I got the follow crash 2 times in the last half hour. Since nothing has changed in my configuration except the new version, I suspect it is related (and also because of the 'foobar2000_get_interface' in the crash log). I use Windows Vista RC2.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 779218D3h
Access violation, operation: write, address: 00000014h
Call path:
Code bytes (779218D3h):
77921893h: C0 89 4D F0 0F 84 37 88 FD FF 8B 4E 04 F6 C1 01
779218A3h: 8D 7E 04 0F 85 CF C6 00 00 8B 55 0C 90 8B C1 2B
779218B3h: C2 8B D8 8B C1 F0 0F B1 1F 3B C1 0F 85 A8 C6 00
779218C3h: 00 33 C0 89 45 0C 89 45 08 8B 06 83 F8 FF 74 04
779218D3h: 83 40 14 01 8B 5D F4 8B 7D F0 90 80 3D 82 03 FE
779218E3h: 7F 00 0F 85 9B C6 00 00 8B 45 FC 83 F8 FF 57 6A
779218F3h: 00 0F 84 F1 C6 00 00 50 E8 C0 C3 FF FF 3D 02 01
77921903h: 00 00 0F 84 F1 C6 00 00 85 C0 0F 8C 87 C7 00 00
Stack (0635FE04h):
0635FDE4h: 00000000 00000000 00000000 00000000
0635FDF4h: 00000000 00000000 00000000 00000000
0635FE04h: 01320D50 01320D54 00000000 00000010
0635FE14h: 01320CF8 003DE0F8 004DE4B8 00000002
0635FE24h: 011B2548 00000002 0635FE50 C0000008
0635FE34h: FFFFFFFF 00000002 0635FDD4 00000000
0635FE44h: 00000000 00000000 7FFDC000 0000011C
0635FE54h: 0635FE7C 7792181B 00000000 00000000
0635FE64h: 00000000 00000010 01320CF8 00000004
0635FE74h: 00000000 00000001 0635FEE0 003DC5AD
0635FE84h: 01320D50 1315F065 00000000 00000000
0635FE94h: 01322320 00000000 00004B4F 00000052
0635FEA4h: 01320178 00000000 00000002 0000000F
0635FEB4h: 01320148 00000000 013222B0 01322760
0635FEC4h: 00000000 00000000 00000000 0635FE88
0635FED4h: 0635FF88 003F0178 FFFFFFFF 0635FF50
0635FEE4h: 778D6396 00000118 0000011C 0635FE68
0635FEF4h: 01320CF8 00000035 00322320 00000035
0635FF04h: 003F90A8 504F5453 663D6320 000A6F6F
0635FF14h: 01320000 0000000B 0000000F 0635FF60
Registers:
EAX: 00000000, EBX: FFFFFFFC, ECX: 00000000, EDX: 00000004
ESI: 01320D50, EDI: 01320D54, EBP: 0635FE54, ESP: 0635FE04
Crash location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlTimeFieldsToTime" (+000002DCh)
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 778C0000h - 779DD000h
kernel32 loaded at 77320000h - 773F8000h
COMCTL32 loaded at 74F30000h - 750C5000h
msvcrt loaded at 77400000h - 774AA000h
ADVAPI32 loaded at 77260000h - 7731F000h
RPCRT4 loaded at 76220000h - 762E3000h
GDI32 loaded at 762F0000h - 7633B000h
USER32 loaded at 76180000h - 7621E000h
SHLWAPI loaded at 77A80000h - 77AD5000h
SHELL32 loaded at 76690000h - 7715B000h
ole32 loaded at 77770000h - 778B4000h
shared loaded at 10000000h - 1002A000h
comdlg32 loaded at 771E0000h - 77254000h
IMM32 loaded at 77AE0000h - 77AFE000h
MSCTF loaded at 763D0000h - 76498000h
LPK loaded at 779F0000h - 779F9000h
USP10 loaded at 77A00000h - 77A7D000h
uxtheme loaded at 75190000h - 751CF000h
foo_albumlist loaded at 00500000h - 00547000h
OLEAUT32 loaded at 76340000h - 763CD000h
foo_audioscrobbler loaded at 003D0000h - 00400000h
WS2_32 loaded at 76600000h - 7662D000h
NSI loaded at 76680000h - 76686000h
foo_autoplaylist loaded at 00550000h - 00580000h
foo_cdda loaded at 012B0000h - 012E6000h
foo_converter loaded at 013A0000h - 01409000h
foo_dsp_std loaded at 01330000h - 01371000h
foo_freedb2 loaded at 01410000h - 01450000h
foo_infobox loaded at 01450000h - 01490000h
foo_input_shorten loaded at 014E0000h - 0150E000h
foo_input_std loaded at 01510000h - 01624000h
foo_masstag loaded at 01650000h - 016A0000h
foo_run loaded at 016A0000h - 016CB000h
foo_uie_albumart loaded at 01730000h - 01767000h
gdiplus loaded at 74830000h - 749DA000h
foo_uie_quicksearch loaded at 01770000h - 017B7000h
foo_uie_single_column_playlist loaded at 01820000h - 01873000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_uie_trackinfo_mod loaded at 01880000h - 018CE000h
foo_ui_columns loaded at 01A10000h - 01AA7000h
foo_ui_std loaded at 018D0000h - 01927000h
dciman32 loaded at 74360000h - 74366000h
PROPSYS loaded at 74730000h - 747E5000h
SETUPAPI loaded at 775E0000h - 77768000h
apphelp loaded at 75FB0000h - 75FDC000h
CLBCatQ loaded at 764A0000h - 76524000h
wpdshext loaded at 6BE50000h - 6C0BE000h
WINMM loaded at 72190000h - 721C3000h
OLEACC loaded at 74A10000h - 74A49000h
shdocvw loaded at 72F00000h - 73007000h
ieframe loaded at 71170000h - 71738000h
PSAPI loaded at 760E0000h - 760E6000h
iertutil loaded at 76630000h - 76675000h
USERENV loaded at 76030000h - 7604E000h
Secur32 loaded at 76010000h - 76024000h
urlmon loaded at 774B0000h - 775D3000h
NLAapi loaded at 749E0000h - 749EF000h
IPHLPAPI loaded at 75A20000h - 75A39000h
dhcpcsvc loaded at 759E0000h - 75A14000h
DNSAPI loaded at 75C60000h - 75C8B000h
WINNSI loaded at 759D0000h - 759D7000h
dhcpcsvc6 loaded at 759B0000h - 759D0000h
mswsock loaded at 757E0000h - 7581B000h
