Topic: Nero AAC, listening test :-) (Read 22485 times) previous topic - next topic
Reply #50
How do Codecs with VBR fit in with 128Kbps? to be fair to WMA it should be VBR 2 pass, not that it will win
Well, it would be a VBR/ABR test, except for atrac3. As Ivan already explained several times on the QuickTime 6.3 announcement thread, AAC CBR is almost ABR, due to the big bit reservoir.
Reply #51
If you take WMA9, be sure to use both Std and Pro.
As I understand, there's no difference between them.
WMA pro is just WMA for high bit depths, high sampling rates and multichannel. It isn't even possible to encode a 44100/stereo/16bit sample with it.
There's a difference between them. WMApro is able to encode :
• stereo files
• 44100 hertz files
• at low bitrate, using VBR settings
Reply #52
? stereo files
? 44100 hertz files
? at low bitrate, using VBR settings
I couldn't reach these settings on CoolEdit 2.1 WMA output plugin.
What program should I use to encode with WMA pro?
What what's the difference? Slower encoding, better quality?
Reply #53
The profile options for WMApro are 2 channel only if is 24 bit, or 16 bit only if is 6 channel.
Reply #54
? stereo files
? 44100 hertz files
You don't have to worry about WMA just yet, do you?  Isn't this for a future test?  But WMA9 Pro is different from WMA9 standard -- it sounds better, at least on one sample I tried at 64 kbit/s.  You can access it from within the Windows Media Encoder.  Also probably from Spoon's dBPowerAmp (although I haven't checked to make sure).  It's kind of a maze trying to figure out just how to make WME give you access to the WMA9 Pro settings.
ff123
