01 45:23:36
  TRACK 13 AUDIO
    TITLE "A Song For The Deaf"
    ISRC USIR10211294
    INDEX 01 48:39:50
  TRACK 14 AUDIO
    TITLE "Mosquito Song"
    ISRC USIR10211289
    INDEX 00 54:52:12
    INDEX 01 55:22:11
  TRACK 15 AUDIO
    TITLE "The Lost Art Of Keeping A Secret"
    ISRC USIR10211358
    INDEX 01 61:00:07
  TRACK 16 AUDIO
    TITLE "Everybody's Gonna Be Happy"
    ISRC USIR10211380
    INDEX 00 64:37:34
    INDEX 01 64:38:07
My stab at it
REM DISCNUMBER 1
REM TOTALDISCS 1
REM DATE 2002
REM DISCID F20F6510
  TRACK 01 AUDIO
    TITLE "PreHidden Track"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    ISRC USIR10211295
    INDEX 00 00:00:00
    INDEX 01 01:32:61
  TRACK 03 AUDIO
    ISRC USIR10211291
    INDEX 01 04:45:23
  TRACK 04 AUDIO
    ISRC USIR10211285
    INDEX 01 09:24:04
  TRACK 05 AUDIO
    ISRC USIR10211293
    INDEX 01 12:42:33
  TRACK 06 AUDIO
    ISRC USIR10211296
    INDEX 01 18:34:67
  TRACK 07 AUDIO
    TITLE "Six Shooter"
    ISRC USIR10211292
    INDEX 01 24:50:50
  TRACK 08 AUDIO
    ISRC USIR10211288
    INDEX 01 26:10:07
  TRACK 09 AUDIO
    ISRC USIR10211290
    INDEX 01 29:16:26
  TRACK 10 AUDIO
    ISRC USIR10211287
    INDEX 01 32:23:37
  TRACK 11 AUDIO
    TITLE "Do It Again"
    ISRC USIR10211284
    INDEX 01 35:13:52
  TRACK 12 AUDIO
    ISRC USIR10211286
    INDEX 00 39:17:72
  TRACK 13 AUDIO
    TITLE "Hidden Track 1"
    INDEX 01 39:18:43
  TRACK 13 AUDIO
    ISRC USIR10211283
    INDEX 01 45:23:36
  TRACK 14 AUDIO
    ISRC USIR10211294
    INDEX 01 48:39:50
  TRACK 15 AUDIO
    ISRC USIR10211289
    INDEX 00 54:52:12
  TRACK 16 AUDIO
    TITLE "Hidden Track 2"
    INDEX 01 55:22:11
  TRACK 18 AUDIO
    ISRC USIR10211358
    INDEX 01 61:00:07
  TRACK 19 AUDIO
    ISRC USIR10211380
    INDEX 00 64:37:34
  TRACK 20 AUDIO
    TITLE "Hidden Track 3 (Last)"
    INDEX 01 64:38:07
REACT 2 Released
Reply #1134
Remove the line:
INDEX 00 00:00:00
Edit: and leave the rest alone - except for bumping up the track numbers.  INDEX 00 entries are fine elsewhere in the cuesheet - leave them as INDEX 00 indices and don't make unnecessary extra tracks.  You should have a cuesheet with 17 tracks, not 20.
(and please use CODEBOX)
I'm on a horse.
REACT 2 Released
Reply #1135
Remove the line:
INDEX 00 00:00:00
I am a little bit confused, why are there other tracks with two sets of indicies?  On Wikipedia it says:
"A Song for the Deaf" (Homme, Lanegan, Oliveri) – 6:42
Contains an incomplete version of "Feel Good Hit of the Summer", that features all of the lyrics replaced with rhythmic laughing, toward the end of the track, after about 30 seconds of silence.
"Mosquito Song" (Homme, Oliveri) – 5:37
Mentioned on the track listing, but labelled as a hidden track. The first 30 seconds of this track are silent
So there should be another hidden track other than the one in the lead in.
REACT 2 Released
Reply #1136
I have a ton of .wav files organized by structured directories that I'd like to process.  Does anyone have a good example of a batch script to start at a top level directory and work down to the wav files to generate the tags?
Chuck
REACT 2 Released
Reply #1137
I'm really lost.. what do you want to do? And is this somehow related to REACT? The previous cuefile conversation was Off Topic, so let's not start a new OT discussion. Thanks... and sorry for bitching.
REACT 2 Released
Reply #1138
Sorry for the confusion. (Also, sorry for the delay--I've been out of town).
Let me give some more details. I had a hard drive meltdown and lost a lot of files.  In some cases I only have MP3s, in which case I have to go back to the original CD to get anything lossless.  I also have EAC generated wav files that I'd like to use to create lossless and MP3 files.  I see that you can use REACT in a command line fashion, so the idea would be to read the directory structure to determine genre, artist, and album, and use the file name to determine track#, total tracks, and name.  Pass that info to REACT and have it create the MP3 and ALC files.  I haven't done batch programming in too many years, but I'm pretty sure there's a not too difficult way of recursing directories, setting up the info and passing it off to react.
I thought I read somewhere (but now, can't find) that someone had done something like this.  If not, I'll either brute force it or learn a scripting language...
REACT 2 Released
Reply #1139
I can't seem to find definitions for the REACT command line parameters that EAC provides.  This is my best guess so far.
