Topic: Home stereo display (Read 272526 times) previous topic - next topic
Home stereo display
Reply #225
2 - Option to display the last played date as the number of days ago, rather than the actual date. Perhaps the YY_MM_DD variable could be extended to allow you to choose from YY-MM-DD, YY.MM.DD, or xx Days Ago.
Yes,i thought about it (already reserved the space for this feature) That's where your plugin will come into
full action.On this note do you plan to add %cwb_next_title% support for shuffled playlist? I've already written
the next track part of the code but haven't included it in the current version b/c it's only capable to correctly
display the next track from the "default" playback order.I would love to see it working with shuffle too.
As for your first request i'll add it in the following versions.
Favourite artist:CD-R
Favourite album:700MB
Home stereo display
Reply #226
I don't know if it is technically possible to get the next track that will play when you are in shuffle mode.  I've looked in the SDK for a way to determine it, but I cannot find anything.  So if anyone reading this is familiar with the SDK and knows a way to do this, please let me know.
%cwb_next_title% should currently work with default playback order or with queued files.
Thanks for listening to the requests.
There used to be a link to my website here.
Home stereo display
Reply #227
How about centering the track artist/title info when it doesn't need to be scrolled?
And being able to change the left and top padding using customizable variables, so you can shift all the text/info up/down/left/right?
They're the only 2 things that could make this better IMO.
Home stereo display
Reply #228
thank you
Home stereo display
Reply #229
Hey Russell,
With the new beta, it doesn't properly display "VBR" for MP3 files.  It would appear that there is no %__extrainfo% field now with the new detction of MP3 tech fields.
Home stereo display
Reply #230
Following along with what you suggested - perhaps a variable could be defined at the top which would allow the user to change the alignment of everything in the trackinfo panel at once.  Like, Left / Center / Right alignments.  This would allow for users running at high resolutions with really large foobar windows (like myself) to be a little more creative in placing this into their configurations.
You've done some awesome work on this thing, Russel!  It's really amazing what you've done with the tools available!
Home stereo display
Reply #232
Hey Russell,
Yes i can confirm,the %_extrainfo% field had been removed,so from now on i'll have to support  both 0.9.3 and
0.9.4 fields,i'll release an update later today.The o.9.4 version also gives more info about the codec and bitrate type,i'll add this info too.
If you encounter some more strange things under 0.9.4 please post.Note that the 0.9.3 version will be fully supported by the update.
Home stereo display
Reply #234
i cant get my background to work. everythign else is fine, but i have no back grounds, only solid colour. I appologise if its been mentioned before, but does anybody know what my problem is?
cheers
Home stereo display
Reply #235
cheers
Have you followed the instructions in the readme?
Do you have the images in the images directory that must be located in your foobar's profile directory (where's your foobar.cfg file is located) (....\foobar2000\images\ or ..application data\foobar2000\images\ -depends on user profile support).
Home stereo display
Reply #236
VERSION 1.7.2 is out (see the first post)
Now the main purpose of this version is to provide compatibility with the new Foobar 0.9.4 beta.
I've added some features,along with a couple of your requests,but many more requests has been left
for later versions as i was restricted in time to release the compatibility update.This version tested
to run with both v0.9.3.1 and v0.9.4 b1.
Home stereo display
Reply #237
Hey Russell, this looks great.  I did notice though that on FLAC files, it is showing the files both "LOSSLESS" and "CBR".  Should it be doing this?
Home stereo display
Reply #238
Nice updates
I think it'd be better if the first/last played bits were swapped around (so the date section under rating shows firstplayed, and the text at bottom shows last played). IMO, it makes more sense to have the last played info in text, where it stands out more. Or give an option to swap them round?
Also it would be good if you moved the artist/title string up to the top, so we could change it without having to search through the whole code.
Another idea would be to add something like ' *** ' to the end on the title string when it is being scrolled forwards only, and then making it continuously scroll through, so the string would keep getting added onto the end, and keep looping. Don't know if that could actually be done, but might be good.
Anyway, glad you keep working on this..
