Topic: Windows Vista and Foobar (Crashes) (Read 12302 times) previous topic - next topic
Hi all...
First, sry bad english
So, I got the leaked version of Vista (Final Release), and installed, everything works fine, except foobar
The program works, ok... but some crashes are found... and many componentes simply break.... I will check this later, since I must recustomize my foobar
If I use my settings from XP, Foobar not even open
PS: Someone using Vista+Foobar?
How about we send your IP to Microsoft, maybe they can fix that for you?
Really funny... all my Windows are original, okay? If you don't believe I can post pictures of it.
I'm here posting about a Foobar Bug, and you come with this?
Great awnser hein?
Anyway... here's a screenshot of Bad Allocation Problem, under Vista:
I really don't know if this is really a Foobar Bug, or a incompatibility with Audigy2 ZS Drivers =/
Any ideia?
One of the components in your installation isn't compiled with the newest SDK. Start with a clean install and add them one at the time. Make sure you get the newest versions.
Also, as far as I know there is no Windows Vista 6000 build that is officialy released, it was leaked.
Coppertop, unfortunatelly, this is a clean install just with Audioscrobbler and MonkeyAudio Components
I will check for updates in Audioscrobbler Plugin.
EDIT: Err no Updates... 1.3.2 is the latest version =/
Yes please, show me proof that your Windows Vista is legal.
In my first post I said: my Vista is leaked... I'm saying about older releases, such as: 2k and XP. And I have official licenced RC1 Vista.
Now you understand?
I'm not here to create problems, I'm here just report bugs with Foobar... to be fixed, only this, can't you see this?
Argh... another Crash
Reinstalled everything, and cleaned %APPDATA%/foobar2000
The output of failure.txt
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0043F388h
Access violation, operation: write, address: 00000000h
Call path:
entry=>play_callback_manager::register_callback
Code bytes (0043F388h):
0043F348h:  64 89 0D 00 00 00 00 5B C9 C3 B8 66 8B 4A 00 E8
0043F358h:  30 70 06 00 83 EC 0C 68 18 25 4C 00 8D 4D F0 FF
0043F368h:  15 C4 44 4B 00 83 65 FC 00 B9 4C E4 4D 00 E8 6A
0043F378h:  B3 FC FF 84 C0 74 09 80 3D 05 19 4E 00 00 74 07
0043F388h:  C6 05 00 00 00 00 00 8B 45 08 89 45 E8 8B 45 0C
0043F398h:  89 45 EC A1 18 EC 4D 00 B9 18 EC 4D 00 FF 10 50
0043F3A8h:  8D 45 E8 50 E8 5D 04 00 00 80 7D 10 00 74 0A 8D
0043F3B8h:  45 E8 50 E8 45 F5 FF FF 59 83 4D FC FF 8D 4D F0
Stack (0012E148h):
0012E128h:  00000000 00000000 00000000 00000000
0012E138h:  00000000 00000000 00000000 00000000
0012E148h:  005025B0 00000000 00000005 0012E184
0012E158h:  004A8B66 00000000 017A26BC 017229E0
0012E168h:  017A26B8 00000015 00000001 00000003
0012E178h:  017A0C60 0012E1FC 00000000 0012E1EC
0012E188h:  017407F0 00000001 0171F23D 004DED54
0012E198h:  017A0B10 017A0B10 768C3400 01723FAF
0012E1A8h:  00000001 017248F1 0012E36C 0005035C
0012E1B8h:  00000047 012E0800 0005035C 0012E36C
0012E1C8h:  0005035C 0012E208 768C2539 00EF6958
0012E1D8h:  00000000 768C2545 5A3BCEBD 0012E36C
0012E1E8h:  0005035C 0012E2B4 01741978 FFFFFFFF
0012E1F8h:  0012E2B4 0012E24C 01723F3B 017A0B10
0012E208h:  0005035C 00000047 00000000 0012E36C
0012E218h:  0012E36C 00000047 00000000 768C1A10
0012E228h:  0005035C 00000047 00000000 0012E36C
0012E238h:  00000047 DCBAABCD 00000000 0012E36C
0012E248h:  00000047 0012E2C4 768C3123 01723F00
0012E258h:  0005035C 00000047 00000000 0012E36C
Registers:
EAX: 00000001, EBX: 00000000, ECX: 004DE44C, EDX: 00000003
ESI: 017A26B8, EDI: 004DED54, EBP: 0012E160, ESP: 0012E148
Crash location: "foobar2000", loaded at 00400000h - 004F3000h
Loaded modules:
foobar2000   loaded at 00400000h - 004F3000h
ntdll loaded at 770F0000h - 7720E000h
kernel32 loaded at 76D70000h - 76E48000h
COMCTL32 loaded at 74750000h - 748E4000h
msvcrt   loaded at 76A10000h - 76ABA000h
ADVAPI32 loaded at 76E50000h - 76F0F000h
RPCRT4   loaded at 76710000h - 767D3000h
GDI32 loaded at 75A00000h - 75A4B000h
USER32   loaded at 768A0000h - 7693E000h
SHLWAPI   loaded at 75BE0000h - 75C35000h
SHELL32   loaded at 75C40000h - 7670E000h
ole32 loaded at 76C20000h - 76D64000h
shared   loaded at 10000000h - 1002A000h
comdlg32 loaded at 76940000h - 769B4000h
IMM32 loaded at 77220000h - 7723E000h
MSCTF loaded at 77020000h - 770E7000h
LPK   loaded at 77250000h - 77259000h
USP10 loaded at 76FA0000h - 7701D000h
uxtheme   loaded at 74A50000h - 74A8F000h
