Topic: A suggestion for foo_uie_lyrics (Read 1980 times) previous topic - next topic
When I use lyrics show panel, I find that there is a formatting string that is used when lyrics not found. The string can be used as Track info panel. But can it be modified to " show the formatting string when given a command", say a click on the panel? Since I am not always reading the lyrics even when I have it, and it is not good looking to show two panels at the same time. So I want to switch between lyrics and formatting string easily. Or a more general method, to place two(or several) panels in the same place and switch between them with a single click?
1) Did you really have to start yet another thread for discussing foo_uie_lyrics? We already have several.
2) Have you tried foo_uie_tabs? It will allow you to "stack" panels at the same spot and switch between them by clicking on tabs.. much like the tabbed playlist switcher.
Oh. It is exactly what I want! Thanks a lot. And sorry for adding a new thread again, I will try to search for existing one next time!