Home stereo display
Reply #239
I was playing a song before that had a question mark in it and the whole line of info disappeared from track info. Is this supposed to happen??
Home stereo display
Reply #240
I have a problem with the 1.7.2 version. 1.7.1 worked fine but now this is somehow messed up.
Like this. What are those ////////'s on the background?
And I'm using the latest beta. 0.9.4 beta 1
~JzE
Home stereo display
Reply #241
~JzE
It's obviously one of the code parts separator that got messed up while copying the code from the txt file.
Try to reduce the font size in the txt file and re paste it.If it doesnt work for you,you'll have to go through the code and manualy delete all the separators,till it's all good again ("//////").I used arial 10 pt font
while making the code txt file,so no problems with it from my side,if your font is bigger sized you can get
some long lines "cut off",and thats what's causing the problem.
No it's my fault,probably messed things up while making the bitrate mode recognition compatible with
fb2k 0.9.4b .Sorry for that i'll fix it.
Ok,it will be switchable.
I've tried to make the auto font recognition better but probably it came out worse,i'll check it
and if so,I'll fix it.
It's called "cycle" scrolling,and i'm planning to add it at some stage.
To everybody:i get alot of requests,but you sure understand that it's impossible to add all these,
that some other people might not like,so i'll need more than a single request to add something.
Home stereo display
Reply #242
How do you fix the NF for the playback? I have all the right fonts installed
Home stereo display
Reply #243
It's should be displayed using "wingdings 3" font,check if you have it installed on your system.
Home stereo display
Reply #244
Ah.. Yep. The code was messed up somehow, but repasting worked. (I wonder why I didn't try it myself first =/) But thanks
~JzE
Home stereo display
Reply #246
I've got a problem. The code says that the song was played 6 days ago, but the it was played 2 days ago! How can i fix it?
Home stereo display
Reply #247
can you send me your file for examination?
Home stereo display
Reply #248
you mean the code?
here it is
/////////////////////////////////////////Definitions///////////////////////////////////////////////////
$puts(Theme,space)
$puts(removable,FGH)
$puts(glass_intensity,10)
$puts(back,$rgb(100,100,100))
$puts(active,$rgb(250,250,250))
$puts(center,1)
$puts(display_back,1)
$puts(full,null)
$puts(frame,null)
$puts(decreaserange,15)
$puts(YY_MM_DD,)
$puts(first_played,1)
$puts(alt_font,)
$puts(alt_font_size,)
$puts(alt_font_options,)
$puts(symbolinfo,1)
$puts(scrollback,1)
$puts(window,65)
$puts(size,24)
//////////////////////////////////////////THEMES//////////////////////////////////////////////////
$if($stricmp($get(Theme),space),
$puts(font_options,)
$puts(display_back,)
$puts(full,null)
$puts(frame,100-100-100)
$imageabs(0,0,images\star.png,)
//THEME VISTA INSPIRAT BY PINGWINHO
//FOR HOME STEREO DISPLAY BY RUSSELL777
$if($stricmp($get(Theme),Vista Inspirat),
$puts(back,$rgb(94,105,10))
$puts(active,$rgb(44,46,61))
$puts(full,132-152-16 )
$puts(frame,102-132-0)
$imageabs(0,0,images\grass.png,)
$if($stricmp($get(Theme),stardust),
$puts(back,$rgb(50,50,100))
$puts(active,$rgb(200,200,250))
$puts(font_options,glow-50-50-100 glowalpha-100)
$puts(full, alpha-100)
$puts(frame,null)
$imageabs(-20,-27,images\stardust.png,)
//  LAVA-theme by Sw!ng
// For Russell777's HOME STEREO DISPLAY.
// Enjoy !!
