Topic: Compression/Quality ratio bar (for trackinfo panel) (Read 19808 times) previous topic - next topic
2 tool++
can you explain please what "infosexual" means?  Maybe i'm having infosexual layout without even knowing it?
(is it connected to the colours in some twisted way?)
A term I made up for layouts that have boxes of stuff everywhere - not necessarily a bad thing but I think a few users do have a lot of unnecessary stuff just to look cool.
Not necessarily cluttered, but by infosexual I just mean layouts that have a lot of information everywhere.
But that aside, this is a really good idea, hats off
hi
Nice term,gotta remember it and use it to confuse people
PS The good news are that my layout is probably not infosexual
Favourite artist:CD-R
Favourite album:700MB
Where in the code can I change the font and text color of the Remark (Insane Quality  part).  I want the text to remain White and 12 points. I changed it in the panel but that only seemed to change the Bitrate.
THX
THX
Correct me if i'm wrong,but i believe "live"  font size changing inside trackinfo panel is still impossible in current version,you have to set font definitions for the whole panel in "settings" tab.
THX
I did that but only the word "Bitrate" changed.  The words "Insane Quality" are still grey.  I have a darker background and these terms don't show up unless I hit "CD Quaility"  then they turn white.  So,  "live" changing, as you call it, is occuring.
BTW,  I'm running beta 5 with all available plugin updates.
2 ftboomer:
Suggestion:in my code the bitrate line goes to output first,then next line is the bar and the next one is quality
so i believe you should repeat the font sizing command after the bar is displayed (just before
"$ifequal($get(verbal_mode),1,...")
Question:How do you do it?
Here's what I have.  I actually modified it to be centered horizontally:
Bitrate 400Kbps  (BAR)  CD Quality
Looking at this,  what would I change to make "CD Quality" section remain white text, no matter which quality level is displayed?
//22-cahracter long version
$if(%isplaying%,
//change to the desired symbol
$puts(symbol,$char(9608))
//1-bar+comment,0-bar only
$puts(verbal_mode,1)
Bitrate:$info(bitrate)KB/s
$puts(precent,$div($mul(100,$info(bitrate)),1411))
$puts(precent,$muldiv($get(precent),20,34))
$puts(yellowtr,$muldiv(250,$get(precent),8))
$puts(greentr,$muldiv(250,$get(precent),20))
$puts(redsh,$muldiv(100,$get(precent),8))
$puts(greensh,$muldiv(100,$sub($get(precent),8),12))
$if($greater(9,$get(precent)),
$transition($repeat($get(symbol),$get(precent)),$rgb(250,0,0),$rgb(250,$get(yellowtr),0))
$transition($repeat($get(symbol),$sub(8,$get(precent))),$rgb(100,$get(redsh),0),$rgb(100,100,0))
$transition($repeat($get(symbol),12),$rgb(100,100,0),$rgb(0,100,0))
$rgb(100,100,100)$repeat($get(symbol),2)
$if($and($greater($get(precent),8),$greater(20,$get(precent))),
$transition($repeat($get(symbol),8),$rgb(250,0,0),$rgb(250,250,0))
$transition($repeat($get(symbol),$sub($get(precent),8)),$rgb(250,250,0),
$rgb($sub(250,$get(greentr)),$get(greentr),0))
$transition($repeat($get(symbol),$sub(20,$get(precent))),$rgb($sub(100,$get(greensh)),100,0),
$rgb(0,100,0))
$rgb(100,100,100)
$if($greater($get(precent),20),
$transition($repeat($get(symbol),12),$rgb(250,250,0),$rgb(0,250,0))
$rgb(250,250,250)$repeat($get(symbol),2)
$if($greater(161,$info(bitrate)),'Poor quality')
$if($and($greater($info(bitrate),160),$greater(201,$info(bitrate))),'  Average quality')
$if($and($greater($info(bitrate),200),$greater(251,$info(bitrate))),'  Good quality')
$if($and($greater($info(bitrate),250),$greater(321,$info(bitrate))),'  Excellent quality')
$if($and($greater($info(bitrate),320),$greater(501,$info(bitrate))),'  Insane quality')
$if($greater($info(bitrate),500),'  CD quality'),
Reply #32
$if(%isplaying%,
$rgb(0,100,0))
$rgb(100,100,100)
$rgb(250,250,250)
Copy/Paste This code
Thanks Russell777,  just so I can learn,  where and what did you change.
