Topic: foo_dsp_centercut (Read 95298 times) previous topic - next topic
foo_dsp_centercut
foo_dsp_centercut
Only one way to find out I guess.
foo_dsp_centercut
I should have said this back when I downloaded it: thanks for the recompile!
foo_dsp_centercut
Hi, I don't know if this plugin is still being developed, but would it be possible to implement another setting from the original CCGui?
What I'm talking about is the option 'Bass to sides' (and possible 'Dual mono center' too). I really would like the option of moving the bass to the sides in Foobar too, because I found it has quite an impact on the phase. Sides without the bass is always out of phase, while the other one is always IN phase! I prefer the Foobar version btw, because it also takes 32float files, where the CCGUI.exe doesn't...
Thanks in advance!
foo_dsp_centercut
I'm bumping this because this is the best component I could ever wished for. Not only am I finding this extremely useful for tabbing songs, but it also lets me hear melodies that are hard to hear when listening to the full mix.
I want to know how to reproduce this while using my DAW. What did you do to cut whatever is panned to the center and what's hard panned?
foo_dsp_centercut
Reply #32
Wow, thanks for that! I was especially amused by this:
Disclaimer: I'm not an audio researcher and am not familiar with the audio literature, so excuse me if I use the wrong terms or fail to acknowledge past work, as I am not familiar with existing advanced algorithms for vocal removal. I came up with this algorithm one day after a discussion about vector projection in lower-division math class, so I didn't do any research before devising the algorithm.
Must be nice to be able to make something like this as a lark while (apparently) knowing next to nothing about it! Modesty, eh?
foo_dsp_centercut
Well, I don't think you need much audio/DSP knowledge to come up with this algorithm.  What's more important is vector math etc. like he wrote.
"I hear it when I see it."
foo_dsp_centercut
Reply #34
Yeah, I’m sure you’re correct. It’s just that it still seems quite impressive to a layman like myself.
foo_dsp_centercut
Reply #35
Thread necromancy I know, but it's a real shame foo_dsp_centrecut seems to have vanished, the link in the op to the version for foobar2000 v1.x is dead
foo_dsp_centercut
Reply #36
Actually, following the trail showed me that the link in mudlord’s post has disappeared, presumably because of his current Group… of which I wasn’t aware until now.
But you’re in luck:
foo_dsp_centercut
Reply #37
The latest foobar is saying this is unsupported when I try to add it, any fix?
foo_dsp_centercut
Reply #38
Loads fine here.
foo_dsp_centercut
Reply #39
That's odd, it's working fine here now too. Hmm, must of been due to system updates and needing a restart.
foo_dsp_centercut
Reply #40
This one is handy! It cleans up a crackly mono LP (recorded in stereo) much better than a plain mono downmix, as you'd expect.
Re: foo_dsp_centercut
Reply #41
Hi! Any chance for update to foobar2000 2.0?
Reply #42
Attached is a simple recompile with 64-bit support included.
