Topic: foo_uie_queuemanager (Read 452268 times) previous topic - next topic
All those changes of the queue's default behaviour are hacks and it not possible to implement them in a "clean" way. They are quite likely to cause problems with other components.
For this reason I will leave the queue's behaviour as it is - it's peter's job to change that if his users demand that.
The more I think about it the more I agree.
I'll add some ideas for discussion in another thread at some day. I think the current queue behaviour is not very practical. Most likely we suffer from having fb2k jumping out of the current playlist... I think a queue manager should remember the starting playlist and position, follow the playlists when playing from the queue (if possible. trackinfo panels in follow cursor mode would refresh then...) and jump back to where it started (if possible), after the queue finished. Independent from the follow cursor/cursor follows playback mode. As simple.
extremely useful, thanks
Hello Chronial!
I found time to look into the paneled version and what should i say: Thanks! I enjoy!
I like your "play after current" feature and its option just to move and not to copy the track if it is in same playlist. You asked in the first post of this thread for better names for commands. I think "play after current" is not a good name for the command because of two reasons:
1. The name can provoke a misunderstanding as the command belongs to queuemanager: It doesn't express that the track is really inserted and not just played after the current one.
2. If your options are setted in that way that the queue is not cleared by using "play after current" then the track won't be played although the name of the command tells you so
What do you think about  "Place after current" for example? Place can mean both: Copied or moved (same playlist)
I'm don't like "play after current", too
The idea of using "place" sounds good. I guess I'll use something like "place after current playing" in the next version
Very useful. I still use the old version. I like it more than the panel-version.
Like Squeller, i dislike the current queue behaviour. After playing the queued tracks it should jump back to where ist started, how it was possible with the plugin foo_temple for 0.8x. I would love to see this as an option.
I'd have to store the current status every time a song is played and find out if that song is played from the queue or not (which is not possible - you could only check for numerous things and have a change to guess right). Well, it's easy to find out when the queue ends - but the queue "ends" before the last song is played. If I change to the pre-queue playlist when this song ends, I'd also stop you from starting another song and jump away. Then still it would ignore shuffle.
And all this would completely be messed up if another component tries something similar.
Short:
Feature request:
I would like to request context menu options for this component.  The current queue behavior suits my needs fine however if I would like to modify any of the queue entries it appears I can only do so from the keyboard. It would be nice if I could right click an entry and choose delete from the context menu.
Also please implement a refresh interval so that we can use queue index numbers in the display.
Reply #32
this should work in the current version (0.2.1). (use %list_index% and %list_total%)
Thanks, I need to start reading the first post more often for updates :)
This appears to work well except that %list_index% starts counting at 0 instead of 1.  But I can easily accomodate this with an $add(%list_index%,1).
Reply #34
Will be fixed in next version
Reply #35
Hello Chronial,
sorry, this part of my posting wasn't directed to you ... more to Peter
Your plugin is fantastic! Thank you
Reply #36
hi, i cant reorder the tracks in the queue, all that happens when i try to drag them around is that i select stuff.
using the latest version (0.2.1) and columns ui 0.1.3b
Nothing is so good that somebody, somewhere, will not hate it.
Reply #37
Why do you think this is possible? ^^.
It's on my todo list. But maybe you are abusing the queue - try using the "play after current" feature instead.
Reply #38
lol sorry. I blame the fever ;D
then it works like a charm
Reply #39
Will there be a non columns ui version, too?
EDIT: Oh I searched through the thread and found out that there won't be one. What a shame. Does anyone have a download link for the last non columns ui version?
EDIT2: Nevermind I found the old link: http://chron.visiondesigns.de/foobar2000/f...nager_0.1.1.zip
Reply #40
Was just going to post that link
but I can't assure you that this version si bug-free at all.
Reply #41
I have no idea how to use this. I imagine "queue" as the same principle from Winamp, using the "Play after current" operation, but nothing happens - Except the track is duplicated after the current one in the playlist (which is ugly!)
Reply #42
How about the "add to playback queue" operation?
Reply #43
Ah yes, I have this option, now after I've cleaned up in my components
Reply #44
Hello Chronial
When i want to insert the queue manager panel, in UI Column, aswell as in a Tab or a dockable panel (dockable panel just only to test because having the queue manager panel in a dockable panel would be a nonsense  )
my foobar crash.
