foobar2000 v0.9.3 beta Reply #150 – 2006-07-30 04:23:36 The link to download the 0.9.2 and 0.9.3.4 in official site (http://www.foobar2000.org/index.html) is don't working! Last Edit: 2006-07-30 04:24:07 by FRICSO
foobar2000 v0.9.3 beta Reply #151 – 2006-07-30 04:37:11 It worked for me, I just tried it again to be sure. Try clearing your cookies/cache and download it again.
foobar2000 v0.9.3 beta Reply #152 – 2006-07-30 12:59:34 the remove dead items bug has been fixed in beta4http://www.hydrogenaudio.org/forums/index....c=46961&hl=thx for fast work
foobar2000 v0.9.3 beta Reply #153 – 2006-07-30 14:24:47 Quote from: 4nt1 on 2006-07-30 03:43:47anyone got a change log for 0.9.3.4 ? i love seeing the new versions but I really have no idea of what has been changed or fixed so its very hard to judge or test the features...any ideas appreciated..+1
foobar2000 v0.9.3 beta Reply #154 – 2006-07-30 22:52:33 Quote from: Lyx on 2006-07-28 15:54:23What you want is not a cuesheet, but instead APL. Cuesheets dont support what you want to do. Use APL instead.Hrm... maybe a cuesheet isn't the absolute best solution, but I've already got hundreds of albums with cuesheets that have metadata for each track embedded into it. Foobar 0.9 can read such data okay, but only the common fields, and it mangles the cuesheets (i.e. deletes all my metadata) if I try to change some info. I'd like to see this functionality extended so that it will work the way that trusty 0.8.3 did (with cue_ex). Last Edit: 2006-07-30 22:53:17 by Supacon
foobar2000 v0.9.3 beta Reply #155 – 2006-07-30 23:31:03 Also, using .apl has the advantage of being able to reference a single track in a playlist (*m3u8/fpl). The greatest drawback being its closed format, system encoding dependancy and having many files instead of one (which is also an advantage). This said, embedded (or not) cuesheets are still useful so long as it doesn't go overboard. I don't like the idea of an escape mess in cuesheet extended tags, but I support your suggestion.Apparently components that have been modified in beta 4 areshared.dllfoo_unpack.dllfoo_rgscan.dllfoo_masstag.dllfoo_converter.dllfoo_cdda.dllfoo_input_std.dllfoo_albumlist.dllfoo_dsp_std.dllfoo_ui_std.dll Last Edit: 2006-07-30 23:31:32 by Rasqual
foobar2000 v0.9.3 beta Reply #156 – 2006-07-31 09:52:25 Thanks to the developers for the keyboard shortcut for "Properties (properties tab)" .There is also a "Properties (metadata tab)", but that's the same as just "Properties".
foobar2000 v0.9.3 beta Reply #157 – 2006-07-31 12:53:54 Quote from: 4nt1 on 2006-07-30 03:43:47anyone got a change log for 0.9.3.4 ? i love seeing the new versions but I really have no idea of what has been changed or fixed so its very hard to judge or test the features...any ideas appreciated..At least the Vorbis decoding failure issue appears to be fixed again Thanks Peter!
foobar2000 v0.9.3 beta Reply #158 – 2006-07-31 14:53:27 Quote from: Prodoc on 2006-07-31 12:53:54Quote from: 4nt1 on 2006-07-30 03:43:47anyone got a change log for 0.9.3.4 ? i love seeing the new versions but I really have no idea of what has been changed or fixed so its very hard to judge or test the features...any ideas appreciated..At least the Vorbis decoding failure issue appears to be fixed again Thanks Peter!This has been fixed in b3 afaik.
foobar2000 v0.9.3 beta Reply #159 – 2006-07-31 15:16:03 Quote from: Squeller on 2006-07-31 14:53:27Quote from: Prodoc on 2006-07-31 12:53:54Quote from: 4nt1 on 2006-07-30 03:43:47anyone got a change log for 0.9.3.4 ? i love seeing the new versions but I really have no idea of what has been changed or fixed so its very hard to judge or test the features...any ideas appreciated..At least the Vorbis decoding failure issue appears to be fixed again Thanks Peter!This has been fixed in b3 afaik.Nope, I discovered and reported it after beta 3.
foobar2000 v0.9.3 beta Reply #160 – 2006-07-31 21:33:37 I just wanted to say thanks for beta 4! It is significantly faster opening/closing and all around for me that the beta 3.
