Topic: MPEG2 into MPEG1 (Read 4787 times) previous topic - next topic
MPEG2 into MPEG1
Hi. I have some MP3 files on computer that I want to listen to on my Sony MP3 player.
The audiofiles are on the PC are MP3 (MPEG-2 audio layer3)  ........but......
The MP3 player can only play MP3 (MPEG-1 Audio Layer3)
I don't care too much about loss of quality or increased file size as its just an Audio-book that I want to listen to. Someone sugested that I burn to CD - before ripping back to PC using the correct format.... but the trouble is its 20hours long!!
Does anyone know what I can do to convert them to the correct format and hopefully for free?
MPEG2 into MPEG1
MP3 is MPEG-1 layer 3 so your player should support it with no problems. almost every portable player supports MP3.
did you actually check if the files play on your device?
edit: spelling
Nothing but a Heartache - Since I found my Baby ;)
MPEG2 into MPEG1
Sorry Digga, but you are wrong. Lower bitrate MP3's are actually MPEG 2 (or MPEG 2.5) Layer 3.
        Sample Rates     Bitrates
MPEG-1  32, 44.1,  48    32, 40, 48, 56, 64, 80, 96, 112, 128, 160, 192, 224, 256, 320
MPEG-2  16. 22.05, 24    8,  16, 24, 32, 40, 48, 56, 64,  80,  96,  112, 128, 144, 160
Bonker - there's no need to burn them to CD, somebody told you a stupid method.
Just try recompress these files with LAME, which can read mp3 as an input (but first make sure you really can't play these files on your player).
Not really a Signature.
MPEG2 into MPEG1
MPEG-2 audio layer3
The MPEG-2 Audio part (defined in Part 3 of the standard), enhances MPEG-1's audio by allowing the coding of audio programs with more than two channels. Part 3 of the standard allows this to be done in a backwards compatible way, allowing MPEG-1 audio decoders to decode the two main stereo components of the presentation.
General MP3 decoder seems to support decoding MPEG-2 audio layer3.
MPEG2 into MPEG1
General MP3 decoder, yes. Sony MP3 decoder - who knows...
The problem might be with lower sample rates, not channel number.
MPEG2 into MPEG1
That's the problem.
I confirmed iPod nano plays 8 and 16kHz mp3.
But Sony officially support 32, 44.1 and 48kHz only.
MPEG2 into MPEG1
Thanks for all your quick replies.
I did try the audio on my MP3 plyer- twice......but although the tracks transfered onto it, they won't play.
what can I do then?  I take it that the audio is recoreded at too low a sample rate so my MP3 player wont play it??  Will LAME be able to rectify this and covert to a higher bit rate that the Sony MP3 player will be able to read?
MPEG2 into MPEG1
As already said, transcoding with resampling is the only way to play on Sony walkman.
LAME with --resample 32000 or SSRC prior to encoding would be good. I don't konw which is better.
MPEG2 into MPEG1
hmm I didn't know this. thanks for the info.
MPEG2 into MPEG1
You may try:
lame.exe --mp3input --resample 32000 -h -b 32 inputfile.mp3 outputfile.mp3
I don't know if --mp3input switch is mandatory, and maybe you would like to encode at higher bitrate (then you may try using -abr [bitrate] instead of -b [bitrate]).