$if($stricmp($get(Theme),Lava),
$puts(back,$rgb(0,0,0))
$puts(active,$rgb(250,0,0))
$puts(full,)
$puts(frame,0-0-0 alpha-100)
$imageabs(-210,$sub($mul($mod(%_time_elapsed_seconds%,60),-8),80),images\RedLava.png,)
//////////////////////////////////////TIME Sequence//////////////////////////////////////////////
$if(%isplaying%,$puts(active,$get(active)),$puts(active,$get(back))
$puts(font_options,)$puts(display_back,1))
$if($or($get(full),$get(frame)),
$drawrect(7,$sub($div(%_height%,5),7),39,29,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(48,$sub($div(%_height%,5),7),30,29,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(175,$add($div(%_height%,5),10),41,12,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(79,$sub($div(%_height%,5),7),91,29,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(175,$sub($div(%_height%,5),7),41,15,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(221,$sub($div(%_height%,5),7),166,29,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(388,$sub($div(%_height%,5),7),120,29,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(509,$sub($div(%_height%,5),18),25,40,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(7,$add($div(%_height%,5),25),527,15,brushcolor-$get(full) pencolor-$get(frame))
$if($get(first_played),
$drawrect(276,$add($div(%_height%,5),43),232,15,brushcolor-$get(full) pencolor-$get(frame))
$drawrect(509,$add($div(%_height%,5),43),25,15,brushcolor-$get(full) pencolor-$get(frame))))
$if($stricmp($get(alt_font),),$puts(alt_font,arial))
$if($stricmp($get(alt_font_size),),$puts(alt_font_size,11))
$puts(min,$div( %playback_time_seconds%,60))
$if($stricmp($len($get(min)),1),$puts(min,0$get(min)))
$puts(sec,$mod( %playback_time_seconds%,60))
$if($stricmp($len($get(sec)),1),$puts(sec,0$get(sec)))
$puts(time,$get(min):$get(sec))
$if(%_time_total%,
$puts(total,$num($div( %length_seconds%,60),2):
$num($mod( %length_seconds%,60),2))
,$puts(total,__:__))
$font(7 Segment,$get(size),$get(font_options),250-250-250)
$puts(1,$substr($get(time),1,1))
$puts(2,$substr($get(time),2,2))
$puts(4,$substr($get(time),4,4))
$puts(5,$substr($get(time),5,5))
$puts(6,$substr(%tracknumber%,1,1))
$puts(7,$substr(%tracknumber%,2,2))
$puts(8,$substr($get(total),1,1))
$puts(9,$substr($get(total),2,2))
$puts(10,$substr($get(total),4,4))
$puts(11,$substr($get(total),5,5))
$puts(s,$calcwidth($get(1)))
$puts(s1,$calcwidth()
$if($stricmp($get(1),7),$puts(f1,2),)
$if($stricmp($get(2),7),$puts(f2,2),)
$if($stricmp($get(5),7),$puts(f5,3),)
$if($stricmp($get(6),7),$puts(f6,3),)
$if($stricmp($get(7),7),$puts(f7,3),)
$if($stricmp($get(8),7),$puts(f8,3),)
$if($stricmp($get(9),7),$puts(f9,3),)
$if($stricmp($get(10),7),$puts(f10,3),)
$if($stricmp($get(11),7),$puts(f11,2),)
$alignabs(91,$div(%_height%,5),%_width%,%_height%,,)$get(back)
$if($get(display_back),$char(56)$char(56):$char(56)$char(56),)
$alignabs($add(91,$get(f1)),$div(%_height%,5),%_width%,%_height%,,)
$get(active)$get(1)
$alignabs($add(91,$get(f2),$mul($get(s),1)),$div(%_height%,5),
