Topic: Multiplex UIE's in one single panel (Read 45143 times) previous topic - next topic
There seems to be a bug with the albumart panel. The albumart preferences option in the context menu seems to be gone when the albumart panel is in a tab. I think it might be conflicting with the settings context option of the tabs uie.
Has anyone had any success using splitters inside a tab? Each tab appears to only handle objects 1 level deep. (i.e.: can see the tabs for playlist tabs but not it's playlist, can see a vertical or horizontal splitter but not any panels added on the splitter)
That's right. Same here.
You can use "Tabbed panel stack mod" as splitter, though, to get multi-level tabs. It works.
This really is a GREAT news, THANK YOU
Woot, thanks for this, you complete me.
whenever i switch between tabs, i have to click on the panel for the item to load. any ideas as to how to fix?
When I run foobar2000 normally, I get the context menu just fine, "Preferences..." and all.  When I run foobar2000 from the VC++ Express debugger, I get the following error message when I right-click on an album art panel placed within a tab:
HEAP[foobar2000.exe]: Invalid Address specified to RtlFreeHeap( 00D40000, 0012F1FC )
Windows has triggered a breakpoint in foobar2000.exe.
This may be due to a corruption of the heap, and indicates a bug in foobar2000.exe or any of the DLLs it has loaded.
The output window may have more diagnostic information
I get this same error message also when I place an Album List Panel, Buttons toolbar, or Spectrum Analyser toolbar in a tab and right-click either the panel itself or the tab.  Given the fact that this happens with more than component, I'm guessing it's not a bug with foo_uie_albumart specifically.  I wonder if it's related to the Columns UI SDK, because Track Info Panel didn't cause any errors, and it doesn't use the Columns UI SDK to display its context menu.
part deux: i just tried to fix it, and foo crashed.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 04277AF6h
Access violation, operation: read, address: 0003000Ah
Call path:
entry=>app_mainloop=>write config
Code bytes (04277AF6h):
04277AB6h:  8B 44 24 28 50 8B CE FF D2 8B 44 24 20 50 C7 44
04277AC6h:  24 40 FF FF FF FF E8 BF 97 FF FF 83 C5 01 83 C4
04277AD6h:  04 3B 6C 24 48 0F 82 46 FF FF FF 33 ED 39 6C 24
04277AE6h:  44 0F 86 C1 00 00 00 8D 49 00 8B 4B 18 8B 04 A9
04277AF6h:  8B 08 8B 11 8B 42 0C FF D0 8B 16 57 6A 10 50 8B
04277B06h:  02 8B CE FF D0 8B 4B 18 8B 04 A9 83 78 10 00 76
04277B16h:  05 8B 40 08 EB 05 B8 9F 83 28 04 57 50 8B CE E8
04277B26h:  F6 BA FF FF 33 C0 C7 44 24 28 3C 65 28 04 89 44
Stack (0012F4FCh):
0012F4DCh:  0167D050 7C9C93A0 77F643DD 7C9C93A0
0012F4ECh:  00000004 00000000 0167C55C 00000000
0012F4FCh:  B1D7233A 042B4DE0 042B4DE0 0012F5E0
0012F50Ch:  00000000 00000003 00000000 001536F5
0012F51Ch:  042864AC 0000000C 0428653C 00000000
0012F52Ch:  00000000 0012F554 04284890 FFFFFFFF
0012F53Ch:  04276665 00000003 00000000 B1D72376
0012F54Ch:  042B4DE0 00000013 0012F5D4 042846B9
0012F55Ch:  00000000 04359581 0012F5B8 0012F5AC
0012F56Ch:  91331A98 042B4DE0 048CE158 00000004
0012F57Ch:  00000014 001CAFE0 00000022 00000000
0012F58Ch:  00000000 00000000 00000000 00000000
0012F59Ch:  00000000 043CA770 00000000 00000000
0012F5ACh:  043862D0 77D4B800 00000460 04385D70
0012F5BCh:  048C9D10 00000080 043CA770 04359FEB
0012F5CCh:  007203CA 0012F56C 0012F650 04374872
0012F5DCh:  00000002 0012F65C 0435A1BC 005302FE
0012F5ECh:  001CAFE0 005302FE 048DC990 048CE158
0012F5FCh:  001CAFE0 0012F5C0 91331924 005302FE
0012F60Ch:  048DC220 00000000 00000014 001CAFE0
Registers:
EAX: 0003000A, EBX: 042B3CE8, ECX: 042B2578, EDX: 043C0600
ESI: 0012F5B8, EDI: 0012F5AC, EBP: 00000002, ESP: 0012F4FC
Crash location: "foo_uie_tabs", loaded at 04270000h - 04297000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004E6000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D2000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 763B0000h - 763F9000h
wbsys                            loaded at 66500000h - 6650A000h
wbhelp                          loaded at 66600000h - 66617000h
WBlind                          loaded at 66000000h - 6608F000h
WINMM                            loaded at 76B40000h - 76B6D000h
UXTHEME                          loaded at 5AD70000h - 5ADA8000h
msimg32                          loaded at 76380000h - 76385000h
MSCTF                            loaded at 74720000h - 7476B000h
foo_albumlist                    loaded at 00EA0000h - 00EE1000h
foo_amipwrapper                  loaded at 00F10000h - 00F36000h
foo_audioscrobbler              loaded at 00F60000h - 00F98000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_browser                      loaded at 01000000h - 01039000h
foo_cdda                        loaded at 01060000h - 01099000h
foo_common                      loaded at 010C0000h - 010FA000h
foo_converter                    loaded at 01120000h - 01184000h
foo_dbsearch                    loaded at 011B0000h - 0120C000h
foo_dsp_continuator              loaded at 01230000h - 01262000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_dsp_crossfeed                loaded at 01290000h - 012B4000h
foo_dsp_std                      loaded at 012E0000h - 01322000h
foo_history                      loaded at 01350000h - 0136C000h
foo_infobox                      loaded at 01390000h - 013CF000h
