Topic: Track Info Panel with ability to change font (Read 730378 times) previous topic - next topic
Reply #1200
Hello !
Is it possible to add a vertical scrollbar to the trackinfo panel?
If it is, what's the code?
Thank you very much !
Reply #1201
Where can I download this?  The download link is broken.
Reply #1202
yeah, i want it too
Reply #1203
In foobar 1.0 beta does not work
Reply #1204
It does work for me (v0.8.0 beta)
Btw, is there a newer version of this component? This one is pretty old (and it's blacklisted).
I see that the link is broken, so if anyone wants it:
foo_uie_trackinfo_mod
Disregard the constabulary.
Reply #1205
foo_uie_trackinfo_mod was merged in PanelsUI. PanelsUI is not used anymore, but I believe WSH Panel Mod is the closest equivalent today.
EDIT : Apparently Column UI offers similar functionality, it's called 'Item Properties'.
Reply #1206
Was foo_uie_trackinfo 0.8
Replaced on foo_uie_trackinfo_mod, now all not beautiful %)
foo_uie_trackinfo
ps: paranoia is of course, but want so...
Reply #1207
Is there still some form of documentation for this available? I'm searching for it but can't find it .
Reply #1208
i guess this component isn't used much these days, but i like it a lot.
here's what i've whipped up. the code is extremely ugly, but it works great
// Global
$puts(1,$rgb(234,0,0))
$puts(2,$rgb(224,41,00))
$puts(3,$rgb(215,78,0))
$puts(4,$rgb(205,112,0))
$puts(5,$rgb(195,142,0))
$puts(6,$rgb(186,169,0))
$puts(7,$rgb(160,176,0))
$puts(8,$rgb(121,167,0))
$puts(9,$rgb(86,157,0))
$puts(10,$rgb(54,147,0))
$puts(11,$rgb(25,138,0))
$puts(12,$rgb(0,128,0))
$drawrect(0,0,%_width%,15,brushcolor-50-100-140)
$alignabs(0,0,%_width%,15,center,middle)$rgb(255,255,255)NOW PLAYING
$drawrect(0,150,%_width%,15, brushcolor-50-100-140)
$alignabs(0,150,%_width%,15,center,middle)$rgb(255,255,255)TECHNICAL
$drawrect(0,225,%_width%,15, brushcolor-50-100-140)
$alignabs(0,225,%_width%,15,center,middle)$rgb(255,255,255)STATISTICS
// PerTrack
$alignabs(0,15,65,15,right,)Title:
$alignabs(0,30,65,15,right,)Rating:
$alignabs(0,45,65,15,right,)Artist:
$alignabs(0,60,65,15,right,)Album:
$alignabs(0,75,65,15,right,)Type:
$alignabs(0,90,65,15,right,)Date:
$alignabs(0,105,65,15,right,)Genre:
$alignabs(0,120,65,15,right,)Style:
$alignabs(0,135,65,15,right,)Comments:
$alignabs(0,165,65,15,right,)Codec:
$alignabs(0,180,65,15,right,)Bitrate:
$alignabs(0,195,65,15,right,)Track Gain:
$alignabs(0,210,65,15,right,)Album Gain:
$alignabs(0,240,65,15,right,)Play Count:
$alignabs(0,255,65,15,right,)Last Played:
$alignabs(0,270,65,15,right,)Length:
$alignabs(70,15,$sub(%_width%,60),15,,)$rgb(50,100,140,0,0,0)$replace($replace(%title%,')',')'$rgb(50,100,140,0,0,0)),'(',$rgb(133,176,211,94,74,83)'(')
$alignabs(70,30,$sub(%_width%,60),15,,)
$puts(mychar,$char(9733)$char(8202))
$rgb(245,175,92,225,155,72)
$ifgreater(%rating%,0,
$repeat(★,%rating%)
$repeat($rgb(230,230,230,210,210,210)★,$sub(5,%rating%))
$repeat($rgb(230,230,230,210,210,210)★,5)
$alignabs(70,45,$sub(%_width%,60),15,,)$rgb(60,100,60)%artist%
$alignabs(70,60,$sub(%_width%,60),15,,)$puts(normal,$rgb(60,100,60))
$puts(light,$rgb(164,180,134))
$puts(bright,$rgb(205,135,52))
$get(normal)
$replace(%album%,
'(',$get(light)'(',
')',')'$get(normal),
'[single]',,
'EP',,
'12"',,
'7"',)
$if(%discnumber%,
$get(sep)$rgb(0,0,255) '['Disc %discnumber%[ of %totaldiscs%]']'
$alignabs(70,75,$sub(%_width%,60),15,,)$rgb(50,100,140)%release type%
$alignabs(70,90,$sub(%_width%,60),15,,)$rgb(50,100,140)%date%
$alignabs(70,105,$sub(%_width%,60),15,,)$rgb(50,100,140)%genre%
$alignabs(70,120,$sub(%_width%,60),15,,)$rgb(50,100,140)%style%
$alignabs(70,135,$sub(%_width%,60),15,,)$rgb(50,100,140)$if2(%comments%,...)
$alignabs(70,165,$sub(%_width%,60),15,,)$rgb(50,100,140)%codec% [%codec_profile%]
$alignabs(70,195,$sub(%_width%,60),15,,)$if(%replaygain_track_gain%,$rgb(50,100,140)%replaygain_track_gain%,$rgb(234,0,0)$char(215))
$alignabs(70,210,$sub(%_width%,60),15,,)$if(%replaygain_album_gain%,$rgb(50,100,140)%replaygain_album_gain%,$rgb(234,0,0)$char(215))
$alignabs(70,240,$sub(%_width%,60),15,,)$rgb(50,100,140)%play_count% $ifequal(%play_count%,1,time,times)
$alignabs(70,255,$sub(%_width%,60),15,,)$rgb(140,150,160)$rgb(50,100,140)$if2(%last_played%,Never)
// PerSecond
$alignabs(70,270,$sub(%_width%,60),15,,)$rgb(50,100,160)%length%$rgb(140,150,160)' [- '%playback_time_remaining%']'
$alignabs(70,180,$sub(%_width%,60),15,,)
$rgb(140,150,160)
$ifgreater(%bitrate%,0,$get(1),)
$ifgreater(%bitrate%,49,$get(2),)
$ifgreater(%bitrate%,74,$get(3),)
$ifgreater(%bitrate%,99,$get(4),)
$ifgreater(%bitrate%,124,$get(5),)
$ifgreater(%bitrate%,149,$get(6),)
$ifgreater(%bitrate%,174,$get(7),)
$ifgreater(%bitrate%,199,$get(8),)
$ifgreater(%bitrate%,224,$get(9),)
$ifgreater(%bitrate%,249,$get(10),)
$ifgreater(%bitrate%,274,$get(11),)
$ifgreater(%bitrate%,299,$get(12),)
%bitrate% $rgb(50,100,140)kbps
Reply #1209
Hi,i use this code but on rate i have no stars but lines,any help?
Moderation: Removed unnecessary full quote of the preceding post.
Reply #1210
It doesn't work native on windows xp, vista or 7 is needed.
An alternative is to install East Asian language support as described in this topic.
Reply #1211
I have win 7 ultimate x64 Greek lang. here is a screen cap.
Reply #1212
Ok,i fix it,i was had wrong text settings,thank you.
