Topic: Foobar and the .mpa extension (Read 4322 times) previous topic - next topic
Hi guys, just a small request: could foobar be changed slightly, or configured, so that .mpa extension is recognized as .mp2? I use foobar to transcode audio and certain applications demultiplex audio with the .mpa extension, it's very tiresome to have to go and rename each one
my spider senses tell me foobar picks the decoder based on file extension
hope you can help. thanks
Ant renamer
Sharing delusions since 1991.
thanks for the suggestion, but i'd really like to avoid having to use another app to rename all extensions, it's almost as bad as having to rename them manually (i usually transcode around 5 or 6 every day)
i was hoping it could just be added to the supported types list, like m4a (which is really just aac in mp4, apple uses it to distinguish audio from video)
anyone?
in Windows Explorer do the following
Tools->Folder Options->File Types->New
1) type MPA
2)press OK then find it in the list highlight it press CHANGE and choose foobar from the list and you're done
hellska crew
the problem is foobar doesn't read the file so long as it has the mpa extension. it needs to be recognized as .mp2