$get(active)$get(2):
$alignabs($add(92,$get(f4),$mul($get(s),2),$get(s1)),$div(%_height%,5),
$get(active)$get(4)
$alignabs($add(92,$get(f5),$mul($get(s),3),$get(s1)),$div(%_height%,5)
$get(active)$get(5)
//////////////////////////////////////////Source////////////////////////////////////////////////////
$puts(str,1)
$alignabs(21,$add($div(%_height%,5),57),%_width%,%_height%,,)
$font(arial,6,bolditalic$get(font_options),250-250-250)
#LINEHEIGHT,9#
$if($stricmp(ftp,$substr(%path%,1,3)),$get(active),$get(back))NET DRIVE
$char(32)$char(32)
$if($stricmp(\,$substr(%path%,1,1)),$get(active),$get(back))REMOTE PC
$char(32)$char(32)
$if($stricmp($substr(%path%,1,4),http),$get(active)STREAMING$puts(str,),
$get(back)STREAMING)$char(32)$char(32)
$if($or($not($stricmp($strchr($get(removable),$substr(%path%,1,1)),0)),
$stricmp(%codec%,CDDA)),$get(active)REMOVABLE,
$get(back)REMOVABLE)$char(32)$char(32)
$if($and($stricmp($strchr($get(removable),$substr(%path%,1,1)),0),
$stricmp($stricmp(\,$substr(%path%,1,1)),),$stricmp($stricmp(ftp,$substr(%path%,1,3)),),
$not($stricmp(%codec%,CDDA)),$not($stricmp($substr(%path%,1,4),http))),
$get(active)LOCAL DRIVE,$get(back)LOCAL DRIVE)
/////////////////////////Stereo Encoding Tagtype RG///////////////////////////////////////
$alignabs(21,$div(%_height%,50),%_width%,%_height%,,)
#LINEHEIGHT,4#$char(32)$char(10)
$font(arial,7,bolditalic$get(font_options),250-250-250)
$if($stricmp(%channels%,8ch),$get(active),$get(back))7.1
$if($stricmp(%channels%,7ch),$get(active),$get(back))$char(32)6.1
$if($stricmp(%channels%,6ch),$get(active),$get(back))$char(32)5.1$char(32)
$if($stricmp(%__mp3_stereo_mode%,JOINT STEREO),$get(active)JOINT STEREO
$get(back)$char(32)MONO,
$if($stricmp(%channels%,stereo),$get(back)JOINT $get(active)STEREO
$get(back)JOINT STEREO
$if($stricmp(%channels%,MONO),$get(active)$char(32)MONO,
$get(back)$char(32)MONO)))
$if($stricmp($info(encoding),lossy),$get(active) LOSSY$get(back) LOSSLESS,
$get(back) LOSSY$get(active) LOSSLESS)
$if($or($stricmp(%codec_profile%,CBR),
$and($stricmp($info(extrainfo),),$stricmp(%codec_profile%,?)),
$stricmp($info(encoding),lossless),$stricmp(%codec%,wma)),
$get(active),$get(back)) CBR
$if($or($stricmp(%codec%,musepack),$and($stricmp(%codec%,aac),$get(str)),
$info(extrainfo),$strstr(%codec_profile%,VBR)),$get(active),$get(back)) VBR
$if($stricmp(%codec%,vorbis),$get(active),$get(back)) ABR
$if($strstr($info(tagtype),id3v1),$get(active),$get(back)) ID3V1
$if($strstr($info(tagtype),id3v2),$get(active),$get(back)) ID3V2
$if($strstr($info(tagtype),apev2),$get(active),$get(back)) APEV2
$if($stricmp(%codec%,vorbis),$get(active),$get(back)) VC
$if($stricmp(%codec%,flac),$get(active),$get(back)) FLAC
$if($or( %__replaygain_album_gain%,%__replaygain_track_gain%)
,$get(active),$get(back)) R-GAINED
////////////////////////////////Play pause tracknumber//////////////////////////////////////////
$alignabs(193,$add($div(%_height%,5),1),%_width%,%_height%,,)
#LINEHEIGHT,16#$char(32)$char(10)
$font(webdings,10,$get(font_options),250-250-250)
