Topic: .m4a in WMP 11 (Read 5534 times) previous topic - next topic
.m4a in WMP 11
I generally use foobar for my audio playback, but I can't sleep so I started messing around with WMP 11 for fun. Most of my audio collection is in .m4a format that I ripped myself. By installing ffdshow I'm able to get WMP 11 to play mp4 files, but it won't seek. Any suggestions as to how to make this work? Or am I on a futile search?
edit: the seeking problem only happens with files if they are in the library - other files seek fine.
.m4a in WMP 11
Then don't add them to the library, problem solved
On a more serious note.. What mp4 parser filter are you using? (or does wmp11 actually natively support it?)
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
.m4a in WMP 11
I've got an aac parser, an mp4 splitter and an mp4 demuxer registered. I installed them a while back so I don't remember exactly, but they are probably from rarewares and the Guliverkli project at sourceforge.
.m4a in WMP 11
For the MP4 container (as well as for all Matroska, AVI and OGG/OGM ones) you can't go wrong with Haali Media Splitter :-) !
Get it here: http://haali.cs.msu.ru/mkv/!
All my DirectShow players work perfectly with it.
WavPack 5.7.0 -b384hx6cmv / qaac64 2.80 -V 100
.m4a in WMP 11
I can seek .M4A AAC files without issues, as well as reading the tags thanks to WMPTSE.  I'm not on my main box, but I think it's one supplied by Nero.
.m4a in WMP 11
Found this on SourceForge:
http://sourceforge.net/projects/wmptagext/
Installed that and the Haali splitter as well and no go. I'm going to try to try unregistering the other filters I have and see if that helps.
edit: Haali splitter is working with ffdshow to decode the .m4a files. The tags don't seem to be read even though I've got the tag support installed. And I still can't seek if the .m4a is in the library. :/
edit2: the files wouldn't play without an aac parser installed. Would a faulty parser affect seeking? And why would it only be ones in the library?
