Topic: LAME 3.97 released (Read 56258 times) previous topic - next topic
LAME 3.97 released
Today, the LAME developer team released the final version of LAME 3.97.
You can grab the sources here:
http://prdownloads.sourceforge.net/lame/la...tar.gz?download
The changelog is available here:
http://lame.cvs.sourceforge.net/*checkout*...l?revision=1.82
Binaries (lame.exe and DLL) at RareWares:
http://www.rarewares.org/dancer/dancer.php?f=109
LAME 3.97 released
One thing at a time! I didn't even update the official LAME page yet
LAME 3.97 released
OK, just added some quick compiles to RareWares. More goodies to come soon!
LAME 3.97 released
After more than 10 alpha version, 3 beta, it's definitely a great release!
When I included 3.97 for the first time in one test more than two years ago I didn't expected such long maturation time
3.98 is also very promising.
Many thanks to Gabriel, Robert, Alexander, Takehiro, John33 and all contributors!
LAME 3.97 released
[noob]Ok fine now, but when is lame 4 ready?      [/noob]
Great news!
LAME 3.97 released
[quote name='Fandango' date='Sep 25 2006, 00:45' post='434488']
[uber-noob]Should I encode my collection now, or wait for LAME 5?[/uber-noob]
Many thanks to all the contributors for what is such a great encoder.
LAME 3.97 released
Very Surprise! to me.
Now Recommended Encoder is 3.97 final.
LAME 3.97 released
This is great news, I thought it would stay at beta.
LAME 3.97 released
Congratulations and kudos to whole team! Thanks!
An eye for eye will make the whole world blind
LAME 3.97 released
A full set of compiles is now at Rarewares.
LAME 3.97 released
Great work guys! Thanks!
Edit: fixed. Thanks!
Every night with my star friends / We eat caviar and drink champagne
Sniffing in the VIP area / We talk about Frank Sinatra
Do you know Frank Sinatra? / He's dead
LAME 3.97 released
Uhm, what's the difference between
and
http://www.rarewares.org/dancer/dancer.php?f=107
now?
Roberto compiled the first ones, in my absence, and I compiled the second. I'm not sure what compiler he used, but any difference would be down to that.
LAME 3.97 released
Yep, his compile encodes at around 8x while your's does at 10x (P4-HT@2.4GHz). Apart from a slightly different header the mp3s are identical, of course.
LAME 3.97 released
WoW~~!!!
Hyper Super Ultra Great News~~!!!!!!
LAME 3.97 released
Has LAME reached its peak in development ? I mean, quality-wise.
LAME 3.97 released
only the next version will tell. But current alphas say: NO!
LAME 3.97 released
Oh? Can I get a summary on the future direction of LAME?
Also, I think I'd estimate that the improvement from 3.90->3.97 was about 10-15% how much room for improvement is there in the future?
LAME 3.97 released
10-15% more tonal purity!
I'm assuming you mean 10-15% lower filesize for a given quality? Do you have any research to back this, or is this TOS#8-breaking speculation?
LAME 3.97 released
There has been some discussion about proposed features for version 3.98. Specifically this post.
Here's some comments on upcoming features / modifications intended for version 3.98
*Add mp3x build back to the VC8 projects It was present in vc6 projects, but I'd like to try using up-to-date gtk libs instead of the ones from 2000.
*Move intrinsics functions into separate files Right now they are inside the regular .c files. It's not very clean.
*Intrinsics support for gcc, both x86 and x64 Should be a matter of configure detection in order to enable the proper define.
*New short blocks detection
I already started to work on it, but did not touched it since a few monthes. It's faster, and do not need our current kludge introduced in 3.97b3, but would probably need some tuning.
*Resolve issue regarding bit reservoir/max number of bits and FhG decoders.
An issue has been identified that cause FhG DShow decoder to output silence. A workaround is enabled in current 3.98, but it causes some bitrate inflation/waste. More investigations would be needed in order to be able to separate max reservoir use from max frame size.
*Quantized signal power "normalisation" for low bitrates This is in order to avoid dropouts at low bitrates.
LAME 3.97 released
Finally!
Now to begin the arduous task of re-encoding my rips...
</signature>
LAME 3.97 released
Woo hoo, and I was going to reencode all my FLAC files so here's hoping dbpowerAMP gets sorted with 3.97 soon!!
LAME 3.97 released
 ... I guess Aoyumi's leading example of actually releasing a non-beta (i.e. AoTuV Release 1) is now being followed by the rest of the world
