Topic: [BUG] Multiple metadata fields not working (Read 2321 times) previous topic - next topic
To reproduce do the following:
1. Select an audio file in any playlist
2. In the context menu select 'Properties'
3. In the metadata tab double click in any existing tag or create a new one
4. Try to enter multiple fields separated by the ';' character
5. Save the metadata
When you invoke the multiple fields using %<field>% you don't get separated multiple fields but just one field containing everything.
Does the field name occur in the list at Preferences | Advanced | Display | Properties dialog | Multivalue fields?
Only fields in this list are split into multiple values with a semicolon.
that did the trick. thanks.
I have to say though that this way is not straightforward. Previous versions handled this better IMO.
There is something wrong....
When I apply the multiple tags first time it does not separate the entries. I have to edit them again and reapply for them to work.
Does anyone else have this problem?
Please give an example.
1. Included the STYLE field in the multivalued fields in the advanced properties and saved all preferences:
2. Selected all tracks from one album and included the values separated by a semicolon ';'
3. Applyed the changes and got this:
4. Re edited the field and added a space between the semicolon and the last value:
5. Applyed the changes and now it works:
sorry for bumping, but could anyone confirm if this is fixed in the new 0.9.3b3? Cannot test right now
Seems to be fixed here in 0.9.3b3, I haven't tested it in 0.9.3b2 so not sure there's this problem to begin with.
