Topic: toolej's FCS stuff. (Read 133396 times) previous topic - next topic
toolej's FCS stuff.
Reply #50
@nyzeo Post the pic u using for track info? pleaasee ??
thx
toolej's FCS stuff.
Reply #52
My first stab.  There's still a lot I want to do, but it's a start!
Big props to Tool for being the Foobar Pimp that he is.
toolej's FCS stuff.
Reply #53
how use png as a background ;/ ?
toolej's FCS stuff.
Reply #54
Could someone help me, i'm stuck and dont know what's wrong with my configs. As you can see the upper info don't show correctly and alubum art doesn't show.
toolej's FCS stuff.
Reply #55
Are you sure that top panel is a trackinfo_mod rather than a trackinfo?
How have you done your album art.
Iirc that old code is pretty buggy but meh, it worked for a lot of others so I don't see where the problem is.
hi
toolej's FCS stuff.
Reply #56
looks like you have the original track info panel when you need to use the latest trackinfo_mod panel
You also need to edit the Simageabs2 portion of the code to read your album art.....if its named cover and folder and the file extension needs to be considered. for exemple...
$imageabs2(84,84,,,,,5,3,'images\noalbum.png',)
$imageabs2(84,84,,,,,5,3,$replace(%path%,%filename_ext%,)folder.png,)
$imageabs2(84,84,,,,,5,3,$replace(%path%,%filename_ext%,)folder.jpg,)
$imageabs2(84,84,,,,,5,3,$replace(%path%,%filename_ext%,)cover.jpg,)
$imageabs2(84,84,,,,,5,3,$replace(%path%,%filename_ext%,)cover.png,)
$imageabs2(84,84,,,,,5,3,'images\artoverlay.png',)
My Name is Sean and I'm here to leech off your genius.
toolej's FCS stuff.
Reply #57
Okay, now i'm one step closer  I got right trackinfo_mod but now i cant get that part where buttons (marked area) are scaled, it doesnt move up or down, just sideways and i dont know how to scale those track infos and horizontal splitters. Layouttree is now identical with tool++'s (i've checked that 5 times)
toolej's FCS stuff.
Reply #58
Hello all there.
I'm a newbie in the use of Foobar.
I think this audio player is a great one, but I can't customise it.
In an other way, I don't find the good library(ies) to custome it.
Could I have some help from u ?
Where to fine these plug ins ?
- foo_uie_browser
- foo_uie_trackinfo
- foo_uie_albumart_msn
Thanks in advance.
toolej's FCS stuff.
Reply #59
Say you have a folder with all your album art there and you have it organised as %artist% - %album%.jpg just add
$imageabs2(84,84,,,,,5,3,C:Artwork folder\%artist% - %album%.jpg
to the list of picture locations....that should work i think
toolej's FCS stuff.
Reply #60
ok.... heres my album art code now :
$font(cambria,12,bold,164-171-179)
$drawrect(0,0,0,0,brushcolor-240-240-240 pencolor-null)
$imageabs2(84,84,,,,,5,3,'C:\Program Files\foobar2000\Images\noalbum.png',)
$imageabs2(84,84,,,,,5,3,'C:\Covers\%artist% - %album%.jpg',)
$imageabs2(84,84,,,,,5,3,'C:\Program Files\foobar2000\Images\artoverlay.png',)
$alignabs(92,40,$add(%_width%,-107),20,left,top)
$lower($if2(%album artist%,%artist%))
$alignabs(92,55,$add(%_width%,-107),20,left,top)
$font(Swis721 Cn BT D-Type,14,,138-145-153)
%album%$font(Swis721 Cn BT D-Type,14,bold,120-120-120)[ %date%]
$alignabs(92,71,$add(%_width%,-107),20,left,top)
$font(calibri,9,bold,153-153-153)[$upper(%genre%)]
and here's how foobar show's it :
toolej's FCS stuff.
Reply #61
i had some problems with the pics too, maybe it's a bad tag problem.
but now i use only the album name for the pics:
$imageabs2(84,84,,,,,5,3,$replace(%path%,%filename_ext%,)%album%.jpg,)
or $imageabs2(84,84,,,,,5,3,C:Artwork folder\%album%.jpg
i've exported the button.fcb for the play/pause but what to do with the other 'menu' button?
and what about those side and empty track info's?!
toolej's FCS stuff.
Reply #62
I'm using a highly modified version (I called EerieCream  ) of tool++s columnsUI config, which is a work-in-progress, and may even use certain codes of navigator suite and others (I simply have forgotten where I've taken them from).
Screenshot #1: +++
fcs-file (v.0.01): +++
It supports: mood-tag,rating (both album+track), playcount, replaygain (both), artist, composer, ensemble, etc.. as a compromise to both support popular music and classical, release date, remastered date, production date, media source, recording types, label name, isbootleg, isdemo, issingle, (sofficial) blah blah.
coloring is done based on mood, playcount, track- and album rating tags, most is customizable (see globals tab)
I'd like to hear your suggestions, though I know that there are bugs (sortof), there are none as of yet that disturb my foobar listing experience  Do whatever you like with it
toolej's FCS stuff.