winrnr loaded at 726F0000h - 726F8000h
WLDAP32 loaded at 77160000h - 771A9000h
napinsp loaded at 72630000h - 7263F000h
pnrpnsp loaded at 724B0000h - 724C2000h
wshbth loaded at 72620000h - 7262C000h
rasadhlp loaded at 751E0000h - 751E6000h
DSOUND loaded at 6F340000h - 6F3B1000h
POWRPROF loaded at 754D0000h - 754EA000h
MMDevApi loaded at 74700000h - 74727000h
WINTRUST loaded at 752D0000h - 752FD000h
CRYPT32 loaded at 75AD0000h - 75BC1000h
MSASN1 loaded at 75C20000h - 75C32000h
imagehlp loaded at 771B0000h - 771D9000h
audioses loaded at 704F0000h - 70511000h
audioeng loaded at 70150000h - 701B7000h
AVRT loaded at 74A00000h - 74A07000h
rsaenh loaded at 75570000h - 755A8000h
mlang loaded at 6F230000h - 6F260000h
dbghelp loaded at 72010000h - 720EC000h
Stack dump analysis:
Address: 003DE0F8h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00009948h)
Address: 004DE4B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7792181Bh, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlTimeFieldsToTime" (+00000224h)
Address: 003DC5ADh, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00007DFDh)
Address: 003F0178h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0001B9C8h)
Address: 778D6396h, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlGetLongestNtPathLength" (+00000056h)
Address: 003DE3F3h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00009C43h)
Address: 003DC8C9h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00008119h)
Address: 003DFE0Ah, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0000B65Ah)
Address: 003E49C0h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+00010210h)
Address: 003DFEAFh, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0000B6FFh)
Address: 7735C71Ch, location: "kernel32", loaded at 77320000h - 773F8000h
Symbol: "BaseThreadInitThunk" (+00000012h)
Address: 778EE2CFh, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlIsCurrentThreadAttachExempt" (+00000042h)
Address: 778EF0DDh, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlLCIDToCultureName" (+00000310h)
Address: 003DFE30h, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0000B680h)
Address: 00480020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 003D003Ch, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Address: 003F003Eh, location: "foo_audioscrobbler", loaded at 003D0000h - 00400000h
Symbol: "foobar2000_get_interface" (+0001B88Eh)
Address: 00410040h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430042h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00450044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00470046h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B004Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F004Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00510050h, location: "foo_albumlist", loaded at 00500000h - 00547000h
Symbol: "foobar2000_get_interface" (+00005700h)
Address: 00530052h, location: "foo_albumlist", loaded at 00500000h - 00547000h
Symbol: "foobar2000_get_interface" (+00025702h)
Address: 00550054h, location: "foo_autoplaylist", loaded at 00550000h - 00580000h
Address: 00570056h, location: "foo_autoplaylist", loaded at 00550000h - 00580000h
Symbol: "foobar2000_get_interface" (+0001B436h)
Address: 0192201Ah, location: "foo_ui_std", loaded at 018D0000h - 01927000h
Symbol: "foobar2000_get_interface" (+0003BA2Ah)
Address: 0178017Eh, location: "foo_uie_quicksearch", loaded at 01770000h - 017B7000h
Symbol: "foobar2000_get_interface" (+0000D7AEh)
Address: 00500060h, location: "foo_albumlist", loaded at 00500000h - 00547000h
Address: 778CFF20h, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "RtlFindAceByType" (+00000A98h)
Address: 7799271Ah, location: "ntdll", loaded at 778C0000h - 779DD000h
Symbol: "fltused" (+000093EAh)
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Autoplaylist Manager 1.0 (foo_autoplaylist)
Run services 0.3.2 (foo_run)
Shorten decoder 0.4.2a (foo_input_shorten)
CD Audio Decoder 2.1.1 (foo_cdda)
Album Art Panel 0.2.5.1 (foo_uie_albumart)
Masstagger 1.6 (foo_masstag)
Columns UI 0.1.3 beta 1v6 TEST (foo_ui_columns)
Track info panel mod 0.6 beta [Oct 12 2006 - 10:42:55] (foo_uie_trackinfo_mod)
FLAC Decoder 1.1.0 (foo_input_std)
freedb Tagger 0.5.2a (foo_freedb2)
Converter 1.0.1 (foo_converter)
Standard Input Array 1.0 (foo_input_std)
Album List 3.2.0 (foo_albumlist)
Default User Interface 0.9acc (foo_ui_std)
Quick Search Toolbar 2.8j (foo_uie_quicksearch)
WMA Decoder 1.1 (foo_input_std)
Single Column Playlist Display 0.3.2 beta [Oct 16 2006 - 12:21:19] (foo_uie_single_column_playlist)
Standard DSP array 1.0 (foo_dsp_std)
Special file info box 2.0.4 (foo_infobox)
Audioscrobbler 2.1 (foo_audioscrobbler)
foobar2000 core v0.9.4.1 (Core)
