Topic: Track Info Panel with ability to change font (Read 755359 times) previous topic - next topic
Reply #576
thanks i found it but this is a newer version so cheers
The one that russell777 mentioned actually is the newest version.  Version 0.2.5 is a modified version, which was spawned from version 2.07
Reply #577
Is there a way to have buttons align with the preceeding text? I need something like:
Line 1
Line 2
Line 3
Button
But I can't specify a height because in some cases Line 2 may not be displayed. I've tried using $button2(,,,,,,x,x,x,x) but the button is still positioned as if the values were 0.
Also, if I change underline in the following to bold, the screen is blank. Any ideas?
$button2(0,0,0,0,30,13,'$font(tahoma,8,,0-0-0)pause','$font(tahoma,8,underline,0-0-0)pause',pause,)
Reply #578
i want to display my album art to a max of 300by300 centrally is there a code i can use? so it remains centered even if the window resizes?
also is there a way so the images resizes due to the visible space (again if the window resizes?)
Reply #579
I'm having trouble with playback commands within $button. None of them seem to work including: play, pause, playpause, previous, prev, next, stop, playback/play, playback/prev, playback/previous, etc, etc, etc.
I've tried the wiki that includes all foobar commands, but they just aren't working.
Reply #580
Make sure there is no space between the previous comma and the command and the command is exactly as it appears in the wiki. There was a space in the example on the wiki that was causing it not to work for me.
Reply #581
Hi, terrestrial and gang.
I've been using foobar for about a week and this plug-in for about as long. (version: 0.7.1 beta [Oct 24 2006 - 22:48:54])
I'm using the following code to display album art:
$imageabs2(125,125,,,,,2,2,$replace(%path%,%filename_ext%,)folder.jpg,)
and this works great for everything except whenever I'm playing/viewing a song from the directory ...My Music\Albums\Big Star\#1 Record
Since the image file is viewable with the same code if I move it to another directory, and the $replace(%path%,%filename_ext%,) prints in trackinfo_mod by itself as one would expect, I'm guessing the bug is with your plug-in, and has something to do with the path to the file containing a #.
Thank you.
elevatorladylevitateme
Reply #582
I'm trying to make a button for playing an audio cd, like this:
$button(21,0,0,0,18,17,images\icons\opencd.png,,play audio cd...,)      and it does not work
I've also tried: $button(21,0,0,0,18,17,images\icons\opencd.png,,play audio cd,)  but still, nothing
The "play audio cd..." command belongs to the Main Menu Items.
Anybody else has made that button? is it not possible?
EDIT: nvm, the right command is "Open Audio CD". It's wrong in the commandline guide in the wiki
Reply #583
Does anyone know if there would be a way to know the state of a tabbed panel, i mean which view it is on, inside the code of a track info mod panel?
Edit: It appears that images loaded in track info mod are locked so we cant modify album arts for example. Would there be a way for those images not to be locked?
Also i really hope fileexists will be implemented in track info mod too
Cant wait for that and the full path commands
Thanks a lot for your work terrestrial!
Reply #584
If you guys find a mistake in the Wiki, don't be shy, fix it!
It's not possible to my knowledge. There's no way to detect what state a tabbed panel is in.
Reply #585
That s what i thought
Reply #586
Could I make a button to load a specific playlist?
Closest command I can find is: Playlist/Load playlist...
Is there a way to specify one? I'm kind of assuming thats why it's ...
Reply #587
Currently when you resize the panel, images are not updated. Consequently if the size of an imageabs2 depends on the width or height, the image does not resize itself when you resize the panel.
Could it be possible terrestrial to add that feature?
Reply #588
I was going to ask the same thing. Also, are you planning to implement the new features in single_column into this (NOKEEPASPECT,filecheck,image wildcards)?
Reply #589
When I upgraded to the Oct. 24 version of trackinfomod my buttons linked to foo_run services and tabs stopped working. I downgraded to my previous version and they started working again. I re-upgraded to Oct.24 and they stopped. However, my buttons linked to main menu playback commands such as previous, next, play/pause, and volume functions all function properly in both versions. Is anyone experiencing this problem? I'll have to wait until this weekend to give it a proper debugging.
Reply #590
my tabs are still working in the current version
Reply #591
Well I solved my problem, there appears to have been a change in the button command:
$button(x,y,a,b,w,h,image,hover,option)
Before I had left a and b blank, this used to work fine but the newer version appears to be a bit more sensitive. I replaced the empty parameters with 0's and now all is well.
Reply #592
is there a way to display the total number of tracks selected in this panel somehow ?
i see a way to display selected time...and a way to show the number of tracks in a playlist.
but is there a way to display how many tracks i have selected ?
thanks!
Reply #593
quick requests, could you make it so setting tags/running scripts targets all of the tracks selected, right now it is only doing one. Also the same imageabs2 options you added to single columns playlists would be awesome(nokeepaspect/image aligning)
thanks for the great work on these components
Reply #594
i hope $fileexists is being added to this plugin too
Reply #595
Feature Request
Allow buttons, rectangles and images to flow with text instead of specifying a position. Thanks!
Reply #596
Feature Request
use $calcwidth to find the length of text and size them that way
Reply #597
is it possible for a button to switch to a different foobar layout?
and going even further specifying which tabbed panel?
Reply #598
Using last build of TrackInfo.. I don't have ability to bring my foobar window on top when clicking on trackinfo area.. Could it be fixed? Older builds don't have such problem..
Reply #599
You should be able to just use the panel/layout name as the button command.. I think
