Topic: Converting to FLAC doesn't work (Read 5702 times) previous topic - next topic
I am new to this and now I am trying to convert fromCD to FLAC. I have followed this description as far as I can understand it. The discription is very good  , it's something with me...
http://www.hydrogenaudio.org/forums/index.php?showtopic=30959
What I get out of this is WAV files not flac files. What do I do wrong? Grateful for some good ideas and guidelines...[/quote]
Iam using EAC,
configured Compression options, external compression,
|x| use external program for compression
Parameter: User Define Encoder
file extension: .flac
Program for compression:C:\Programfiler\FLAC\FLAC.exe
Still I get only Wav-files....
Double posting
Make sure you click on the "MP3" button in EAC ... (not the "WAV" button)
- p
http://www.hydrogenaudio.org/forums/index....showtopic=30959
Iam using EAC,
Do you extract/rip to compressed files or uncompressed? When you have an audio CD put in, select a track and pushes command key F6 what files do you get?
NOW I got it  Use comporessed - then it's compressing to FLAC after WAV. Great!
Thanks for good and QUICK help!
But still there are some more questons:
I add these command line options:
-6 -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -T comment="%e" -T "comment=EAC (Secure Mode)" %s
This is the filename I get. And its most of the informaton, but I want the Pink Floyd Catalog (if its not there) automatically to be created. It doesn't.
I also want the Album Catalogue to be created. It doesn't
Pink Floyd - Wish You Were Here [Gold Edition] - 01 - Shine On You Crazy Diamond - Part 1-5.flac
What do I use as command line options to make these to catalogues automatically created?
This is so great forum  And my Squeezebox is incredible
The options for output filenames are actually in EAC....assuming you're not in beginners mode then go to EAC->EAC options, Filename tab...you can then create whatever output filename you like using the options it gives
For example mine is:
%D\%C\%N - %A - %T
which puts each artist in a directory with it's albums underneath it and the tracks underneath that
...and yes Squeezebox + FLAC = awesome