foo_abx   loaded at 00620000h - 00654000h
foo_albumlist loaded at 00660000h - 006A7000h
OLEAUT32 loaded at 76F10000h - 76F9C000h
foo_audioscrobbler   loaded at 01280000h - 012B8000h
WS2_32   loaded at 76870000h - 7689D000h
NSI   loaded at 77240000h - 77246000h
foo_cdda loaded at 01320000h - 01356000h
foo_converter loaded at 013D0000h - 01439000h
foo_dsp_std   loaded at 01360000h - 013A1000h
foo_freedb2   loaded at 01450000h - 01490000h
foo_input_monkey loaded at 01490000h - 014D9000h
foo_input_std loaded at 015F0000h - 01704000h
foo_masstag   loaded at 014F0000h - 01540000h
foo_rgscan   loaded at 01560000h - 015A8000h
foo_ui_std   loaded at 01710000h - 01767000h
foo_unpack   loaded at 01770000h - 0179E000h
ctagent   loaded at 01890000h - 01897000h
NLAapi   loaded at 74480000h - 7448F000h
IPHLPAPI loaded at 75280000h - 75299000h
dhcpcsvc loaded at 75240000h - 75275000h
DNSAPI   loaded at 754B0000h - 754DB000h
Secur32   loaded at 75840000h - 75854000h
WINNSI   loaded at 75230000h - 75237000h
dhcpcsvc6 loaded at 75210000h - 75230000h
mswsock   loaded at 75000000h - 7503B000h
winrnr   loaded at 71380000h - 71388000h
WLDAP32   loaded at 769C0000h - 76A09000h
PSAPI loaded at 75910000h - 75917000h
napinsp   loaded at 71370000h - 7137F000h
pnrpnsp   loaded at 71240000h - 71252000h
wshtcpip loaded at 74CE0000h - 74CE6000h
wship6   loaded at 75070000h - 75076000h
rasadhlp loaded at 72FA0000h - 72FA6000h
CLBCatQ   loaded at 767E0000h - 76864000h
DSOUND   loaded at 6F270000h - 6F2E1000h
WINMM loaded at 744E0000h - 74513000h
OLEACC   loaded at 744A0000h - 744D8000h
POWRPROF loaded at 74D00000h - 74D1A000h
MMDevApi loaded at 74410000h - 74437000h
SETUPAPI loaded at 75A50000h - 75BD8000h
WINTRUST loaded at 74B50000h - 74B7D000h
CRYPT32   loaded at 75330000h - 75421000h
MSASN1   loaded at 75470000h - 75482000h
USERENV   loaded at 75860000h - 7587E000h
imagehlp loaded at 76AC0000h - 76AE9000h
audioses loaded at 73420000h - 73441000h
audioeng loaded at 733B0000h - 73416000h
AVRT loaded at 74490000h - 74497000h
dbghelp   loaded at 71D80000h - 71E5C000h
Stack dump analysis:
Address: 004A8B66h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 017229E0h, location: "foo_ui_std", loaded at 01710000h - 01767000h
Address: 017407F0h, location: "foo_ui_std", loaded at 01710000h - 01767000h
Symbol: "foobar2000_get_interface" (+0001A200h)
Address: 0171F23Dh, location: "foo_ui_std", loaded at 01710000h - 01767000h
Address: 004DED54h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 768C3400h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "RemovePropW" (+0000004Bh)
Address: 01723FAFh, location: "foo_ui_std", loaded at 01710000h - 01767000h
Address: 017248F1h, location: "foo_ui_std", loaded at 01710000h - 01767000h
Address: 768C2539h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 768C2545h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetWindowLongW" (+00000037h)
Address: 01741978h, location: "foo_ui_std", loaded at 01710000h - 01767000h
Symbol: "foobar2000_get_interface" (+0001B388h)
Address: 01723F3Bh, location: "foo_ui_std", loaded at 01710000h - 01767000h
Address: 768C1A10h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetMessageW" (+0000006Eh)
Address: 768C3123h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetWindow" (+0000010Fh)
Address: 01723F00h, location: "foo_ui_std", loaded at 01710000h - 01767000h
Address: 768C1A91h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetMessageW" (+000000EFh)
Address: 769076B4h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "AlignRects" (+00001926h)
Address: 768C1C03h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetMessageW" (+00000261h)
Address: 768C1C0Eh, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetMessageW" (+0000026Ch)
Address: 768B93D5h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "DestroyWindow" (+000007AFh)
Address: 768C3656h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "OffsetRect" (+0000004Dh)
Address: 77150E6Eh, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "KiUserCallbackDispatcher" (+0000002Eh)
Address: 77150E20h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "KiUserApcDispatcher" (+00000048h)
Address: 768C1BB8h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetMessageW" (+00000216h)
Address: 768BC5ACh, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "MsgWaitForMultipleObjectsEx" (+000000ACh)
Address: 768BC56Bh, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "MsgWaitForMultipleObjectsEx" (+0000006Bh)
