Topic: Skins for foo_title plugin (Read 365588 times) previous topic - next topic
In this thread you can present your skins for the foo_title plugin by Quiark
I put together a pretty minimal skin using Quiark's animation and some of his code as a starting point. The control buttons are transparent. They're laid out below the album art (left to right: previous, play, pause, stop, next). Admittedly, the code for the progress bar could be cleaner, but it works...
great component, thanks!
[attachment=2359:attachment][attachment=2360:attachment]
Here's a quick skin I made. It's supposed to be a sort of Fallout-style display bar. Hope you like it.
There's a darker version in there too, but you'll have to enable that from the skin.xml, but it shouldn't be too hard to find.
This is a skin created by Raven:
black.
[a href="http://img93.imageshack.us/my.php?image=footitledbainestoastpreviewyh2.jpg" target="_blank"]
Velvet
[a href="http://img205.imageshack.us/my.php?image=velvetpreviewuw7.jpg" target="_blank"]
foostick...
another one i did last night...i remember seeing a winamp skin like this in winshade mode...
no funni buttons this time, just simple playback, minimize, maximize and close.
PS: hope you have Dungeon font
A little transparent, small skin with buttons called thin:
[attachment=2403:attachment]
foostick...
Hello,
I just discovered this great plugin. It is something I've been really missing in fb2k since I upgraded to 0.9 and lost Foopilot One. I really like foostick skin. Simple and effective. I have all the time, I just have some minor issues. The stop button is in fact a pause button. I didn't like the transparent title/info fields, so I changed it. The only think that bothers me is that it is higher then my titlebars and it covers upper parts of menu in maximixed windows. I'll try to downscale it.....
And now one feature request: would it be possible to add a volume slider? Or at least a volume indicator and +/- buttons. Or if you tell me how to do it, I could try it myself.
Thank you.
"Raven hereby releases not one, not two, but three new skins. There's a new version of Mini, which has scrolling enabled and features a simple 'stop' message. If someone wants more work to be done on it, please ask so.
Also included are two versions of Listen or Die. They are based off a popular anime-show, but this reference is only seen with the 'no-album-art' image in the full version. They are using a LOT of special functions that few people seem to ahve used as of yet. Tey are way more advanced than Mini/MiniScroll.
Miniscroll:
http://www.xs4all.nl/~vaas/Foobar/Mini-scroll.zip
Listen or Die:
http://www.xs4all.nl/~vaas/Foobar/Listen%20or%20Die.zip
Listen or Die Mini:
http://www.xs4all.nl/~vaas/Foobar/Listen%2...0Die%20Mini.zip
Thank you very much!"
(I used Raven's Mini as a basis)
I'm honored. Yeah, I made them, I finaly managed to get a forum account. If I may ask: what do the up/down arrows do? Change the display?
There's a storm on the loose, there's sirens in my head...
I think the link is broken.
Works for me o_O
Edit: use Right-click -> save
Edit 2: a new one, with more buttons and informations:
http://membres.lycos.fr/norbert/divers/miniview_os.rar
Edit 3: update -> now, when stopped, displays some text.
If you prefer a semi-transparent background, change background.jpg to bg.png
weird, in opera right clicking and going save doesn't work, but in ie it does.  huh.  anyway, great skin, i love it!
I created my first skin for foo_title:
You can download it here (7-zip compression). It is quite similar to foostick. It is slightly smaller (18px high) to fit my windows titlebar.
Unfortunately I don't know hot take a screenshot of it. I tried XnView and FastStone, but both programs refuse to capture it.
If you know how to produce a screenshot, please let me know.
If you want to modify any part of my skin and release it, please feel free to do it. It is completely my own work, except of a part of the XML which formates bitrate displaying. I took it and modified from my Columns UI .FCS. Unfortunately I can't remember where I got the original code from.
Edit: Is the size of my image acceptable or should I better crop/resize it?
Press the PrintScreen  key to copy the screen to clipboard and then Ctrl-V to paste in your graphics editor
The simplest solution is the best one
Btw. Do you have any idea why the last letter is cropped? It sometimes is and sometimes isn't.
Verify the size of your text layer ?
I can't check it directly: the download does not work for me (_very_ slow and then stopped)
When using Windows XP's silver theme this skin fits on the titlebar of the active window:
[a href=\"http://img160.imageshack.us/my.php?image=footitlepj2.jpg\" target=\"_blank\"] and I can't get the button to the right side (aling right) of the skin but on the left side it works.
EDIT: Found the command in two minutes... Not resize but activate
EDIT2: And the button works now. I don't know what i did different