foobar2000 v0.9.3 beta Reply #161 – 2006-08-01 11:03:25 QuoteFoobar 0.9 can read such data okay, but only the common fields, and it mangles the cuesheets (i.e. deletes all my metadata) if I try to change some info. I'd like to see this functionality extendedExactly. Sadly, all such enquiries have met with no response so far.
foobar2000 v0.9.3 beta Reply #162 – 2006-08-05 14:07:19 foobar 0.9.3 final is available on http://foobar2000.org/
foobar2000 v0.9.3 beta Reply #163 – 2006-08-07 19:23:15 guys, I really can't download the executable from the official site!I'd just tried to clean my cookies and cache (like Yotsuya suggested), but don't worked in the Firefox and Internet Explorer.Always I click in the link, and simply reload the webpage. Last Edit: 2006-08-07 19:25:33 by FRICSO
foobar2000 v0.9.3 beta Reply #164 – 2006-08-07 19:35:46 Quote from: FRICSO on 2006-08-07 19:23:15guys, I really can't download the executable from the official site!I'd just tried to clean my cookies and cache (like Yotsuya suggested), but don't worked in the Firefox and Internet Explorer.Always I click in the link, and simply reload the webpage. Try this: Copy the downloadlink and Paste it into the adressbar.
foobar2000 v0.9.3 beta Reply #165 – 2006-08-08 02:44:31 What changes needed to be made to fix Vista compatability? I'm not running Vista yet, but I'm curious about the state of the transistion and why some programs do not work properly in under it.
foobar2000 v0.9.3 beta Reply #166 – 2006-08-08 03:59:29 I just installed Foobar v0.9.3 final on my Vista Public Beta2 testbox and it appears to run fine. Mind you this was just a default install and nothing fancy, no 3rd party plugins or anything but it appears to work out of the box with nothing special.
foobar2000 v0.9.3 beta Reply #167 – 2006-08-08 06:57:09 Quote from: Mike Giacomelli on 2006-08-08 02:44:31What changes needed to be made to fix Vista compatability? I'm not running Vista yet, but I'm curious about the state of the transistion and why some programs do not work properly in under it.In this case, it was some memory management functions in the runtime library that Microsoft changed in a non-backwards compatible way.
foobar2000 v0.9.3 beta Reply #168 – 2006-08-08 19:22:49 [quote author=deus-ex link=msg=418643 date=1154975746]Try this: Copy the downloadlink and Paste it into the adressbar.[/quote]Don't worked too! I'd tried to copy to my download manager (flashget) and don't worked too!it's too bad
foobar2000 v0.9.3 beta Reply #169 – 2006-08-08 19:28:46 If you want, I can upload it to YouSendit, and you can dl from there..just reply .
foobar2000 v0.9.3 beta Reply #170 – 2006-08-08 19:40:03 Quote from: FRICSO on 2006-08-08 19:22:49[quote author=deus-ex link=msg=418643 date=1154975746]Try this: Copy the downloadlink and Paste it into the adressbar.Don't worked too! I'd tried to copy to my download manager (flashget) and don't worked too!it's too bad [/quote]Well... it sounds like bloated software (read: firewall) is installed on your computer. If this is the case turn it off/uninstall/shift+delete... As you may see it's less than helping.
foobar2000 v0.9.3 beta Reply #171 – 2006-08-10 23:23:16 Quote from: funKie on 2006-08-08 19:28:46If you want, I can upload it to YouSendit, and you can dl from there..just reply .oh, do this for me, please! thanks! Quote from: roentgen on 2006-08-08 19:40:03Well... it sounds like bloated software (read: firewall) is installed on your computer. If this is the case turn it off/uninstall/shift+delete... As you may see it's less than helping.I don't use firewall, but thanks for your help!
foobar2000 v0.9.3 beta Reply #172 – 2006-08-10 23:33:43 Quote from: FRICSO on 2006-08-10 23:23:16Quote from: funKie on 2006-08-08 19:28:46If you want, I can upload it to YouSendit, and you can dl from there..just reply .oh, do this for me, please! thanks! Quote from: roentgen on 2006-08-08 19:40:03Well... it sounds like bloated software (read: firewall) is installed on your computer. If this is the case turn it off/uninstall/shift+delete... As you may see it's less than helping.I don't use firewall, but thanks for your help!meh. just disable the download manager.. works just fine
foobar2000 v0.9.3 beta Reply #173 – 2006-08-12 03:33:03 Quotemeh. just disable the download manager.. works just fineI don't using download manager, what I said's: I'd tried to use, but don't worked.