Address: 768BC5C5h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "MsgWaitForMultipleObjectsEx" (+000000C5h)
Address: 768B12C9h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "DefDlgProcW" (+000000C0h)
Address: 768B1450h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "DefDlgProcW" (+00000247h)
Address: 768CF099h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "SoftModalMessageBox" (+00000563h)
Address: 768A0000h, location: "USER32", loaded at 768A0000h - 7693E000h
Address: 768CE773h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetPhysicalCursorPos" (+00000A9Ah)
Address: 768CEB11h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetPhysicalCursorPos" (+00000E38h)
Address: 7715648Ch, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "AlpcGetHeaderSize" (+00000112h)
Address: 768CDE8Ch, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetPhysicalCursorPos" (+000001B3h)
Address: 7712C485h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlHashUnicodeString" (+00000417h)
Address: 768BD2CCh, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetCursorPos" (+00000C70h)
Address: 7712C4D1h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlHashUnicodeString" (+00000463h)
Address: 77151843h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlAllocateHeap" (+00000216h)
Address: 768A00E0h, location: "USER32", loaded at 768A0000h - 7693E000h
Address: 00650025h, location: "foo_abx", loaded at 00620000h - 00654000h
Symbol: "foobar2000_get_interface" (+00027F45h)
Address: 77130FF1h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "memcmp" (+00000036h)
Address: 771586CDh, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlConsoleMultiByteToUnicodeN" (+00000494h)
Address: 7712C652h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "LdrGetProcedureAddressEx" (+00000179h)
Address: 77152D96h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlFreeUnicodeString" (+00000085h)
Address: 7712C628h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "LdrGetProcedureAddressEx" (+0000014Fh)
Address: 768C5838h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "MessageBoxTimeoutW" (+0000005Fh)
Address: 768C57A6h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "MessageBoxTimeoutA" (+00000075h)
Address: 768AB132h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetUserObjectInformationA" (+00000000h)
Address: 768B17A9h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "GetProcessWindowStation" (+00000000h)
Address: 768C5728h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "MessageBoxExA" (+0000001Bh)
Address: 004E0A40h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B5098h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 768C5704h, location: "USER32", loaded at 768A0000h - 7693E000h
Symbol: "MessageBoxA" (+00000025h)
Address: 0049EA08h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497A34h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497B03h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 76FAD8E7h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptGetCMap" (+00002CC0h)
Address: 76FF7268h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptPositionSingleGlyph" (+00006288h)
Address: 76FF7124h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptPositionSingleGlyph" (+00006144h)
Address: 76FF7344h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptPositionSingleGlyph" (+00006364h)
Address: 76FAB378h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptGetCMap" (+00000751h)
Address: 7715240Bh, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B25h)
Address: 77152447h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlTryEnterCriticalSection" (+00000B61h)
Address: 77152054h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlTryEnterCriticalSection" (+0000076Eh)
Address: 77152033h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlTryEnterCriticalSection" (+0000074Dh)
Address: 770F8BF2h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "EtwLogTraceEvent" (+000000FBh)
Address: 77130F91h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "wcslen" (+00000464h)
Address: 77151C21h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlTryEnterCriticalSection" (+0000033Bh)
