Topic: Long Filename bug XP-EAC-LAME (Read 3340 times) previous topic - next topic
i accidently set the eac to create a filename that is obviously too long to handle for XP. I can´t move or delete it, nor change the name. thx m.
ps.: which lame is the one to use at the moment?
Have you already tried to delete them with "Windows Explorer"? - Normally this tool can delete files from harddisk, where others fail (e.g. "Windows Commander"). A few weeks ago, I had some files, which neither could be found by the system on the harddisk anymore, nor could this error be corrected by the dos-function "chkdsk" (checkdisk). They were yet only listed in the directories. But with Windows Explorer I still could delete them.
My used codecs and settings:
FLAC V1.1.2 -4 / APE V3.99 Update 4 -high / MPC V1.15v --q 5 / LAME V3.97b2 -V2 --vbr-new / OGG aoTuV V4.51 Lancer -q5
Nope, doesn´t work. XP-Explorer has no access.
Try using "deltree" to delete the whole directory if possible.
Reboot your machine. You probably have some app that has session locked the file, preventing deletion.
i would still suggest trying to move it to another directory on the same drive (using explorer).
if it is on c: then move it to c:\tmp, if on d: then to d:\tmp and so on
Directory name should be something very short, like "tmp"
I had the same problem with a file I got from kazaa which had a very long filename and I could find no way to delete it in windows.
Only thing that worked was restarting in "dos-prompt mode" and delete the file.
When that problem occured on my WinXP machine, moving the file has mostly solved the problem. after it has been moved, I have been able to rename the file and after that remove it. Good luck.
I doubt your filename is really too long for XP to handle - XP can handle filenames up to 255 characters and full paths of up to 32,767 (wide) characters.  So you could have a filename like "c:\255 letter name 1\255 letter name 2\255 letter name 3\......\255 letter name 128" and it would (well, should) work ok.
except for most of windows programs having hardcoded limit of 260 (MAX_PATH) characters per file path.
Yes, but Windows itself can handle 32,767 so it should be able to delete it.  What really causes problems in Windows is when a filename has '*' in it (CDs from those Mac users !).  Then, you can't do ANYTHING with it.
You will be able to delete it from the command/DOS prompt using wildcards. I had the same problem some months ago and that was the only way to remove it.
John
My compiles and utilities are at http://www.rarewares.org/
Thanx a lot, guys. Nothing worked.  No kind of access to the file, except I can play it with the win-media-player. no moving, deleting etc; not even with win-explorer. Rebooting didn´t help either.
@ Jan S., how do I start the dos-mode
@ zZzZzZz, so what can I do?  (w00t)
With the Dos-Prompt I managed to kill it. :alien:
(the path was C:\Dokumente und Einstellungen\Erste Bank\Eigene Dateien\Eigene Musik\CD\a-MICHI G\Various Artists - Rolling Stone Rare Tracks Vol.21 - Soul\and an endless long song-title+Various Artists - Rolling Stone Rare Tracks Vol.21 - Soul.mp3. Thanx to all again!
I once had the same problem
Try this...
Reboot  into Safe Mode With Command prompt
goto the folder where the file is an type del *a word of the title*.*.
It worked for me.
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