$if(%ispaused%,$get(active),$get(back))$char(59)
$font(arial,9,$get(font_options),250-250-250)
$if($not(%ispaused%),$get(active),$get(back))$char(9658)
$alignabs(21,$div(%_height%,5),%_width%,%_height%,,)
$if($get(display_back),$get(back)$char(56)$char(56),)
$alignabs($add(21,$get(f6)),$div(%_height%,5),%_width%,%_height%,,)
$get(active)$get(6)
$alignabs($add(21,$get(f7),$get(s)),$div(%_height%,5),%_width%,%_height%,,)
$get(active)$get(7)
//////////////////////////////////////////Time total //////////////////////////////////////////////
$alignabs(188,$div(%_height%,5),%_width%,%_height%,,)
$font(7 segment,11,$get(font_options),250-250-250)
$puts(s2,$calcwidth($get(8)))
$puts(s3,$calcwidth()
#LINEHEIGHT,3#$char(32)$char(10)
$if($get(display_back),$get(back)$char(56)$char(56):$char(56)$char(56),)
$alignabs($add(188,$get(f8)),$div(%_height%,5),%_width%,%_height%,,)
$get(active)$get(8)
$alignabs($add(188,$get(s2),$get(f9)),$div(%_height%,5),
$get(active)$get(9):
$alignabs($add(188,$mul($get(s2),2),$get(s3)),$div(%_height%,5),
$get(active)$get(10)
$alignabs($add(188,$get(s3),$mul($get(s2),3),$get(f11)),
$get(active)$get(11)
///////////////////////////////Bitrate Samplerate Compression/////////////////////////////////
$alignabs(237,$div(%_height%,5),%_width%,%_height%,,)
$font(7 segment,10,$get(font_options),250-250-250)
$get(active)[%bitrate%]
$alignabs(265,$div(%_height%,5),%_width%,%_height%,,)
$font(arial,7,$get(font_options),250-250-250)$get(active)Kb/s
$get(active)$char(32)[%samplerate%]
$alignabs(329,$div(%_height%,5),%_width%,%_height%,,)
#LINEHEIGHT,19#$char(32)$char(10)
$font(arial,7,$get(font_options),250-250-250)$get(active) Hz
$alignabs(354,$div(%_height%,5),%_width%,%_height%,,)
#LINEHEIGHT,2#$char(32)$char(10)
$puts(show,$num($muldiv(1000,$info(bitrate),1411),3))
$if(%isplaying%,$if($stricmp($get(show),1000),
$font(lcd2,9,bold,250-250-250)$repeat($char(10),8)$get(active)ucm$puts(flag2,1),
$get(active)$repeat($char(10),7)$substr($get(show),1,2)
'.'$substr($get(show),3,3)))
$alignabs(383,$div(%_height%,5),%_width%,%_height%,,)
$font(arial,7,$get(font_options),)$if($get(flag2),$get(back),$get(active))'%'
//////////////////////////////////Rating FP Play count//////////////////////////////////////////
$if(%rating%,$puts(rating,%rating%),
$puts(fix,$div($cwb_datediff(%cwb_systemdatetime%,%first_played%),
$get(decreaserange)))
$puts(rating,$sub($add(%play_count%,%play_counter%),$get(fix))))
$if($greater($get(rating),5),$puts(rating,5))
$if($greater(0,$get(rating)),$puts(rating,0))
$alignabs(403,$div(%_height%,5),%_width%,%_height%,,)
$font(wingdings,12,$get(font_options),250-250-250)
$get(active)$repeat($char(171),$get(rating))
$get(back)$repeat($char(171),$sub(5,$get(rating)))
#LINEHEIGHT,13#$char(32)$char(10)
$get(active)$if(%last_played%,$if($get(YY_MM_DD),
[$substr(%last_played%,1,4).$substr(%last_played%,6,7).$substr(%last_played%,9,10)],
[$substr(%last_played%,9,10).$substr(%last_played%,6,7).]
$substr(%last_played%,1,4)),..........)
