Topic: - q0 Switch with LAME 3.97b2 problem solved ? ! (Read 16817 times) previous topic - next topic
--abr 8 and -V0 ? i would say that should obey -V 0 and forget about --abr 8.. (at least it used to be the case with contradictory options).
Anyway, my point was that the Quality entry in the LAME tag was something that was added way back, and that hasn't been reviewed in quite some time. It also used to show values of ~60  for -V 2 , when some comparable CBR option had higher values. It it written by the encoder, and depends on the internal options that the encoder uses ( ath, lowpass filter... etc..)
that is:  -V 0 --vbr-new -m s -b 320
Tag revision:        0
Version string:      3.97b
Quality:            97 (V0 and q3)
Encoding method:    cbr
Lowpass:            20,500Hz
RG track peak:      <not stored>
RG track gain:      -5.1dB (determined automatically)
RG album gain:      <not stored>
nspsytune:          yes
nssafejoint:        yes
nogap continued:    no
nogap continuation:  no
ATH type:            4
Bitrate:            255 or higher
Encoder delay:      576 samples
Padded at end:      2,184 samples
Noise shaping:      1
Stereo mode:        stereo
Unwise settings:    no
Source sample freq:  44.1kHz
MP3Gain change:      <none>
Preset:              cbr 320
Surround info:      none
Music length:        5,512,880 bytes
Music CRC:          5462
Actual Music CRC:    5462
Info tag CRC:        0EF8
Actual Info Tag CRC: 0EF8
Would anyone has the abilty to check which method is better? or is there any automatic electronic way to compare tracks?
-V 0 --vbr-new  -b 320
or: -V 0 --vbr-new
or: -b320
thanks
This must be the weirdest nuttiest thread I've ever read...
//From the barren lands of the Northsmen
Info to yes10: The quality score stored in the Lame tag (like "97") has NOTHING WHATSOEVER to do with audio quality, it just indicates which encoding mode (VBR, ABR, CBR, q level) was used. A higher number DOES NOT MEAN higher quality. -B 320 offers the highest quality possible, plain and simple.
Proverb for Paranoids: "If they can get you asking the wrong questions, they don't have to worry about answers."
-T. Pynchon (Gravity's Rainbow)
thank you all for the information.