Address: 00497EE2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00499127h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497420h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049F7EBh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049E1ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7C58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004974AEh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77151039h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlRaiseStatus" (+000000B4h)
Address: 7715104Dh, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlRaiseStatus" (+000000C8h)
Address: 7715100Bh, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlRaiseStatus" (+00000086h)
Address: 771129D7h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlGetAce" (+0000013Eh)
Address: 004D83F0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 76DB7A7Eh, location: "kernel32", loaded at 76D70000h - 76E48000h
Symbol: "HeapFree" (+00000014h)
Address: 76FA9ADBh, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "UspFreeMem" (+0000002Dh)
Address: 76FACAAAh, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptGetCMap" (+00001E83h)
Address: 76FAC6E3h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptGetCMap" (+00001ABCh)
Address: 76FAC6F7h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptGetCMap" (+00001AD0h)
Address: 77150E97h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "KiUserExceptionDispatcher" (+0000000Fh)
Address: 76D8B09Eh, location: "kernel32", loaded at 76D70000h - 76E48000h
Symbol: "RaiseException" (+00000058h)
Address: 004E2AC4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A7288h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004386DAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004983DAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043F4AFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C58B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C23DCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440B98h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A0347h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D8348h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049F7DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF789h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A02A7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00499570h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77151074h, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlRaiseStatus" (+000000EFh)
Address: 004AF7B4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77112C4Bh, location: "ntdll", loaded at 770F0000h - 7720E000h
Symbol: "RtlUnwind" (+000000E3h)
Address: 004D8C88h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 74A88CA8h, location: "uxtheme", loaded at 74A50000h - 74A8F000h
Symbol: "Ordinal74" (+00007494h)
Address: 74A57E0Dh, location: "uxtheme", loaded at 74A50000h - 74A8F000h
Symbol: "GetThemeEnumValue" (+00000297h)
Address: 76FAAB2Bh, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptLayout" (+00000762h)
Address: 76FF7100h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptPositionSingleGlyph" (+00006120h)
Address: 76FF74A4h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptPositionSingleGlyph" (+000064C4h)
Address: 76FF7000h, location: "USP10", loaded at 76FA0000h - 7701D000h
Symbol: "ScriptPositionSingleGlyph" (+00006020h)
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
ReplayGain Scanner 2.0.2  (foo_rgscan)
freedb Tagger 0.5.2a  (foo_freedb2)
Converter 1.0.1  (foo_converter)
ABX Comparator 1.3.1  (foo_abx)
Album List 3.2.0  (foo_albumlist)
Masstagger 1.6  (foo_masstag)
RAR reader 1.1  (foo_unpack)
FLAC Decoder 1.1.0  (foo_input_std)
CD Audio Decoder 2.1.1  (foo_cdda)
WMA Decoder 1.1  (foo_input_std)
Default User Interface 0.9acc  (foo_ui_std)
foobar2000 core v0.9.4.1  (Core)
Audioscrobbler 1.3.2  (foo_audioscrobbler)
ZIP/GZIP reader 1.0  (foo_unpack)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
Standard DSP array 1.0  (foo_dsp_std)
Have you tried it without the Monkey's Audio? Also, were you doing anything at the time of the crash or just listerning to music (what codec?)
Also, if you edit your post and change [ code ] and [ / code ] to [ codebox ] [ / codebox ] (without the spaces ofcourse) it won't take up so much space.
I was listening to MonkeyAudio, I'll try with FLAC/MP3 now.
At the time of crash, I was simply using Mozilla Firefox and Windows Live Messenger.
Thx for the Codebox tip
Now you understand?
Ah yes, sorry. That makes it perfectly legal, of course...
Fuck, do you have shares in MS or something?  Give they guy a break.  Anyway, why are you so worried about what this guy is doing anyway?  What's it to you?
