Topic: foo_scheduler (Read 352519 times) previous topic - next topic
foo_scheduler
Request:
- Option to shutdown the machine after a period of time or songs played
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
foo_scheduler
Request:
Why not to use such config:
  • On playback end, disable after done
        ...some actions...
        2 minutes delay
        Shutdown
foo_scheduler
Just thought of this, dunno if it will work... could you just set the time to run the task in 1 min then have the task as something like
-delay for X minutes
-shutdown..
I agree that an option would be better but I think this should work as a temporary work around
foo_scheduler
Request:
Besides setting the foobar2000 volume, setting the Windows MASTER volume would be very useful.
For example, you can end the day listening the music through your headphones, where a lower windows master volume is necessary, but want to be woken up the next morning - in which case a higher windows master volume is vital.
Of course, if you forget to unplug the headphones.... But that is something you can do even if the notebook is already off...
foo_scheduler
Is already there a way to create these actions I had with 0.8:
1)  Shutdown on track end
2)  Change playlist to "playlist_name" after 2h:00m
3)  Change playlist to "playlist_name" on playback end
4)  Change playlist to "playlist_name" at 10:30 AM
5)  Exit Foobar (saving config and database files) after/on/at...
foo_scheduler
Reply #32
thanks fot that great plugin
foo_scheduler
1) on playback end
2) yes
3) yes
4) yes
5) no (will be in the next version)
Why not to download and try yourself?
foo_scheduler
Reply #34
1) on playback end
2) yes
3) yes
4) yes
Sorry, I had a look but, obviously, it had not been a careful one.
Anyway, I can't find the way to do the # 2 in the list above: which event should I start with?
In my post, I was meaning: "change to that playlist after two hours from when I check this command. At least, from when I close the settings window.
In the player list I can only see "On playback end" and in the date/time list I cant see a "delay"
time field. Yes, I saw there is a delay action but I have to start with an event first, so?
foo_scheduler
Reply #35
Thank you very much andrew_smolko!
Requests:
  - Event: Track change
  - Action: Foobar command
Then I can use foo_run with cwb_hooks to check wether i have album art for the album and run CoverDownloader if i haven't.
foo_scheduler
Reply #36
Wow, just when I think there is nothing else that can be added, somebody creatively comes up with a fantastic idea!  Thanks, I will put this to good use, esp. when on the road with my notebook, and one of those hotel alarm clocks that play fuzz and are impossible to set right.
foo_scheduler
Reply #37
Right now im just using 1 playlist all the time, (i have albums organized with .m3u files). how do i make it so it goes back to the first track of the playlist, its not very useful when it only plays the last song on the playlist. (its on the last song because i played the whole playlist when i fell asleep.
Edit: i kind of fixed it. i just made the last song a really long loud one.
foo_scheduler
Reply #38
2) yes
Oops  It can be done in my development build, not in public release 3.01. Wait for the next version. There it will be possible to start scheduler action lists from main menu. The configuration will look like this:
  • On menu item "Item identifier"
    • 5 minutes delay
    • Shutdown
foo_scheduler
Reply #39
thanks man i waited long for this one,
THANK YOU SO MUCH
foo_scheduler
Reply #41
3.05 is ready!
foo_scheduler
Reply #42
Thanks, finally got the "timer" to work, thanks to the menu item addition =)
Unfortunately there's no way to see the remaining time, a title format would be good to use in e.g. Trackinfo or statusbar/caption.
foo_scheduler
Reply #43
hello,
can you make the plugin allow twice or more equal events?
I like to shutdown when the playback ends, but also like to close the player sometimes...
ty anyway
foo_scheduler
Reply #44
Could you add a warning if the user tries to save an event for a past date? Maybe it could even be smart warning, meaning it would offer a correction, too. For example: user tries to save an event for 7am 2nd November on the 5th November, a warning window pops up saying "event date is in the past, would you like to save it for 7am 6th November (so the next day 7am)", and user would be able to either accept the change or go back and edit or even save it with the "useless" setting.
What do you think?
(I almost missed a wake up alarm because of not changing the date on a past event  )
A very good component, though, I never knew how much I was missing a scheduler until recently
Life is Real...
(But not in audio :) )
foo_scheduler
Reply #45
Marked, as TODO for future versions.
Already in TODO list!
Could you add a warning if the user tries to save an event for a past date? ...
No problem, added to TODO list.
foo_scheduler
Reply #46
I can't seem to get a timer that I make to work. I make a new timer, I set a delay for say 5 min, then after that I have it shutdown foobar. I click the menu to run scheduler event click the timer, 5 min passes and nothing happens. Can someone post what they are using for their timer settings so I know if I am doing this right.
oh and i have version 3.05 if that makes a difference.
THanks,
Josh
foo_scheduler
Reply #47
What does that mean?
jackassbikeco... try it with stopping play (just because I know that has worked for me)...  I have 60minute delay and then stop play.  The reason I suggest using a more simple function is because I think in the past I have had timers not turn off...  and alarms not go on.  I haven't verified it because.... normally I'm half asleep and I can't tell if it's a software problem or me not being fully awake ~_~
foo_scheduler
Reply #48
What he means is that if he wants to have the same event twice. He wants it to allow him to setup say two identical alarms. I think that is what he means. Oh and i will try it to make a new timer again, i was kinda tired when i was playing around with it so maybe i missed something.
Thanks,
Josh
foo_scheduler
Reply #49
couple of question.
how are people saying shut down the computer in x mins. i can only seem to have it on playback end. i want it to shut down on a timer dont care if it is playing. your talking about the timer but i cant find it
I would like to request a fade in & fade out volume.  Also being able to set the playback order would be cool.
