foo_alarm Reply #50 – 2006-09-25 21:49:32 Work is in progress. It's not as easy as it seemed at first. When there will be something to test, a new thread will be started.
foo_alarm Reply #51 – 2006-09-26 08:30:53 Thanks andrew. Just please make sure you post the link to the new post into this thread.
foo_alarm Reply #52 – 2006-10-03 01:27:36 Great work! Thank you very much!Expecting multi-timers like those in "Scheduler"....Thanks again!
foo_alarm Reply #53 – 2006-10-15 15:54:19 I have solved the problem with multiple alarms (for example starting playback of a specified playlist on weekdays and at the weekend at the different time) this way:1. downloading foo_cmd_playlist component, that enables activating of specified playlist by name2. making simple batch file named foobar.cmd with this: start /d"C:\Program Files\foobar2000\" foobar2000.exe /playlist-activate:"<SpecifiedPlaylist>" /play3. setting windows task scheduler to execute foobar.cmdMaybe this will help someone.....
foo_alarm Reply #54 – 2006-10-22 19:18:41 Good news for those waiting for foo_scheduler! I've almost completed the development. During the next week you'll see foo_alarm 2.0 (or it's better to say foo_scheduler 2.0 )! Stay tuned! Last Edit: 2006-10-22 19:25:45 by andrew_smolko
foo_alarm Reply #58 – 2006-10-25 21:24:46 No more foo_alarm, foo_scheduler is better! (topic) Last Edit: 2006-10-25 21:59:38 by andrew_smolko
foo_alarm Reply #60 – 2006-10-26 11:32:37 Goodbye foo_alarm. Our time together was short but sweet.(thank you andrew)
foo_alarm Reply #62 – 2006-10-31 21:08:42 bug: foo_alarm.dlldoesen't work start-stop 23:59-0:01 i like to go to bed with music (radio streaming), and i don't like to switch it off. suggestion: make button [start playing right now and stop after] xx hours xx minutes
foo_alarm Reply #63 – 2006-10-31 21:38:37 Quote from: parabox on 2006-10-31 21:08:42bug: foo_alarm.dlldoesen't work start-stop 23:59-0:01 i like to go to bed with music (radio streaming), and i don't like to switch it off. suggestion: make button [start playing right now and stop after] xx hours xx minutes Have you read the first red message in the first post? foo_alarm development is stopped, use foo_scheduler instead.
foo_alarm Reply #64 – 2006-11-01 22:50:49 Quote from: andrew_smolko on 2006-10-31 21:38:37Have you read the first red messagegood work;) i thought it will be long delayed development project thank you. Last Edit: 2006-11-01 22:52:01 by parabox
