Topic: WMA converting (encoding) error w/fb2k 0.9.4 & 0.9.3.1 (Read 1465 times) previous topic - next topic
I have set to convert monkey audio file into WMA with the following settings:
WMA Standard, Quality-based VBR
Encoder: C:\Program Files\Windows Media Components\Encoder\WMCmd.vbs
Extension: wma
Parameters: -silent -a_codec WMA9STD -a_mode 2 -a_setting Q75_44_2 -input %s -output %d
Format is: lossy
Highest BPS mode supported: 24
Encoder name: WMA Standard
Bitrate: <blank>
Settings: VBR quality-based
However, I got an error message - Error flushing file (Object not found)
What's wrong with it.
Could someone give further advice. Thanks a lot.
Have you installed Windows Media Encoder and is the path to WMCmd.vbs correct? What is the destination filename?  (A filename like "- _ - 1.wma" won't work.)
If you still encounter a problem, please post a log from foobar2000 -> View -> Console.
