Topic: foo_alarm (Read 66658 times) previous topic - next topic
foo_alarm
Superseded by foo_scheduler (topic)
Simple plugin that starts playback at the specified period of time. Just set up the period on Preferences/Playback/Alarm page.
I'd like to use my computer as alarm clock but I am tired of waiting scheduler plugin. And I don't want to use any external schedulers. Now I select playlist that should be played early in the morning and switch computer to sleep mode. When computer wakes up, playback is started. Of course, it's possible to start playback and then switch to sleep mode, but usually I power off the computer late at night and I don't want to disturb anybody with loud music.
Version 1.61 (download)
Changelog:
  • 1.61
    Fixed: playback queue isn't cleared before starting playback
  • 1.6
    Added: computer wake up from stand-by/hibernate mode
  • 1.55
    Fixed: playback isn't started from paused state
    Added: playback of the specified playlist
  • 1.5
    Added: alarm startup type
    Added: it's possible to disable fade in
    Added: fade in range configuration
    Added: buttons to pick current player volume
    Code is rewritten from scratch.
  • 1.05
    Added: fade in
  • 1.03
    Added: checkbox to enable/disable alarm
  • 1.02
    Changed the appearance of the preferences page
  • 1.01
    Fixed: preferences page isn't displayed under win 2k
  • 1.0
    Initial release
[/size]
foo_alarm
Just intalled it and got
foobar2000 0.9.3 beta 3, win 2k sp 4
hellska crew
foo_alarm
now it's working, btw if i set it to start time 2mins ago for instance, and then chage end time to after an hour foobar starts playing.
btw would be nice also to change days, and shutdown at end time options
hellska crew
foo_alarm
It happens because alarm is restarted when you change "start time" or "end time".
I'll think about it. If scheduler plugin doesn't appear in nearly future, I'll begin developing my own foo_scheduler
foo_alarm
Thanks for the plugin.
Bug report: Start (e.g. 12:20PM) works fine. End (e.g. 12:23PM) doesn't stop playing. Also, if foobar2000 is stopped and closed, and reopened, the songs start playing. Is this intended behavior?
foo_alarm
Perhaps I should change descriptions for edit-boxes. "End time" doesn't mean "stop playing at this time". "Start" and "end time" describe time interval. If the current time is between "start" and "end" then playback is started.
I've done that way because sometimes I change wake up time in BIOS and I don't want to change it every time in foobar. In alarm preferences I set my usual wake up time, e.g 6:00-9:00, and then I change BIOS alarm, e.g 7:30. When computer wakes up from sleep mode, foo_alarm starts playback, because current time 7:30 is between 6:00 and 9:00. The next day I want to set alarm at 6:30, so I just change it in BIOS, not in foobar. But when computer is powered on manually at 13:00 there is no need to start playback, because most likely that I'm not sleeping
Yes.
foo_alarm
Bud,thanks so much,couse i was still using the 0.8.3 couse i was waiting for scheduler,now i can switch to new one as simply wake up alarm is all what i need
Thanks once again!!
foo_alarm
Good job on the plugin, been looking for a foo_scheduler replacement !  THANK YOU
foo_alarm
Thanks for the initiative. Just a request: for me, it is most important to have the alarm activate after a given delay, rather than at a specific time. I have now moved up from 8.3, however.
foo_alarm
FInally this day has come. I'm, too, the one who has been waiting for an updated of scheduler only before upgrade to 0.9 . I use it every day.
I have not tested yet, but may I raise a stupid question. I think your mainboard is a new one so that it support wake up time in BIOS, but mine doesn't . Can the plugin wakes up the PC itself if I turn my PC to sleep mode ?
GRAET GREAT GREAT , You have made my day !
foo_alarm
Well, Epox 8RDA3I on nForce2 chipset. It's not a new mainboard, I've bought it 2 years ago.
Can the plugin wakes up the PC itself if I turn my PC to sleep mode?
No, it's impossible. Only BIOS controls this functionality.
foo_alarm
 LOL mine is ... my brain erased the chipset name already ... ESC mobo for my 6years old PIII 1.2G . So there is no hope, but it's ok for me anyway, I have my PC on for 24/7 and it's been like this long ago.
I hope you would add more functions to the component or your scheduler clone. As I said, my PC runs all day long and with ssheduler, I set a rule set :
- turn down volume at 11pm
- turn down a little bit more at 3am (about this time I go to sleep) . and keep playing during my sleep time.
- prepare all steps like: choose playlist, tracks, [the tracks after that], ... and RELEASE the volume to 0 , loud enough for me to wake up, then after 10mins reduce the volume to -10 (or someone would kill me )
I'm looking forward for any development of this must have component
thanks again
foo_alarm
Wait, so does this only work with sleep modes, or can I just specify a time at which it starts playing x song?
Plugin doesn't work with sleep modes, it only starts playback at specified period of time.
foo_alarm
Could you add a feature in the preferences, like a checkbox or something, to activate and deactivate the plugin?  Don't want it going off on the weekends, and I tend to leave fb2k open most of the time.
foo_alarm
I need such checkbox too, so download version 1.03, I've added this feature
foo_alarm
Now only fade in-out, and auto shutdown is missing. Having the skeleton, this can't be too difficult to implement. Please
foo_alarm
Fade in has been added in 1.05.
foo_alarm
Superb, thanks!
foo_alarm
Is there a way not to reach the 0.0 dB volume? I don't want to wake up my neighboors at the same time as me
(the only way I found is to enter 3600 seconds of delay before reaching 0dB). Maybe a slider for the target volume could be perfect.
Anyway: very nice plugin. Thanks!
Edit: another request: could the second time be de-activated?
foo_alarm
I allow myself to make another suggestion. Few words, a pic:
And thanks again for your useful plugin, Andrew.
foo_alarm
1.5 is ready!
