Topic: foo_uie_bookmarks (Read 263237 times) previous topic - next topic
Re: foo_uie_bookmarks
Reply #225
Hi @tanka , thanks for the plugin and for still giving support after 10 years!
Maybe I'm too dumb, but is there a way to remove a bookmark? Or manage bookmarks somehow?
Also, is there a way to a set a visible indicator or a column that shows which songs are bookmarked?
Appreciate your work! Thanks a lot!
Reply #226
@tanka , thank you for making and updating this! Too bad I can't use it - the latest version archive seems to be corrupted :[ Can you please fix it? I'd be eternally grateful. @enibra , maybe you could send me the plugin file? thx
Reply #227
I'm getting a bug where if i use more than one bookmark it will mess up the previous one's times.  If I have one for 0:15 and set a new one for 0:33, at some point the previous one will mess up and be a few seconds from the new one, like 0:17 or something.
Reply #228
Is the source code available for this plugin?  If it's been abandoned I can look into fixing it.
Reply #229
@tanka , ...Too bad I can't use it - the latest version archive seems to be corrupted :[ Can you please fix it?...
What's the one corrupted, please write down the link.
This is the only plugin this kind?
Reply #230
Is anyone who write a new plugin (bookmarks) for foobar 64bit?
Reply #231
^ Skip Track has basic bookmarking...
Reply #232
If this component works...
https://github.com/Paremo/foo_bbookmark
It should be relatively easy for someone who is interested (not me  :P ) to update it for 64bit. I see it uses modern list control code from the foobar2000 SDK which means dark mode can be enabled with a few lines of code.
edit:  original thread here - https://hydrogenaud.io/index.php?topic=118283.0
Reply #233
Does anyone know if the column header for foo_bookmarks 0.3.6 with foobar-2.0-x86 can be black with white text?
I have a dark mode setup for foobar for everything except the bookmarks column header.
This is what my setup looks like:
Reply #234
^ The component has to be rebuilt as the previous reply said. And as the reply before that said, if all you want is a bookmark position column, you can use Skip Track instead, and make a %bookmark% column in the default playlist which is already dark mode. (Edit: actually I think you can do that with this component too using %bookmarks% field, been a long time since I looked at it)
Reply #235
Thanks for the feedback.
Skip Track does more than I want and does not do everything Bookmarks does that I need.
I tried the updated Bookmarks for 64bit but the whole Bookmarks panel on the left, column heading and bookmarks list below, have a white background.