I post here my failure report (but maybe the fault will be due to another component... Or due to myself : Am I suppose to deinstal foo_pqwiew and foo_queuemanager to use the panel version foo_ui_queuemanager ?) :
Illegal operation:
Code: E0434F4Dh, flags: 00000001h, address: 7C812A5Bh
Call path:
entry=>app_mainloop
Code bytes (7C812A5Bh):
7C812A1Bh:  8B 45 0C 56 8B 75 14 83 E0 01 85 F6 89 45 B4 C7
7C812A2Bh:  45 BC 09 2A 81 7C 0F 84 99 00 00 00 8B 4D 10 83
7C812A3Bh:  F9 0F 0F 87 4D 1D 03 00 85 C9 89 4D C0 74 07 57
7C812A4Bh:  8D 7D C4 F3 A5 5F 8D 45 B0 50 FF 15 08 15 80 7C
7C812A5Bh:  5E C9 C2 10 00 85 FF 0F 8E 36 93 FF FF 8B 55 FC
7C812A6Bh:  89 55 0C 0F B7 16 8B 7D F8 8A 14 3A 88 11 8B 78
7C812A7Bh:  0C 0F B6 D2 66 8B 14 57 66 3B 16 0F 85 A3 89 03
7C812A8Bh:  00 8B 50 08 66 8B 5A 04 38 19 0F 84 A1 89 03 00
Stack (0013E664h):
0013E644h:  00000000 BA7343E8 BA733CF4 00000001
0013E654h:  BA733FEC 0000003B 00000083 0076EE88
0013E664h:  0013E6F0 E0434F4D 00000001 00000000
0013E674h:  7C812A5B 00000001 8013150C 790C2000
0013E684h:  02000036 0013E69C 79E814DA 0013E6A8
0013E694h:  02000036 00000001 0013E718 79E87FF4
0013E6A4h:  0000012C 790FABCC 79F958B8 7916BE4C
0013E6B4h:  0000012C 0013E718 79F97065 E0434F4D
0013E6C4h:  00000001 00000001 0013E6F0 E3D7FC40
0013E6D4h:  01499AA4 00187918 00000000 00043000
0013E6E4h:  00000040 00000001 00187918 8013150C
0013E6F4h:  0013E274 00000001 00000001 0013E6D0
0013E704h:  0013E274 0013E7D0 79F9A3C8 9A3D6BD8
0013E714h:  00000000 0013E7DC 7A0945A4 01499AA4
0013E724h:  00000000 00000000 E3D7FC84 01499AA4
0013E734h:  01499A90 0149999C A027EBCC 79E71870
0013E744h:  FFFFFFFF 00000000 00000001 0013E760
0013E754h:  00000000 00187918 00000000 0013E730
0013E764h:  01499AA4 0013E734 01499A90 0013E738
0013E774h:  0149999C 0013E7DC 014856F8 0013E7E4
Registers:
EAX: 0013E668, EBX: 00187918, ECX: 00000000, EDX: 00000025
ESI: 0013E6F4, EDI: E0434F4D, EBP: 0013E6B8, ESP: 0013E664
Crash location: "kernel32", loaded at 7C800000h - 7C904000h
Symbol: "RaiseException" (+00000052h)
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C904000h
COMCTL32                        loaded at 77390000h - 77493000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4C000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77DA0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7E475000h
ole32                            loaded at 774A0000h - 775E3000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 76340000h - 7638A000h
uxtheme                          loaded at 5B090000h - 5B0C8000h
focus                            loaded at 003C0000h - 003C8000h
WMHook                          loaded at 003E0000h - 003EE000h
UnlockerHook                    loaded at 00B30000h - 00B34000h
AhJsctNs                        loaded at 65780000h - 657A3000h
HKDll                            loaded at 00B50000h - 00B5D000h
foo_albumlist_autoupdate        loaded at 00B70000h - 00B87000h
foo_autoplaylist                loaded at 00BB0000h - 00BE0000h
foo_browser                      loaded at 00C00000h - 00C3B000h
foo_burninate                    loaded at 00C60000h - 00C97000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_common                      loaded at 00CC0000h - 00CFA000h
foo_custominfo                  loaded at 00D20000h - 00DA5000h
foo_cwb_hooks                    loaded at 00DD0000h - 00DFE000h
foo_dockable_panels              loaded at 00E20000h - 00E43000h
foo_dsp_bs2b                    loaded at 00E70000h - 00E8C000h
foo_dsp_continuator              loaded at 00EB0000h - 00EE2000h
OLEAUT32                        loaded at 770E0000h - 7716C000h
foo_dsp_crossfeed                loaded at 00F10000h - 00F34000h
foo_dsp_delta                    loaded at 00F60000h - 00F7E000h
foo_highlightplaying            loaded at 00FA0000h - 00FC1000h
foo_input_monkey                loaded at 00FF0000h - 01039000h
foo_lnk                          loaded at 01060000h - 01079000h
foo_lyricsdb                    loaded at 010A0000h - 010BE000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
WININET                          loaded at 77AA0000h - 77B4C000h
CRYPT32                          loaded at 779E0000h - 77A76000h
MSASN1                          loaded at 77A80000h - 77A92000h
foo_masstag_addons              loaded at 010E0000h - 010EE000h
foo_menu_addons                  loaded at 01100000h - 0111F000h
foo_navigator                    loaded at 01130000h - 01151000h
foo_playcount                    loaded at 011A0000h - 011C8000h
foo_playlist_manager            loaded at 011E0000h - 01226000h
foo_queuemanager                loaded at 01250000h - 01278000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
foo_random                      loaded at 037A0000h - 037DF000h
foo_skip                        loaded at 037E0000h - 037FB000h
foo_uie_albumart                loaded at 03810000h - 03847000h
gdiplus                          loaded at 4EB80000h - 4ED23000h
foo_uie_albumlist                loaded at 03880000h - 038BF000h
foo_uie_bookmarks                loaded at 038E0000h - 03928000h
foo_uie_lyrics                  loaded at 03940000h - 0399E000h
WINMM                            loaded at 76AE0000h - 76B0F000h
foo_uie_lyrics_panel            loaded at 03A40000h - 03AA8000h