foo_input_shorten                loaded at 013F0000h - 0141E000h
foo_input_std                    loaded at 01440000h - 0153B000h
foo_lnk                          loaded at 01560000h - 01579000h
foo_midi                        loaded at 015A0000h - 01648000h
foo_navigator                    loaded at 01670000h - 01691000h
foo_out_asio                    loaded at 016C0000h - 016F0000h
foo_playcount                    loaded at 01710000h - 01738000h
foo_playlist_manager            loaded at 01760000h - 017A6000h
foo_playlist_tree                loaded at 017D0000h - 01836000h
foo_pqview                      loaded at 01860000h - 0187C000h
foo_prettypop                    loaded at 018A0000h - 018EE000h
mscoree                          loaded at 79000000h - 79045000h
MSVCR80                          loaded at 78130000h - 781CB000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
foo_random                      loaded at 03E60000h - 03E9F000h
foo_rgscan                      loaded at 03EA0000h - 03EE6000h
foo_run                          loaded at 03EF0000h - 03F1B000h
foo_sendtodevice                loaded at 03F40000h - 03F53000h
foo_uie_albumart                loaded at 03F70000h - 03FA3000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_uie_albumlist                loaded at 03FE0000h - 0401F000h
foo_uie_console                  loaded at 04040000h - 0405C000h
foo_uie_lyrics                  loaded at 04080000h - 040DE000h
WININET                          loaded at 771B0000h - 77256000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_uie_lyrics_panel            loaded at 04100000h - 04168000h
foo_uie_playlists_dropdown      loaded at 041B0000h - 041EA000h
foo_uie_quicksearch              loaded at 04200000h - 04245000h
foo_uie_tabs                    loaded at 04270000h - 04297000h
foo_uie_trackinfo                loaded at 042C0000h - 042EE000h
foo_ui_columns                  loaded at 04310000h - 043AB000h
foo_ui_std                      loaded at 043D0000h - 04427000h
foo_utils                        loaded at 04450000h - 04489000h
dciman32                        loaded at 73BC0000h - 73BC6000h
amip                            loaded at 04DC0000h - 04F6C000h
mswsock                          loaded at 71A50000h - 71A8F000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
DNSAPI                          loaded at 76F20000h - 76F47000h
winrnr                          loaded at 76FB0000h - 76FB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
mslbui                          loaded at 605D0000h - 605D9000h
DSOUND                          loaded at 73F10000h - 73F6C000h
VERSION                          loaded at 77C00000h - 77C08000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 042864ACh, location: "foo_uie_tabs", loaded at 04270000h - 04297000h
Address: 0428653Ch, location: "foo_uie_tabs", loaded at 04270000h - 04297000h
Address: 04284890h, location: "foo_uie_tabs", loaded at 04270000h - 04297000h
Address: 04276665h, location: "foo_uie_tabs", loaded at 04270000h - 04297000h
Address: 042846B9h, location: "foo_uie_tabs", loaded at 04270000h - 04297000h
Address: 04359581h, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 043862D0h, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 77D4B800h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetParent" (+000000D1h)
Address: 04385D70h, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 04359FEBh, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 04374872h, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 0435A1BCh, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 04374A4Fh, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 0435B578h, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 0435A89Ah, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 7C809F12h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "IsBadReadPtr" (+0000005Fh)
Address: 04374B2Dh, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 77D541E2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7475E548h, location: "MSCTF", loaded at 74720000h - 7476B000h
Address: 74730E78h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_UninitSystem" (+00000A0Fh)
Address: 77D484FCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D485A4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D48BD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 0437C8BCh, location: "foo_ui_columns", loaded at 04310000h - 043AB000h
Address: 77D4B3B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 77D4B3A7h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77D4C331h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D5418Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 00EB015Dh, location: "foo_albumlist", loaded at 00EA0000h - 00EE1000h
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D541B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D53FD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 77D54204h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B89Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetParent" (+0000016Ch)
Address: 77D4B903h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000049h)
Address: 774098B5h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0001DA8Bh)
Address: 7740A4C3h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0001E699h)
