Topic: Track Info Panel Not Addable (Read 2028 times) previous topic - next topic
Hello, i´m new here, maybe i´m only to stupid to do it, but my problem is, that i´ve installed the new and stable version of Foobar2000 (V.0.9.2 Beta 4 or 5, i don´t know), everything is working properly, except for the Track info Panel, when i do a rightclick in the Layout menu on a Splitter and then click on Panels or something else, the Track info Panel isn´t there...i also installed it once again into the components folder, but it doesn´t work. Can someone help me?
Thx
P.S. My english is terrible, i know^^ i´m from germany.
Okay, i found the problem.
This happened to me when I had an old version of Columns UI. Make sure you have the latest.
hi
A lot of this "can't activate x component" problem is because you're not using compatible versions...
Yes Yes, thx to both of you  i found the problem very quickly and corrected it, now all is working perfect.
