Re: Skins for foo_title plugin
Reply #164 –
Very sorry but I missed a strange issue in my flourish skin that appeared when I updated but I didn't notice until I already posted v2. Apparently foo_title no longer allows layers whose padding contains a negative value to clip out of its boundaries, nor into a previous layers' padding. Any such geometry will become transparent. Strange, but I fixed it by rearranging the order it's loaded and giving it a positive padding value. It affected only the RATING_CD display.
<layer name="rating" type="text">
<geometry type="full">
<padding left="16" top="2" right="0" bottom="0"/>
</geometry>
<contents spacing="0" font="Guifx v2 Transports" size="10">
<label position="left" color="88FFFFFF">$ifgreater(%rating_cd%,0,b, )</label>
</contents>
</layer>
I'll explain again the function of this layer. It shows a star if the RATING_CD tag is present. If you do not have foo_customdb component, change this to RATING. If you do not have the font installed and listen to a rated song, you'll only see the character 'b'. If you don't want an entire font as a dependency for a single character, you could change it to a unicode ★ and take font="..." out, or if you don't want rating display at all, modify or take this entire code cluster right out of the file. All up to you.