foo_uie_playlists_dropdown      loaded at 03AD0000h - 03B0A000h
foo_uie_queuemanager            loaded at 03B30000h - 03B69000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
foo_uie_quicksearch              loaded at 03E30000h - 03E77000h
foo_uie_single_column_playlist  loaded at 03E80000h - 03ED3000h
foo_uie_tabs                    loaded at 03EF0000h - 03F1A000h
foo_uie_trackinfo_mod            loaded at 03F40000h - 03F9A000h
foo_ui_columns                  loaded at 03FB0000h - 0404B000h
foo_utils                        loaded at 04070000h - 040A9000h
foo_verifier                    loaded at 040D0000h - 04100000h
foo_version                      loaded at 04120000h - 04146000h
dbghelp                          loaded at 5D3F0000h - 5D491000h
foo_winamp_spam                  loaded at 04270000h - 0428F000h
foo_abx                          loaded at 042A0000h - 042D4000h
foo_albumlist                    loaded at 04300000h - 04347000h
foo_cdda                        loaded at 04370000h - 043A6000h
foo_converter                    loaded at 043D0000h - 04439000h
foo_dsp_std                      loaded at 04460000h - 044A1000h
foo_freedb2                      loaded at 044D0000h - 04510000h
foo_input_std                    loaded at 04530000h - 04644000h
foo_masstag                      loaded at 04670000h - 046C0000h
foo_pqview                      loaded at 046E0000h - 046FC000h
foo_rgscan                      loaded at 04720000h - 04768000h
foo_ui_std                      loaded at 04790000h - 047E7000h
foo_unpack                      loaded at 04810000h - 0483E000h
vlmshlp                          loaded at 071B0000h - 071B7000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
mscorlib.resources              loaded at 068D0000h - 06920000h
imagehlp                        loaded at 76C40000h - 76C68000h
Stack dump analysis:
Address: 7C812A5Bh, location: "kernel32", loaded at 7C800000h - 7C904000h
Address: 790C2000h, location: "mscorlib.ni", loaded at 790C0000h - 79BA8000h
Address: 79E814DAh, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "InstallCustomModule" (+00001F6Ah)
Address: 79E87FF4h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "LogHelp_TerminateOnAssert" (+00001FA4h)
Address: 790FABCCh, location: "mscorlib.ni", loaded at 790C0000h - 79BA8000h
Address: 79F958B8h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "DllCanUnloadNowInternal" (+00001FFCh)
Address: 7916BE4Ch, location: "mscorlib.ni", loaded at 790C0000h - 79BA8000h
Address: 79F97065h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "DllCanUnloadNowInternal" (+000037A9h)
Address: 79F9A3C8h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "DllCanUnloadNowInternal" (+00006B0Ch)
Address: 7A0945A4h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "CorLaunchApplication" (+00012005h)
Address: 79E71870h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Address: 7A0944EAh, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "CorLaunchApplication" (+00011F4Bh)
Address: 7A3197D4h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Address: 7963C123h, location: "mscorlib.ni", loaded at 790C0000h - 79BA8000h
Address: 794D0540h, location: "mscorlib.ni", loaded at 790C0000h - 79BA8000h
Address: 79E885A2h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "LogHelp_TerminateOnAssert" (+00002552h)
Address: 794C7F7Fh, location: "mscorlib.ni", loaded at 790C0000h - 79BA8000h
Address: 03B63D60h, location: "foo_uie_queuemanager", loaded at 03B30000h - 03B69000h
Address: 79FCC4DAh, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "GetCompileInfo" (+0000656Bh)
Address: 03FD42BBh, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03B5E2D4h, location: "foo_uie_queuemanager", loaded at 03B30000h - 03B69000h
Address: 77EF6C2Dh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "DeleteObject" (+00000000h)
Address: 040262D0h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 01000000h, location: "foo_input_monkey", loaded at 00FF0000h - 01039000h
Address: 04011D0Dh, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 04025D60h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 04025D44h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 01010000h, location: "foo_input_monkey", loaded at 00FF0000h - 01039000h
Address: 03FD482Ah, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D18B26h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 03FB7220h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D188D1h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D188DAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 03FB7398h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D1D05Bh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnumDisplayMonitors" (+000000F8h)
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000169h)
Address: 77D1B4C0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 00B51350h, location: "HKDll", loaded at 00B50000h - 00B5D000h
Address: 77D1B4D0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D1FD29h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "UserClientDllInitialize" (+000007F1h)