You are not helping anyone.
Now you understand?
Because it makes it look like we embrace warez, which we do not.
The only thing I had to do to stop foobar2000 from crashing under Vista was to  update foo_ui_columns. My old config came over flawlessly.
Now you understand?
Okay...
I'll not more reporting bugs, exploits nothing more... since the moderador don't want this.
Thx Coppertop, Canar, Funkstar De Luxe for helping...
I will be using some alternative until Foobar gets fixed for Vista.
i have a lot of problems with fb2k and windows vista too. i can't add songs to the playlist once i have initiated playback, foobar totally crashes. i have it set to 'enque incoming files when adding from the commandline', and every time something gets add, bam, there it goes.
just my slant.
Hi, i'm reporting this kind of crashes with my Vista RC2 too . I haven't still found the cause. We could share our config here...
Additional info:
Special file info box 2.0.4  (foo_infobox)
Shell link resolver 1.1  (foo_lnk)
Console panel 0.2  (foo_uie_console)
Lyric Show Panels 0.3.0.0  (foo_uie_lyrics)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Menu Addons 0.3.5  (foo_menu_addons)
Audio CD Writer 2.0.1  (foo_burninate)
Common services 0.1  (foo_common)
History 0.2  (foo_history)
Live show tagger 0.6.1  (foo_tradersfriend)
Shorten decoder 0.4.2a  (foo_input_shorten)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Dockable Panels 1.0.2 [Oct 31 2006 - 16:30:41]  (foo_dockable_panels)
Playlist tools 0.5.7  (foo_utils)
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
Randomized playlist entry 1.2.3  (foo_random)
MIDI synthesizer host 1.7  (foo_midi)
FLAC decoder 1.1.0  (foo_input_std)
Playlist Manager 1.0  (foo_playlist_manager)
Playback Statistics 1.3.2  (foo_playcount)
Columns UI 0.1.3 beta 1v6 TEST  (foo_ui_columns)
Masstagger Addons 0.3.2  (foo_masstag_addons)
foobar2000 core v0.9.4  (Core)
Cuesheet Creator 0.4.5  (foo_cuesheet_creator)
Audioscrobbler 2.1  (foo_audioscrobbler)
Track Finder 2.1.1 [Jun 16 2006 - 12:36:15]  (foo_trackfinder)
Album Art Panel Mod (MSN) 0.2.1_8  (foo_uie_albumart_msn)
Database search 1.3.1 beta 11  (foo_dbsearch)
Music Browser 1.2.2c [Jul  6 2006 - 09:42:02]  (foo_browser)
Track info panel mod 0.7.1 beta [Oct 24 2006 - 22:48:54]  (foo_uie_trackinfo_mod)
new development...foobar wont load at all anymore. 'Unhandled exception: Bad allocation'.
any clue what this means?
the only extra plugin im using on top of standard ones is columns ui. i'm on vista rc2. foobar was working somewhat until today now it dont work at all. i cant wait til i can take this crappy version of windows off this computer.
Foobar is an 32-bit application. Maybe this is the problem ? It is not 64bit compatible.
NogginJ: Do you use the test version of Columns UI?
I'm running the latest version of Vista, the RTM release.
Here's a list of components I have working.
foo_albumlist
foo_audioscrobbler
foo_custominfo
foo_cwb_hooks
foo_out_ks
foo_ui_columns
foo_uie_albumart
foo_uie_albumlist
foo_uie_playlists_dropdown
foo_uie_quicksearch
Everything works except for when I change between artists 4-5 times in a row with Album List, then it crashes.
i found out that lyricsdb and lyrics show crashed foobar in windows vista
I found out for myself, that the "typical Vista crash" only happens, when I migrate my old configs to Vista. If I delete the index.dat file in the playlists folder, and let Foobar itself recreate it, I don't get any crash anymore.
Maybe this will help some of you.
I think i've found the problem with this plugin :
it's a problem of access right of your files, it seems that Vista set nearly all your files as "Read Only" by default, so lycricsdb can't update the ID3 tags of your files, and, lyricsdb writes files (if a new lyrics has been found) when you close foobar, and it crashes.
But. i have noticed that "right click - File Info" on a mp3 file, if it is "read only" , no exception will be thown if you edit the tag, foobar won't succeed in editing your file, but it will do as if it succeeded.
So i hope lyricsdb will do that oneday.