Reply #63
I think i know where the problem is....i have this album art code now and it doesnt show the albums even if they are in albumtitle.jpg
$imageabs2(84,84,,,,,5,3,'C:\Program Files\foobar2000\Covers\%album%.jpg',)
When i changed the middle code to this
$imageabs2(84,84,,,,,5,3,'C:\Program Files\foobar2000\Covers\albumtitle.jpg',)
the code showed same album on all album cover art places. So problem is probably in tags? because program dont understand that %album% so is there any other code to describe album than %album%
toolej's FCS stuff.
Reply #64
as a test take one album.....open its properties and copy the text field in album and rename the corresponding picture file and paste the copied value in tthe new filename
Then look at the album in the playlist view...I can only thing that either your tags or maybe your pictures filenames arent matching.
(make sure you are using the %album% tag in the imageabs2 code)
toolej's FCS stuff.
Reply #65
I'm completely new to foobar. By completely new, I mean that I've only used WMP and Winamp in the past, with no skinning/scripting experience, and only downloaded foobar yesterday. If I can figure out how to go through your instructions, I'm sure others will figure it out soon enough.
Thanks a lot, toolej. You really help newcomers learn to customize their foobar. All I've done is use your setup, with glossy overlays. I will update future modifications once I start going through some tutorials.
Here's my very slight mod:
Thanks again, toolej! Much appreciated!
toolej's FCS stuff.
Reply #66
toolej,
Can you post the single column playlist settings for configurations shown in the first post?  Things like: row height, group height, item display, group display?
toolej's FCS stuff.
Reply #67
It's because the %album%/%artist%/etc variables are encased in apostrophes, so they don't get read as tags, but read literally as %album%/%artist%/etc...
In short, remove the apostrophes (single quotes), they aren't needed, and cause the variables/tags NOT to get evaluated.
toolej's FCS stuff.
Reply #68
toolej,
i used row hight 20 and group row 7 in single playlist coulums
toolej's FCS stuff.
Reply #69
Thanks for all the help everybody, now album art works
Does anybody know how to get picture in track info background? or how to change background color of album art/artist/album title
Just like in this picture http://nyzeo.free.fr/foobarz.jpg
toolej's FCS stuff.
Reply #70
Screenshot #1: +++
This guy knows his shit. PM him for help.
here they are :
hi
toolej's FCS stuff.
Reply #71
would anyone help me? i installed the skin and everything, but i coudnt play a single song! whats wrong!  , i been trying to fix this over the past 2 days but no luck... if someone can help that would be great! thanks
toolej's FCS stuff.
Reply #72
Stucked here too.
I have this same problem.
toolej's FCS stuff.
Reply #73
nice i got it to work pretty well.
one question: is there any way to have a column at the top to sort by artists alphabetically?
(for mods like this)
toolej's FCS stuff.
Reply #74
First of all thanks for a wonderful theme. It's beautiful. Though it wasn't easy to configure all the stuff
Still I have some problem with plugin trackinfo, both the top and the bottom freeze when I play any song:
Any suggestions?
Core (2006-11-25 14:21:34)
    foobar2000 core 0.9.4.2
foo_albumlist.dll (2006-11-25 18:49:06)
    Album List 3.2.0
foo_audioscrobbler.dll (2006-05-08 19:04:22)
    Audioscrobbler 1.3.2
foo_cdda.dll (2006-11-25 14:19:46)
    CD Audio Decoder 2.1.1
foo_converter.dll (2006-11-25 14:20:00)
    Converter 1.0.1
foo_dsp_std.dll (2006-11-25 14:20:12)
    Standard DSP array 1.0
foo_freedb2.dll (2006-08-29 19:43:04)
    freedb Tagger 0.5.2a
foo_input_std.dll (2006-11-25 14:19:14)
    FLAC Decoder 1.1.0
    Standard Input Array 1.0
    WMA Decoder 1.1
foo_lyricsdb.dll (2006-07-19 23:45:52)
    foo_lyricsdb 0.0.7 beta 4
foo_rgscan.dll (2006-11-25 14:18:18)
    ReplayGain Scanner 2.0.2
foo_ui_columns.dll (2006-11-22 13:05:24)
    Columns UI 0.1.3 beta 1v7
foo_ui_std.dll (2006-11-25 14:18:12)
    Default User Interface 0.9acc
foo_uie_albumart.dll (2006-10-15 13:57:16)
    Album Art Panel 0.2.5.1
foo_uie_albumart_msn.dll (2006-08-25 03:25:56)
    Album Art Panel Mod (MSN) 0.2.1_8
foo_uie_playlists_dropdown.dll (2006-06-09 13:49:24)
    Playlists Dropdown 0.5.7.5
foo_uie_quicksearch.dll (2006-10-15 18:56:24)
    Quick Search Toolbar 2.8j
foo_uie_single_column_playlist.dll (2006-11-24 21:31:56)
    Single Column Playlist Display 0.5.4 beta [Nov 24 2006 - 21:31:48]
foo_uie_trackinfo.dll (2006-09-20 19:45:06)
    Track info panel 0.8
foo_uie_trackinfo_mod.dll (2006-12-02 01:31:50)
    Track info panel mod 0.7.1 beta [Dec  2 2006 - 01:31:40]