Address: 77D6ABECh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetRawInputDeviceInfoA" (+0000011Fh)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 03FB0000h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 0401BD18h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D1B473h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D2013Eh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 77D20104h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 7C927C0Ch, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+0000020Fh)
Address: 7C920551h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C9205C8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C927E77h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+0000047Ah)
Address: 7C925041h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "bsearch" (+00000046h)
Address: 7C925233h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "bsearch" (+00000238h)
Address: 0401BD66h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 7C9255C9h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlHashUnicodeString" (+00000164h)
Address: 7C925152h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "bsearch" (+00000157h)
Address: 7C92554Ah, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlHashUnicodeString" (+000000E5h)
Address: 7C9253F5h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFindActivationContextSectionString" (+000000DCh)
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 77D19951h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsChild" (+00000243h)
Address: 7C920833h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000025Fh)
Address: 03FB0100h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 7C920838h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000264h)
Address: 77D199E4h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsChild" (+000002D6h)
Address: 77D19A12h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsChild" (+00000304h)
Address: 77D1A303h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "ClientThreadSetup" (+000002F9h)
Address: 77D19A18h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsChild" (+0000030Ah)
Address: 77D1A31Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "ClientThreadSetup" (+00000310h)
Address: 77D1A33Bh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "ClientThreadSetup" (+00000331h)
Address: 004E004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D19D60h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "UnregisterClassW" (+000002BCh)
Address: 77D70270h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D10000h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9205D4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 03FFC771h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FFC790h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FE7B47h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FE76A1h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 04033C14h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FE7A59h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 040311ACh, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D201F7h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CreateWindowExW" (+000002A7h)
Address: 0401BFC0h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 7C927BB8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 7C927BB0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 03FFC966h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FFC9A0h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FB1E97h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D1FF83h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CreateWindowExW" (+00000033h)
Address: 03FB7095h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FC3CD6h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 04033C0Ch, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FDD0B6h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 04034388h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 040126CDh, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FDD168h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 04034350h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 0401B298h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 04033C28h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FDD278h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FF9045h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FFBA65h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 03FFA89Ah, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D1B3B0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 77D1B3A7h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77D1C331h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 77D24073h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+00000198h)
Address: 77D241E2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D3E185h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "User32InitializeImmEntryTable" (+00000E18h)
Address: 77D3E162h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "User32InitializeImmEntryTable" (+00000DF5h)
Address: 77D24204h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 0110005Ah, location: "foo_menu_addons", loaded at 01100000h - 0111F000h
Address: 77D1B933h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsWindow" (+00000000h)
