Topic: iTunes cover art automator? (Read 8941 times) previous topic - next topic
Just found out about http://dyn2.uneasysilence.com/coverart/index.php - great quality, but is it possible to make foobar run over all my albums, replacing the current art with ones from there?
err... i'm not using windows any more ;)
I got it working with foo_run, if anybody is interested how just ask
Well it's complicated, but here we go
http://php.net/ - Download a windows binary for PHP 5, install to C:\php
Download http://www.avantlumiere.com/svn/i7AWF/trunk/i7AWF.php to c:\php\downloadcovers\downloadcover.php
Add this before ?> to it:
$i7 = new i7AWF;
if ($argv[1] != 'Music') {
$artist = $argv[1];
$album = $argv[2];
} else {
$artist = $argv[2];
$album = $argv[3];
$i7->artist($artist);
$i7->album($album);
echo "About to download...\n";
$url = $i7->payload();
echo "Downloading...\n";
$cover = file_get_contents($url);
if ($cover == '' || !$cover) {
echo "Error!";
$errlog = file_get_contents('downloadcovererrors.txt');
file_put_contents('downloadcovererrors.txt', $errlog . "\nNo cover for $artist - $album");
} else {
echo "Writing...\n";
$file = fopen("D:\Music\\$artist\\$album\cover.jpg", 'w');
fwrite($file, $cover);
fclose($file);
echo "Done!";
Change the fopen("D:\Music....") to your directory where your music is. It assumes Artist\Album[\CD <num>] structure, with cover.jpg filenames.
Make a foo_run command, infinite simultanius runs (it only works with this, but jeez if you run it on your entire music collection you'll bring your system down, be warned)
C:\php\php.exe C:\php\downloadcovers\downloadcover.php "$directory(%path%,3)" "$directory(%path%,2)" "$directory(%path%,1)"
Make an autoplaylist with all the first tracks of your albums, and do it in sets of albums (to avoid crashing your machine). From now on, to download art, right click the first track, Run -> Cover Downloader (or whatever your named it). It outputs to an error file in its directory if it can't find album art.
EOF
http://tom.zickel.org/getartwork/
A great little app (32k) that scans whole directory batches for iTunes covers.
Works great, no options or anything.
http://printf.dk/itunes_7_fetching_artwork_for.html
If you'd read my post, you'd see I used the PHP port...
Was it updated for when iTunes disabled downloaing?
Plus, mine doesn't rely on tags.
Yep. I think it was updated just a few days ago. Tried it a few hours ago, and got rather nice results on literally hundreds of subfolders.
Nothing's perfect, though: Various Artists albums output the %1st artistname% - %album%.jpg.
How do i get that output format in imageabs2()? This does not work:
$imageabs2(86,86,,,,,$sub(%_width%,87),1,$replace(%path%,%filename_ext%,)%artist% %album%.jpg,)
For me the advantage of my script is it's intergrated into foobar. But I can see why people would want a GUI.
I would prefer a CLI, but not at the expense of having to run it through PHP or Python.
I could use one of those PHP to C compilers
Elliot, I'm having a problem with your script.
I followed you directions exactly, but nothing happens when I run the command (well almost nothing, a black cli window flashes for a brief second, it has some writing in it but it's gone before I can read it).
No cover art is created.
I replaced the fopen D:\Music\\$artist\\$album\cover.jpg to C:\Documents and Settings\Owner\My Documents\My Music\\$artist\\$album\cover.jpg
When I run C:\php\php.exe C:\php\downloadcovers\downloadcover.php from the command line, I get
Fatal error: Call to undefined function curl_init() in C:\php\downloadcovers\downloadcover.php on line 36
Is over the of = % over 100
Fluffy: Oops, open c:\php\php.ini-dist, change ;extention = php_curl.dll (or similar) to extension = php_curl.dll (just remove the .
too bad that it only reads ID3v1 tags
...and only works with MP3s.
