Topic: Run Command (Read 56045 times) previous topic - next topic
Re: Run Command
Reply #75
Thank you very much for your nice answer! You are very kind!!
I'll be waiting for the updated version of your component , whenever you will have time!
Again ,thank you for your time my friend!
Re: Run Command
Reply #76
Is there a way to suppress confirmation message when running the following command:
foobar2000.exe /runcmd-files="Utilities/Rebuild MP3 Stream" c:\someFolder\*.*
getting a confirmation message.
also getting a different confirmation message on this command:
foobar2000.exe /runcmd-files="Convert/32mbps" c:\someFolder\*.*
those messages are part of the normal UI behavior. Is there a way to script those commands in a quiet mode to avoid interaction.
I do not want to confirm anything in the middle of the script.
Re: Run Command
Reply #77
I can't get the command prompt to run anything under "Sort" in the Edit menu -- I want to set Foobar to run the randomize command and it doesn't actually do what it's supposed to...
foobar2000.exe /runcmd="Edit/Sort/Randomize"
v1.3.14
In console, this is the error I get:
runcmd: Resolving main menu command: Edit/Sort/Randomize
No available command found
Any ideas?
Re: Run Command
Reply #78
v1.3.14
Any ideas?
I'm trying a similar thing - reverse a playlist. I thought foobar2000.exe /runcmd="Edit/Sort/Reverse" would do the job, but it doesn't work. Same error as yours...
This command is not dynamically generated, but I still don't know why it doesn't work.
Re: Run Command view swith to playlist does not work.
Reply #79
Hello,
we are using Foobar2000 v1.3.17on LINUX  under wine with foobar2000.exe /runcmd="view/swith to playlist/ name of playlist" /runcmd="Playback/play".
other commands work in the same environment (
The goal is to start playing always the same file (a web radio) when foobar is turned on.
We assigned these commands to keyboard shortcut and it works.
Thank you for your help.
Re: Run Command
Reply #80
Please HELP:
"/runcmd=View/Visualisations/Analog VU Meter skins/<Default>/Next skin"
don't work (
Re: Run Command
Reply #81
I'm out of ideas, I'd like to control the playback of foobar through the parameter /rundcmd.
But when I execute:
foobar2000.exe /runcmd="Playback/Play or Pause"
I receive the error:
Unknown commandline parameter: /rundcmd=Playback/Play or Pause
Am I doing something wrong here? (Obviously, but what :D)
Could someone help me out?
--BenniP
Re: Run Command
Reply #82
Firstly you have a typo in there ...
However why not try the built-in command line options?
foobar2000.exe /command:"Play or pause"
Cheers
Re: Run Command
Reply #83
Thank you very much, didn't see that!
How stupid of me  >:(
Yeah, after I posted that I realised that as well.
Re: Run Command
Reply #85
Wow, I was looking for this for quite some time! Thanks!
Re: Run Command
Reply #86
"c:\Program Files (x86)\foobar2000\foobar2000.exe" /runcmd-playlist="Tagging/Remove tags from file(s)" "d:\Temp\Test.flac"
"c:\Program Files (x86)\foobar2000\foobar2000.exe" /runcmd-playlist="Utilities/Remove embedded cuesheet(s)" "d:\Temp\Test.flac"
Error:
Spoiler (click to show/hide)
Don't working from console. But working from UI. Any ideas?
Re: Run Command
Reply #87
Is there any reason why sorting doesn't work at all, bar for keyboard shortcuts?
No matter what I try: foo_run_cmd, built-in foobar cmd capabilities, full playlist sorting via main menu, selection sorting via main menu, context sorting - none if it works.
This question has been asked already before to no asnwer:
v1.3.14
Any ideas?
Re: Run Command
Reply #88
It has been answered and alternatives have been posted. Read the last few pages again.
edit: please don't exclaim the Sort menu isn't dynamically generated. It is....
Re: Run Command
Reply #89
Thanks, I was looking for direct answer to those posts. Now it works perfectly (although to set up a scheduler like I wanted I'm using now four distinct plugins, foo_runcmd, foo_run_main, foo_run & foo_scheduler).