Address: 04014B2Dh, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D1B3F9h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 5B091AF6h, location: "uxtheme", loaded at 5B090000h - 5B0C8000h
Address: 03FF3A09h, location: "foo_ui_columns", loaded at 03FB0000h - 0404B000h
Address: 77D1B3D2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000096h)
Address: 77D2418Dh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D241B0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D23FD9h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 5B093AA7h, location: "uxtheme", loaded at 5B090000h - 5B0C8000h
Symbol: "DrawThemeText" (+00000A76h)
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D1BDA2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsWindowEnabled" (+00000000h)
Address: 77D1B50Ch, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 77D1DAF6h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DestroyWindow" (+0000000Ch)
Address: 004565F0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00456A71h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00456D23h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 5B092E8Eh, location: "uxtheme", loaded at 5B090000h - 5B0C8000h
Symbol: "DrawThemeBackground" (+00000266h)
Address: 7C809E01h, location: "kernel32", loaded at 7C800000h - 7C904000h
Symbol: "IsBadReadPtr" (+00000000h)
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Converter 1.0.1  (foo_converter)
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
Masstagger Addons 0.3.2  (foo_masstag_addons)
foobar2000 core v0.9.4.1  (Core)
Playlist Manager 1.0  (foo_playlist_manager)
bs2b 2.0.0  (foo_dsp_bs2b)
freedb Tagger 0.5.2a  (foo_freedb2)
Standard DSP array 1.0  (foo_dsp_std)
Shell link resolver 1.1  (foo_lnk)
Menu Addons 0.3.5  (foo_menu_addons)
Winamp API Emulator 0.90  (foo_winamp_spam)
Continuator 0.4.0  (foo_dsp_continuator)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Navigator 0.2  (foo_navigator)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Single Column Playlist Display 0.3.2 beta [Oct 27 2006 - 17:38:24]  (foo_uie_single_column_playlist)
Playlist tools 0.5.7  (foo_utils)
Quick Search Toolbar 2.8j  (foo_uie_quicksearch)
Playback Statistics 1.3.2  (foo_playcount)
File Integrity Verifier 1.0.1  (foo_verifier)
dockable columns ui panels 0.0.9b [Oct 23 2006 - 13:59:21]  (foo_dockable_panels)
ABX Comparator 1.3.1  (foo_abx)
WMA Decoder 1.1  (foo_input_std)
foo_skip 0.2  (foo_skip)
Album List 3.2.0  (foo_albumlist)
Bookmarks 0.0.9  (foo_uie_bookmarks)
RAR reader 1.1  (foo_unpack)
CD Audio Decoder 2.1.1  (foo_cdda)
cwbowron's title format hooks 1.0.13 [Oct  2 2006 - 09:06:52]  (foo_cwb_hooks)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Queue manager panel 0.2.1  (foo_uie_queuemanager)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
foo_custominfo 0.1.2  (foo_custominfo)
Queue manager 0.1.1  (foo_queuemanager)
Randomized playlist entry 1.2.3  (foo_random)
Track info panel mod 0.7.1 beta [Oct 24 2006 - 22:48:54]  (foo_uie_trackinfo_mod)
Music Browser 1.2.2c [Jul  6 2006 - 09:42:02]  (foo_browser)
Highlight playing 0.1.0  (foo_highlightplaying)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
ZIP/GZIP reader 1.0  (foo_unpack)
FLAC Decoder 1.1.0  (foo_input_std)
Components versions viewer 0.3  (foo_version)
Lyrics panel 0.34.1  (foo_uie_lyrics_panel)
Masstagger 1.6  (foo_masstag)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Crossfeed 0.92  (foo_dsp_crossfeed)
Albumlist autoupdate 0.1  (foo_albumlist_autoupdate)
Audio CD Writer 2.0.1  (foo_burninate)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
Default User Interface 0.9acc  (foo_ui_std)
Album Art Panel 0.2.5.1  (foo_uie_albumart)
Common services 0.1  (foo_common)
Lyric Show Panels 0.3.0.0  (foo_uie_lyrics)
When you'll got time, could you explain me, please, what i'm doing wrong..., or if the crash is due to foo_ui_queuemanager.
Have a nice day.
Reply #45
foo_queuemanager and foo_uie_queuemanager are not supposed to be installed at the same time. I guess this is the reason for this crash.
Reply #46
So I've deinstalled foo_pqview and foo_queuemanager, but this has not resolve the crash.
I guess the incompatibility comes from another component...
Thanks for your above reply
Reply #47
Edit: Okay oops, I wasn't paying attention when I woke up this morning. You can ignore me
Reply #48
I was writing "what is the "Play after current" thing ?" when I discovered what it is : it is in the playlist context menu. Hope this helps people like me.
Is there a way to insert some colours in the title formatting ? How do we align text to the right ? It would be nice to open files in the queue with a double-click (on queue manager panel). And is it possible to keep the queue when a track is played with double-click in the playlist ? Is it a foobar2000 feature that empty the queue ?
Thanks for your plugin.
Reply #49
[quote author=Moe-loves-ayumi link=msg=445062 date=1162140297]I was writing "what is the "Play after current" thing ?" when I discovered what it is : it is in the playlist context menu. Hope this helps people like me.
Is there a way to insert some colours in the title formatting ? How do we align text to the right ? It would be nice to open files in the queue with a double-click.
Thanks for your plugin.[/quote]
Thanks. I've been wondering where the heck that was.
