Topic: [crashware] foo_input_mslive (Read 276516 times) previous topic - next topic
Reply #175
hm... I mentioned about foo_title will cause problem for mslive in the first post before, since I don't use that component anymore, I can't say if it will still cause problem, so I removed the words there...
but I don't know why it causes the problem though, probably it improperly does things about COM interface.
Reply #176
Hmm, and chance in getting this stream to work?
http://soulfulsmoothjazz.com/listen128.asx
I'm getting spotty success with this one.  I got it to stream the first time I tried it, and successive attempts have given me this error message with v0.3 -
Decoding failure at 0:00.000 (Unknown error(c00d2ee6)):
"mslive://|http://soulfulsmoothjazz.com/listen128.asx|list|/"
I left the computer alone for a while to do something else, came back and tried it, and it worked the first time again.  I got the error every attempt after that.
Reply #177
Unable to open item for playback (unsupported content type):
CORRECTION:
I'm sorry i have forgotten to update mslive :-(
So, that stream plays FINE always
Reply #178
ok, it's fixed now, that was the bug when the server is busy it would give up trying other reference urls.
Reply #179
I think there's a reconnect problem. This happened to me three times already: I played http://www.wdr.de/wdrlive/media/wdr2-wm32.asx, it played for 30-60 minutes, then playback interrupted. The connect window appears as fullscreen and doesn't progress. Nothing happens any more. I have to cancel and start the playlist entry again, then it works as usual again.
I'm using 0.31.
Reply #180
hi,
is there any chance for proxy support?  specifically socks
Reply #181
@Squeller,
did it happen just once? I have not encountered, so I don't know what to do.
go full screen sounds rediculous, you sure it's mslive caused it?
@omiwolf,
I don't need to use proxy, and it's hard to find socks to test, so no.
Reply #182
I don't know why the progress window went fullscreen. But let's forget about it, I realized I had lots of errors on my network interfaces because of wrong link speed and duplex mode; now the problem never happened to me again.
Reply #183
hey what is this?
Failed to load DLL: foo_input_mslive.dll
Reason: This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
Reply #184
Did it work before, did you have the vc++ runtimes installed?
You could delete the plugins configuration entries in foobar2000.cfg, i.e.:
1. delete the dll
2. start fb2k
3. Answer "no" when it asks about keeping the configuration
4. put the dll into the directory again
5. start fb2k, does it work now?
Reply #185
1. delete the dll
2. start fb2k
no, have to? I'm not sure what it is when I google it though.
first time I install the plugin.
.cfg shows me alot of crap, dont know what to delete.
when I delete the dll and start foobar, nothing happens.
I put the dll into the dir again, but still the error. (so far I didn't change anything)
Reply #186
Just read my previous posting again. I wasn't talking about directly editing the file. Please delete the binary code out of your previous posting  Just do steps 1-5.
EDIT I see you can leave that out, because the component didn't ever run on your system, so no configuration in the cfg file has been left yet. I guess it's just because you're lacking the runtimes.
You need them in order to run the component. Read the first posting of acropolis! Get them at http://acropolis.lokalen.org/2006/10/fooba...2000-components, I don't know the original ms location.
Reply #187
thank you it works!
Reply #188
Hello,
I have problem with polish radio...
I've read all posts since last update, but I could't find any solution of my problem.
I have problems with this radio:
http://www.itvp.pl/i.tvp/radio/media/pr3/
wmp link: http://lokal.itvp.pl/asx/2/5/83.29.77.121.45c3766e669a88.19420225.asx
In foo none of them worked... [in wmp10 this links work correctly]...
Is there any chance to listen this radio in foo?
I'll check as I update it, I've been fairly busy with other stuff at the moment.
With the latest version of your component, this link above works partially.
itvp.pl server prevents users from (probably) easy stream recording (as it plays in full 192kbit stereo),
so it generates random path to every stream we want to play, every time.
With Foobar and mslive plugin we can hear only itvp.pl announce, something like that:
"Interactive Polish Televison, itvp - presents", then plugin show us title for the station
(without polish characters, maybe due to bad coding), then opens internal playlist, and
stops. Only canceling is possible.
Link works correctly in my WMP11 only.
EDIT: Link which is resolved correctly by WMP11 is: http://v1.itvp.pl/radio/media/pr3/
It plays announce, and immediately after it streams Polish Radio Program 3 in 192 kbit
Also for your help here is the link to that station: www.radio.com.pl/trojka where you
can see speaker icon and text "posluchaj" = "listen now"
Reply #189
it works, finding "http://v1.itvp.pl/radio/media/pr3/" is your job.
but I'll see if I can do some internal redirection.
Reply #190
Yeah, just like Acropolis said, IT WORKS like CHARM! It creates two entries in playlist, plays that annouce then it plays normal radio. BUT! There's bad char encoding (below).
it has crashed when it has been creating internal playlist
Reply #191
I took a quick debug, I think it's not possible to redirect
    to: http://v1.itvp.pl/radio/media/pr3/
because the foobar provided http handler doesn't support http status code 302 (Moved Temporarily).
but I'll fix the encoding problem of the displayed text though.
@Morfeus,
there may be a bug, but I can't reproduce it (I don't get crashed at all), so for the moment I'll ignore it, and you just try to add the radio again.
Reply #192
Yeah I have just produced the same crash so:
1) I open that radio (through add location (mslive))
2) Close that dialog Add Location (mslive), while mslive is creating internal playlist
3) Start playing some song (my case mp3)
Result: It start playing a then crashes (crash log appears).
Try it. Every time I repeat those steps, it crashes.
I can't reproduce it when using some fast asx e.g. dialog creating internal playlist closes in shorter time than that stream above
Reply #193
ok, I've fixed it, as well as the wrong display, will be uploaded to my blog soon, as they are not that critical.
* another update has been made, check my new requirement in my blog *
Reply #194
Acropolis: sorry but i can't get to your components post. And I still doesn't know what's that new dependency
Reply #195
you will need vc8 sp1 runtime as before, as well as libmmd.dll (extract it to SYSTEM32 or foobar directory), and most important, now my components need Pentium 3+ or compatible computer, they use SSE now.
the dll is needed for most of my components too, because now I use the Intel C++ compiler.
Reply #196
No problem, i have amd athlon 64
question: will it work with intel celeron (just question)? because i know that first was pentium 2 then celeron and AFTER it was pentium 3. And i know that celeron supports SSE
Reply #197
it will work as long as the cpu support the instruction set, I just make it general to say P3+ required, but I don't know about celeron.
I can't differentiate different types of celeron, and always have an impression that it is just a pentium II grade cpu. for me,  celeron = slow.
Reply #198
So Intel Celeron (old NOT that new Celeron D or something like that) is derivate from Pentium 3, so it is supported
EDIT: I don't see the point of building those "Intel Builds". From version 0.34 to version 0.35 size raised 2,6x  and only one "tiny little bug" has fixed.
Reply #199
I have said about the new builds in my blog already. bugfix is another thing, intel compiler can generate faster code, while it has to sacrifice the file size.