Address: 77409EADh, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0001E083h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 74730DE9h, location: "MSCTF", loaded at 74720000h - 7476B000h
Symbol: "TF_UninitSystem" (+00000980h)
Address: 77D4EAC1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D4EC03h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 77D61B4Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 77D5E097h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 00427CA9h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00427DB1h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004287F1h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B0380h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B287Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 004A892Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 7C917CB7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 0048842Eh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B90FCh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00403535h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004075EBh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004075F8h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0048CE6Bh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 01000000h, location: "foo_browser", loaded at 01000000h - 01039000h
Address: 0048B590h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B4080h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 10002D67h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000B7h)
Address: 004A30F3h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004289C7h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004D37B0h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0048B299h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004866B7h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004866B1h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A893Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A7000h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004D6C48h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A3208h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0048AA74h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0167C42Ch, location: "foo_navigator", loaded at 01670000h - 01691000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0048AADDh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004E6000h
Version info:
foobar2000 v0.9.2
UNICODE
Additional info:
Converter 1.0.1  (foo_converter)
History 0.2  (foo_history)
Run services 0.3.2  (foo_run)
FLAC decoder 1.1.0  (foo_input_std)
Audioscrobbler 1.3.2  (foo_audioscrobbler)
Tabbed panel modifyed 0.2.0  (foo_uie_tabs)
Default User Interface 0.9acc  (foo_ui_std)
Database search 1.3.1 beta 11  (foo_dbsearch)
Playlist tools 0.5.7  (foo_utils)
Special file info box 2.0.2  (foo_infobox)
Shell link resolver 1.1  (foo_lnk)
Play Count 1.9.2  (foo_playcount)
Common services 0.1  (foo_common)
MIDI synthesizer host 1.6  (foo_midi)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Album Art Panel 0.176a  (foo_uie_albumart)
Lyrics panel 0.34.1  (foo_uie_lyrics_panel)
Console panel 0.2  (foo_uie_console)
Continuator 0.4.0  (foo_dsp_continuator)
Pretty Popup 1.2.2  (foo_prettypop)
Randomized playlist entry 1.2.3  (foo_random)
Album List 3.2.0  (foo_albumlist)
Shorten decoder 0.4.2a  (foo_input_shorten)
Playlist Manager 1.0  (foo_playlist_manager)
CD Audio decoder 2.1  (foo_cdda)
AMIP Wrapper 0.90  (foo_amipwrapper)
Standard DSP array 1.0  (foo_dsp_std)
Music Browser 1.1.10 [Jun  9 2006 - 09:18:25]  (foo_browser)
ASIO support 1.1  (foo_out_asio)
Track info panel 0.8  (foo_uie_trackinfo)
Playlist Tree Panel 2.1.1 [Jun  8 2006 - 10:02:27]  (foo_playlist_tree)
ReplayGain Scanner 2.0.1  (foo_rgscan)
Lyric Show Panels 0.3.0.0  (foo_uie_lyrics)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Navigator 0.2  (foo_navigator)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Crossfeed 0.92  (foo_dsp_crossfeed)
Send to Device 1.0.4 [May 17 2006 - 13:21:17]  (foo_sendtodevice)
Quick Search Toolbar 2.6  (foo_uie_quicksearch)
Standard input array 1.0  (foo_input_std)
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Please use codebox for crashlogs.[/size]
Reply #32
Thanks, tanka!
hi
Gee... I seem to forget thanking tanka in my previous post... well, BLTN.
Anyways, a wishlist, if only the tabs can be on the side of the panels...
Even though, it's already coooooool  that I can put in other panels without sacrificing the playlist view's space.
Thanks again, tanka!
Reply #34
Since the original 0.8x thread 's been closed.
I would like to have custom caption titles so component album list isn't shown thrice as album list, even if different views are applied to component. Sadly all options are disabled even those who make sense.
nice to have it though
Reply #35
What do you mean no Custom Caption Titles? Just right-click on the tab, and choose rename.
Reply #36
Uh, right! Thank you, I expected it to be edited in layout section of columns ui instead
Reply #37
 I just do what the wiki for foobar2000 says: Right-click anything you haven't right-clicked before. You may be pleasantly surprised.
Reply #38
Is this download link not working for anyone else?
Reply #40
I came accross this link for an updated version of this plugin and this version allows you to stack splitters properly inside tabs, so you can build an entire layout inside a tab.