Reply #34
See the image:
[a href="http://img121.imageshack.us/my.php?image=136zs.png" target="_blank"]
PS sorry i got  confused alittle,it wasn't your question
Reply #35
can you guys use the CODEBOX tag instead of CODE so that the codes dont end up cluttering the page? thanks
nice code, btw
Reply #36
btw, animated ratio bar for VBR is very nice.
for compatibility with CBR $info(bitrate) can be replaced with $if2(%bitrate_dynamic%,%bitrate%)
try it...
Reply #37
I've created my own version to improve the customisability.
Just like the one by Russell777, whom I thank for the original idea, it draws a quality bar from color1 to color2 to color3, which are configurable and set to red, yellow, and green by default. You can define where the second color is located in the bar (variable "middle", in percent) to make the red..yellow area thinner or wider. The length of the whole bar is changeable, too. The amount of black (or any other background color) being blended into the dimmed parts can be adjusted using the variable "dimming" (in percent).
It's possible to set the bitrate required to get a completely filled bar. You can decide whether the display should change for variable bitrate tracks or not. For losslessly encoded files, a completely filled bar will always be displayed regardless of the bitrate. Furthermore, It's possible to add a "lossless" indicator at the end with an adjustable length (default: 3), which uses the fourth color (set to white by default).
// configuration
$puts(length,25)
$puts(middle,30%)
$puts(symbol,$char(9610))
$puts(color1,$rgb(255,0,0))
$puts(color2,$rgb(255,255,0))
$puts(color3,$rgb(0,255,0))
$puts(dimming,30%)
$puts(blending_color,$rgb(0,0,0))
$puts(maximum_bitrate,320)
$puts(dynamic_bitrate,0)
$puts(lossless_indicator,3)
$puts(color4,$rgb(255,255,255))
// processing
$puts(color1_dimmed,$blend($get(blending_color),$get(color1),$get(dimming),100))
$puts(color2_dimmed,$blend($get(blending_color),$get(color2),$get(dimming),100))
$puts(color3_dimmed,$blend($get(blending_color),$get(color3),$get(dimming),100))
$puts(color4_dimmed,$blend($get(blending_color),$get(color4),$get(dimming),100))
$if($strcmp($info(encoding),lossless),$puts(lossless,1))
$puts(percent,$min(100,$muldiv($if($strcmp($get(dynamic_bitrate),1),%bitrate%,$info(bitrate)),100,$get(maximum_bitrate))))
$if($get(lossless),$puts(percent,100))
$puts(position,$muldiv($get(percent),$get(length),100))
$puts(middle_position,$muldiv($get(middle),$get(length),100))
$puts(normal_bar,
$transition($repeat($get(symbol),$get(middle_position)),$get(color1),$get(color2))
$transition($repeat($get(symbol),$sub($get(length),$get(middle_position))),$get(color2),$get(color3)))
$puts(dimmed_bar,
$transition($repeat($get(symbol),$get(middle_position)),$get(color1_dimmed),$get(color2_dimmed))
$transition($repeat($get(symbol),$sub($get(length),$get(middle_position))),$get(color2_dimmed),$get(color3_dimmed)))
// adjustments for color codes in variables
$puts(normal_bar,$replace($get(normal_bar),$char(3)$char(3),))
$puts(dimmed_bar,$replace($get(dimmed_bar),$char(3)$char(3),))
$puts(color_code_length,$div($strrchr($get(normal_bar),$get(symbol)),$get(length)))
$puts(position,$mul($get(position),$get(color_code_length)))
$puts(length,$mul($get(length),$get(color_code_length)))
// output
$left($get(normal_bar),$get(position))
$substr($get(dimmed_bar),$add($get(position),1),$get(length))
$if($get(lossless),$get(color4),$get(color4_dimmed))
$repeat($get(symbol),$get(lossless_indicator))
$rgb()
Please don't quote the whole code to avoid old versions floating around in case I make some changes.
Enjoy!