$alignabs(469,$div(%_height%,5),%_width%,%_height%,,)
$font(7 segment,10,$get(font_options),250-250-250)$get(active)
$repeat($char(32),3)$num($add(%play_count%,%play_counter%),3)
$alignabs(479,$div(%_height%,5),%_width%,%_height%,,)
#LINEHEIGHT,17#$char(32)$char(10)
$font(arial,7,$get(font_options),250-250-250)$get(active)'('$repeat($char(32),10)')'
$alignabs(483,$add($div(%_height%,5),19),%_width%,%_height%,,)
$font(arial,7,$get(font_options),250-250-250)$get(active)'x'
//////////////////////////////////////////Codec///////////////////////////////////////////////////
$font(lcd2,10,bold$get(font_options),250-250-250)
#LINEHEIGHT,5#$char(32)$char(10)
$get(active)$if($stricmp($substr(%codec%,1,7),windows),WMA,
$if($strstr($info(tool),LAME),lame mp3,$lower(%codec%)))
////////////////////////////////////////Track info///////////////////////////////////////////////
$puts(title,
['"'%title%'"'][ - %artist%]['/'%album%] ['('%date%')'])
#LINEHEIGHT,1#$char(32)$char(10)
$if($get(symbolinfo),
$if($or($stricmp($substr($ascii($get(title)),2,2),?),
$stricmp($substr($ascii($get(title)),6,6),?)),$char(10)
$font($get(alt_font),$get(alt_font_size),$get(alt_font_options)$get(font_options)
,250-250-250)$repeat($char(10),32),
$puts(title,
$lower($replace($upper($get(title)),-,$char(8208),&,+,À,a,Á,a,Â,a,Ã,a,Ä,ae,Å,a,
Æ,ae,Ç,c,È,e,É,e,Ê,e,Ë,e,Ì,i,Í,i,Î,i,Ï,i,Ò,o,Ó,o,Ô,o,Õ,o,Ö,oe,Ù,u,Ú,u,Û,u,Ü,ue,
ß,ss)))
$font(lcdmono2,11,bold$get(font_options),250-250-250)$repeat($char(10),35)),
$get(font_options),250-250-250)$repeat($char(10),32))$get(active)
$if($greater($len($get(title)),$get(window)),
$if($stricmp($mod($len($get(title)),2),1),
$puts(title,$pad($get(title),$add($len($get(title)),1))),)
$puts(shift,$sub($len($get(title)),$get(window)))
$if($get(scrollback),
$puts(mod,$mod(%_time_elapsed_seconds%,$add($mul($get(shift),2),2)))
$if($greater(3,$get(mod)),$substr($get(title),1,$get(window)),
$puts(mod,$sub($get(mod),2))$puts(flag,$get(mod))
$if($greater($add($get(shift),1),$get(mod)),
$substr($get(title),$add(1,$get(mod)),$add($get(window),$get(mod))),
$substr($get(title),$sub($mul($get(shift),2),$get(mod),-1),
$add($get(window),$sub($mul($get(shift),2),$get(mod),0))))),
$puts(mod,$mod(%_time_elapsed_seconds%,$add($get(shift),2)))
$substr($get(title),$add(1,$get(mod)),$add($get(window),$get(mod))))),
$alignabs(11,$add($div(%_height%,5),36),537,%_height%,
$if($get(center),center),top)
$get(active)$get(title))
$font(arial,8,$get(font_options),250-250-250)
$alignabs(520,$add($div(%_height%,5),20),%_width%,%_height%,,)
#LINEHEIGHT,34#$char(32)$char(10)
$if($greater($get(flag),0),$get(active),$get(back))$char(9668)$char(32)
$if($or($greater($get(shift),$get(mod)),$greater($get(mod),$get(shift))),
$get(active),$get(back)),
$if($greater($get(shift),$add($get(mod),1)),$get(active),$get(back)))$char(9658)
//////////////////////////////////////Progress Bar/////////////////////////////////////////////
$font(lcd2,15,$get(font_options),250-250-250)
$puts(symbol,_)
$alignabs(522,$sub($div(%_height%,5),21),%_width%,%_height%,,)
#LINEHEIGHT,3#
$puts(percent,$num($muldiv(%_time_elapsed_seconds%,100,
%_time_total_seconds%),3))
$if($stricmp($substr($get(percent),1,1),0),$puts(back1,$get(back))
$puts(percent,$char(32)$substr($get(percent),2,3))
,$puts(back1,$get(active)))
$repeat($get(back1)$get(symbol)$char(10),$sub(9,$substr($get(percent),2,2)))
$get(active)$repeat($get(symbol)$char(10),$substr($get(percent),2,2))
