I tested this new ripper last night and so far it works real stable and nice. I do have a few questions though.
I'm using a Sony DVD RW DRU-510A.
a.
The drive read cache detected 36KB cache. And the FUA support test said FUA works propper. Also when I enable FUA the cache test says the drive now doesnt cache.
But I've read in thread that the FUA feature is for plextor drives. Is the best option to use for my drive or should i just use the 36KB cache?
b.
My secure settings are: ultra pass 1-6-1, 7800 rereads and c2 enabled.
I have a cd that has 12 tracks that are 'V accurate(5)' en two of them are 'X AR (21) i Secure'. If I rip those tracks in burst mode they are ripped as 'V accurate(4)! What is better to use and can someone please explain to me what 'X AR (21) i Secure' means?
The log says this:
dBpowerAMP Release 12 Alpha 7 Digital Audio Extraction Log from woensdag 18 oktober 2006 5:56
Drive & Settings
Ripping with drive 'E: [SONY - DVD RW DRU-510A ]', Drive offset: 120, Overread Lead-in/out: No
AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: Yes
Pass 1 Drive Speed: Max, Pass 2 Drive Speed: Max
Ultra:: Vary Drive Speed: Yes, Min Passes: 1, Max Passes: 6, Finish After Clean Passes: 1
Bad Sector Re-rip:: Drive Speed: Max, Maximum Re-reads: 700
Encoder: Wave -compression="PCM"
Extraction Log
Track 7: Ripped LBA 127682 to 148392 (4:36) in 1:33. Filename: D:\My Documents\My Music\U2\U2 - The Best of 1980-1990 - 07 - Where the Streets Have No Name.wav
AccurateRip: Inaccurate (confidence 21) Secure (Warning) [Pass 1, Ultra 1 to 1, Re-Rip 1 Frames]
CRC32: ABF87DF7
Re-rip Frame: 148392 (00:04:36,133) matched 10 / 11
1 Tracks Ripped Securely (Warning: sectors had to be re-ripped) (AccurateRip: Different Pressing?)
