Topic: How do I create a CD image or .cue from WAV files? (Read 13003 times) previous topic - next topic
Is there any software that will create a disc image from multiple WAV files.
I want to be able to create a mountable image from WAV files: ideally I'd like to convert the multiple WAV files into a single WAV file, and a cue sheet, but I'd be happy just to be able to automatically generate a cue sheet from a folder of WAV's.
I have quite a lot of folders of unnamed (e.g. "Track 01"; "Track 02"; etc.) WAV files, and it would be very handy to mount them as images, so that they're recognised by iTunes.
The nearest I've managed is to have create a compilation using Nero, and removing the between song pauses, although this is quite convoluted, and results in a file in the proprietary .nrg format, which is less than ideal.
You could use foobar with foo_cuesheetcreator to create a cuesheet from a load of WAVE files.
Edit: If you'd actually prefer to merge the files as well, then foobar's built in Converter will do that.
There's also my cuemake, which is a .NET command line app (which I don't use), or shntool (a good command line app) would no doubt do it.
I'm on a horse.
Mh, exact same problem here.
I've got a self-made compilation and want to 'merge' the files and use chapters with a cuesheet. Maybe I'm a bit naive, but it sounded so easy.
When choosing 'convert' and then the cuesheet part of it, nothing happens except that all files are re-encoded and copied into one directory. No cuesheet, nothing. I hope I'm just being stupid because I'd really love to share my playlists in one file which could be browsed by chapters or something..
thanks
As long as your files are numbered so that they sort correctly:
$ shntool cue *.wav
and then:
$ shntool join *.wav
You'll need to rename your big WAV and its corresponding reference in the CUE file and the individual WAV filenames will be lost and replaced by Track 01 etc.
Thank you. I'll try this when I get a moment.
Sorry, it would probably be easier to make the CUE creation command:
$ shntool cue *.wav > foo.cue
which will give you a CUE file in the working directory rather than requiring you to copy/paste one.