$alignabs(532,$sub($div(%_height%,5),21),%_width%,%_height%,,)
#LINEHEIGHT,3#
$repeat($get(back1)$get(symbol)$char(10),$sub(9,$substr($get(percent),3,3)))
$get(active)$repeat($get(symbol)$char(10),$substr($get(percent),3,3))
$alignabs(519,$sub($div(%_height%,5),2),%_width%,%_height%,,)
#LINEHEIGHT,22#$char(32)$char(10)
$font(7 Segment,8,$get(font_options),250-250-250)
$if($and(%isplaying%,%_time_total%),
$get(active)$get(percent),$get(active)$char(32)0)
$alignabs(532,$sub($div(%_height%,5),1),%_width%,%_height%,,)
$font(arial,6,$get(font_options),250-250-250)$get(active) '%'
/////////////////////////////////////Relative quality///////////////////////////////////////////////
$if($stricmp(%codec%,mp3),$puts(range,264)$puts(lb,56))
$if($stricmp(%codec%,musepack),$puts(range,320)$puts(lb,30))
$if($stricmp(%codec%,vorbis),$puts(range,455)$puts(lb,45))
$if($or($stricmp($substr(%codec%,1,7),windows),
$stricmp(%codec%,wma)),$puts(range,452)$puts(lb,48))
$if($stricmp(%codec%,aac),$puts(range,385)$puts(lb,15))
$puts(quality,$muldiv($sub($info(bitrate),$get(lb)),100,$get(range)))
$alignabs(353,$add($div(%_height%,5),7),%_width%,%_height%,,)
$font(franklin gothic medium,5,$get(font_options),250-250-250)$get(active)
$if($and($stricmp($info(encoding),lossy),$get(lb)),
$repeat($char(9612),$div($get(quality),10))
$get(back)$repeat($char(9612),$sub(10,$div($get(quality),10))),
$get(active)$repeat($char(9612),10))
///////////////////////////////////////////Playback order////////////////////////////////////////
$alignabs(61,$add($div(%_height%,5),6),%_width%,%_height%,,)
$font(wingdings 3,9,,250-250-250)
#LINEHEIGHT,9#
$if($strstr(%cwb_playback_order%,Repeat),$get(active),$get(back))$char(78)
$if($strstr(%cwb_playback_order%,Shuffle),$get(active),$get(back))$char(70)$char(10)
$alignabs(60,$add($div(%_height%,5),21),%_width%,%_height%,,)
$font(lcdmono2,7,bold,250-250-250)$get(active)
$if($strstr(%cwb_playback_order%,Default),CONT.)
$if($strstr(%cwb_playback_order%,playlist), ALL)
$if($strstr(%cwb_playback_order%,track),track)
$if($strstr(%cwb_playback_order%,albums),album)
$if($strstr(%cwb_playback_order%,directories), dir)
//////////////////////////////////////////Date Range///////////////////////////////////////////////
$alignabs(290,$add($div(%_height%,5),56),222,%_height%,
$font(lcd2,9,bold,)$get(active)$puts(ago,1)
$if(%first_played%,
$puts(dtr,$cwb_datediff(%cwb_systemdatetime%,%first_played%))
$puts(years,$div($get(dtr),365))
$puts(rest,$mod($get(dtr),365))
$puts(month,$div($get(rest),30))
$puts(days,$mod($get(rest),30))
$if($greater($get(years),0),$get(years) year)
$if($greater($get(years),1),s)
$if($and($greater($get(month),0),$stricmp($get(days),0)), and)
$if($greater($get(month),0), $get(month) month)
$if($and($greater($get(days),0),$greater($add($get(years),$get(month)),0)), and)
$if($greater($get(days),1), $get(days) days,
$if($and($stricmp($get(days),1),$stricmp($add($get(years),$get(month)),0)), yesterday
$puts(ago,),
$if($and($stricmp($get(days),0),%first_played%,
$stricmp($add($get(years),$get(month)),0)), today$puts(ago,),
$if($and($stricmp($get(days),1),$greater($add($get(years),$get(month)),0)), 1 day)
)))$if($get(ago), ago),never ))
//////////////////////////////////////////Image//////////////////////////////////////////////////////
$imageabs(0,$sub($get(glass_intensity),20),images\glass.png,)
Home stereo display
Reply #249
 No i mean the file that had been played for the first time 2 days ago and shows up as 6
