Topic: Psytell AAC 1.6 crasdher alot (Read 4601 times) previous topic - next topic
i just tried to encode trancemaster 21 cd3
in oticed that bitrates got very ow with -streaming (below 128kbits) whcih i found funny hence with cd 2 and version 1.5 the where all higher then 130kbits..
anyway psytell 1.6 crashed on 4 of my wav's...
i playd the way in winamp but they sounded ok.
I'm just about to re-rip the files at a lower speed now.
hope that helps
Sven Bent - Denmark
i tried re-rip the track at 4x speed. and it didn't help still crashere
I'm suign
WinXP pro - danish
Eazy cda-extractor 4.6.1
psytell encoder v1.6 stable
Sven Bent - Denmark
Ok, I think I found what was causing crashing -
New bugfixed version is uploaded in the /temp folder so you can check..
-- Ivan
Darn i spell like sh*t when a type at this computer..must b te keyboard :-)
anyway
where do i get  the bugfix version..and is it normal behaiver the bitrates is lower with the new 1.6 version....
Trance master21 contains 3 cd's
2 cd's with different trance music and a third cd which are all remixes of different songe from cd 1 & 2
So some of the song from cd2 (with bitrates above 130k) is also on cd 3 (with belove 120k bitrates) but remixed.
Sven Bent - Denmark
Yes, Ivan has told me that some of the optimizations now allow lower bitrates with higher quality.
I just downloadet the new v1.6 of yhe psytell aacenc.
and it still crashes on me ..however this is only if i use -streaming if i use -normalt it runs fine :confused:
but -normal gives me to big files
Sven Bent - Denmark
