Topic: Use of Dibroms dll with Audiograbber (Read 3681 times) previous topic - next topic
How can I use Dibroms dll with audiograbber forcing it to use
--alt-preset standard.
(Audiograbbers interface gives no possibility for command-line parameters, only for certain switches, but the presets should overwrite them, right?)
I don't use Audiograbber so I'm not familiar with the setup. BUT, if the interface provides preset selections the same as CDex, then the DLLs at rjamorim's site will provide access to several of Dibrom's presets, see the text files that come with them for details.
john33
From what I remember (i'll load up audiograbber first, before i say anything) yes, you have to use lame as an external encoder first off, then add the preset flags in the "Predefined Arguments" section. It works, I usedt ado it that way until i moved on to eac...
-Jeffrey
I don't really know much about audiograbber's interface since it's been so long since I used it, but I'd highly suggest using EAC or CDex instead.  Both work with the external lame.exe, and at least CDex works with my presets through john33's modified .dll.
Thank you, john33 and dibrom!
Your latest modified dll works perfect with audiograbber, the only thing you can't get is the --r3mix preset, but meanwhile I am preferring --alt-preset standard.
The presets work as specified in the text file, but I guess you are saying you can't select r3mix preset in Audiograbber?
BTW, you are welcome! Happy Xmas!
john33