REACT %o %s %d "%a" "%g" "%t" "%n" "%x" "%y" "%m" "%e" "%f" "%b" %r
%o    -
%s   -  wav file name
%d     -  output file name
"%a"     -  CD or Track Artist
"%g"     -  Album
"%t"     -  Track Title
"%n"     -  Track Number
"%x"     -
"%y"     -  Release Year
"%m"     -  Genre
"%e"     -
"%f"     -  FreedbID
"%b"     -  Freedb Genre
%r    -  Artwork file name
Thought this would be in a wiki or  ?? ? but haven't been able to find
REACT 2 Released
Reply #1140
    %s        Source filename
    %d        Destination filename
    %h...%h   Text "..." only when "High quality" selected
    %l...%l   Text "..." only when "Low quality" selected
    %c...%c   Text "..." only when "CRC checksum" selected
    %r        Bitrate ("32".."320")
    %a        CD artist
    %g        CD title
    %t        Track title
    %y        Year
    %n        Track number
    %m        MP3 music genre
    %o        Original filename (without temporary renaming)
    %e        Comment (as selected in EAC)
%x is the total number of tracks, although this includes data tracks if any are present. %b is the CRC.
I'm on a horse.
REACT 2 Released
Reply #1141
First of all, a big thanks to all of you who are working on this excellent tool.
Can someone please explain to me how to set the latest mod of REACT to embed EAC cue sheet and log file? What I want is a single FLAC image file per CD with cue sheet and log embedded into it, but I really don't know how to set this.
P.S. I tried searching the forums, but I couldn't find a straight answer to this.
REACT 2 Released
Reply #1142
@ Chuck:
It might just be easier to have Foobar2000 go through, convert your WAVs, and then have it tag based on directory structure. I don't know how FB2K behaves when you tell it to guess tags from filename [directory structure] on a bunch of WAV files.
@ terhardp:
It automatically embeds the CUE and log when using image mode.
If you look in the REACT-Image.CFG, you will find this code
@tools@\flac.exe @Opt_Flac@ %RG_Flac% %Cover_tag% -T "%ArtistField%=@cdartist@" -T album="@album@" -T totaltracks="@numtracks@" -T date="@year@" -T genre="@genre@" -T comment="@comment@" -T encoding="Flac @Ver_Flac@ @Opt_Flac@" --tag-from-file="cuesheet=@cuesheet@" --tag-from-file="eaclog=@eaclog@" "@source@" -o "@image@"
you see @eaclog@ and @cuesheet@, they are automatically embedded.
OP can't edit initial post when a solution is determined  :'-(
REACT 2 Released
Reply #1143
@ SamHain86:
Thank you again for your help! My apologies - I didn't realize that .cue and .log are embedded automatically when ripping to CD image. When I tried to rip my first CD using EAC/REACT, it created an image file + cue sheet, but I didn't tried it in foobar, so I thought that cue and log wasn't embeded.
REACT 2 Released
Reply #1144
Synthetic Soul:  I finally found that listing some time after my post--thanks for verifying.
SamHain86: I'm not at all familiar with foobar, so I'd probably end up fumbling with that endlessly.
I did a recursive directory listing and have been using tools that I am familiar with--MS Word and Excel--to generate a file with the various tags for each wav.  My plan is to next generate a bat file with one REACT command line call per wav, something like:
REACT "01 - The Package.wav"  "F:\MUSIC - WAV\Rock\A Perfect Circle\01 - The Package.wav" "Temp" "A Perfect Circle" "Thirteenth Step" "The Package" "1" "12" "0" "Rock"
A few more questions:
1) why aren't the file names in quotes in the EAC call of REACT? I would assume any spaces screw things up
2) How does REACT know not to repeatedly call AlbumArt.exe for successive tracks in the same album?
3) Should Year be 0 or blank if I don't know the year?
4) I assume I can ignore the last three or four parameters (e f b and r) since I don't use them?
REACT 2 Released
Reply #1145
  • EAC will always pass the file paths in quotes - so %s is "<source path>".
  • REACT calls AlbumArt.exe before the extraction process actually begins.
  • Blank, I think.
  • I would be tempted to pass valid values, otherwise you may confuse REACT.  Try it and see though - blank values ("") for all may very well be fine.
I'm on a horse.
REACT 2 Released
Reply #1146
What you're thinking is not going to happen. AlbumArt.exe can't be started if you're using the "REACT command line call".
How many albums do you have in wav's? If there's not so many, I suggest that you rip them again with REACT.. me personally I wouldn't try to do what you're trying. Anyways, can you be sure that the wav files are ok since your hd "melted down"? Also you can't have the EAC log & cuefile(s) with this method you're trying.. if you care about those.
REACT 2 Released
Reply #1147
I have added a WIKI guide REACT:Backup DATA Track for, surprise surprise, backing up DATA tracks. I hope it's understandable guide.
Also I managed finally to customize my REACT. Yes! I have ripped about 40 cd's so far and it's working like a charm.. and FAST. Still I check every rip.. I must be paranoid.    I guess that it's the result of a long bughunt. THANK YOU all who have helped.
REACT 2 Released
Reply #1148
So when can we expect the movie to come out?
By movie I mean the super deluxe bug free version of v2. And yes, I dream of when REACT3 comes out or comes integrated with EAC.
REACT 2 Released
Reply #1149
REACT: a new MOD rising. An epic tale of human endurance, perseverance and heartbreaking love story with thrilling action across the planet as we know it.. today. Starring Akkurat, Synthetic Soul, nago, SamHain86 and rest of the brave HA posse. Hold your breath.. it's coming.. soon.. to download sites near you.
EDIT: Delayed... I've some problems with my PSU and/or CD drive. Sorry.
