Topic: Home stereo display (Read 272644 times) previous topic - next topic
Home stereo display
Reply #175
Arial Unicode MS, Franklin Gothic Medium, Lucida Sans Unicode, Webdings, and Wingdings are copyrighted fonts. If you got permission from the copyright holders to distribute them, you should include some proof of that in the archive.
The LCD font family by Samuel Reynolds may be redistributed only under the terms of the license that is included in the original font package.
I suggest you remove any copyrighted fonts for which you don't have permission to distribute from your package before you re-add the link to the first post.
Home stereo display
Reply #176
aye, Russell, PM me with new link when it's up and I'll mirror it for you again.
On a side note, how can I align the background image to the right more?
Home stereo display
Reply #177
$imageabs(0,0,%_width%,%_height%,)
See the red zero? If you put here a possitive value the image will move right,negative-left.
Favourite artist:CD-R
Favourite album:700MB
Home stereo display
Reply #178
Any chance of getting it to display ampersands (&)?  At least make it a plus (+) please?
Cheers
Home stereo display
Reply #180
I use version 1.6 of your script and
if play any *.dts file, i see this
Can you fix it please?
Home stereo display
Reply #181
Surely you can just link to the page with the LCD fonts on seeing as they'e are free afaik..?
It's just you're not allowed to put them in your zip file, but it should be OK to link to the original website.
Home stereo display
Reply #182
Great work, Rus!!! I simply love this trackinfo!!
But I've a problem with the fonts: the tracknumber, the encoding info and some other information aren't shown in stereo-like font. What can I do?
I'm tryin' to change the code, but i'm not so good
Please, help me!!!
(I've all the fonts, the last version of foobar2000 e trackinfo_mod.
Sorry for my bad english!!!)
EDIT: I Made It!!!!
Home stereo display
Reply #183
Hey Russell777,
I love this config for the track info panel mod.  One small issue is that the LCD font doesn't display characters with accents, such as "é".  I was looking around for a possible substitute font, and found this one, which says on the page that it is free for personal use.  It has characters with accents, so I thought it would be a good one to potentially use.
Home stereo display
Reply #184
I have tweaked Russel777's code a bit to suit my needs, primarily to allow for a full length horizontal display.  Essentially, I removed  the decreasing rating code, track number display, vertical progress bar, scrolling title display, and compression code. I then added mood display.  I then realigned all the text and then added a second panel for display of the title and a horizontal progress bar.
Home stereo display
Reply #186
Yeah, but look at the second marker. It says that DTS is uncompressed media.
Home stereo display
Reply #187
Hey Russell777 - Great work; thank you!
Would it be possible to add a "Network Drive" designation on the far left of the display (where it shows "Streaming" "Removable" and "Local Drive")?
Thanks,
~esa
Home stereo display
Reply #188
Thanks for this plugin, it's great.
A question: what does it use for the last played date thing? I'm using foo_playcount 1.0 and the playcount works but the last played date always just has _____. Thanks.
Home stereo display
Reply #189
Thanks For the great Work
Can you give me a tip on how i can get the fonts to work?
Unfortunatily i cannot change the font to any than the default
using foov 0.9.3.1
Home stereo display
Reply #190
Why does mine look like this? I've installed all of the LCD fonts and seeing as I'm running XP, I should have all of the other fonts, correct?
Home stereo display
Reply #191
Same here as well....
i cannot get any other fonts to work
Running Xp also
Home stereo display
Reply #192
The fonts aren't being distributed by the author of the plugin any more because he doesn't a have a license to redistribute them. You should have all the MS ones, you just need to download the LCD font family from here: http://www.spinwardstars.com/scrfonts/lcd.html and also 7 Segment from here: http://www.twyman.org.uk/Fonts/
Install them all then it will work.
Home stereo display
Reply #193
Thanks Works Like A charm
Home stereo display
Reply #194
Installed both sets of fonts and it still looks like this:
Home stereo display
Reply #195
Hello world! I'm back! New version is coming soon,any last minute wishes?
Home stereo display
Reply #197
converting german special characters (ä,ö,ü,ß) to to ae, oe, ue, ss. this way they can be used with the lcd-font.
thank you.
The font I found actually has those characters.  It is mentioned in this post.
Home stereo display
Reply #198
thank you.
Please,could you provide me with an example track that has those symbols? I need to test it first.
Version 1.7 is out (see the first post)
Home stereo display
Reply #199
Beautiful Work  I had too muck around with the padding to get the background boxes to align properly is this what what was supposed to happen?
Cheers
