Topic: Compression/Quality ratio bar (for trackinfo panel) (Read 19230 times) previous topic - next topic
 So here it comes for all of you who going crazy about some extra info:
Compression\quality bar for trackinfo panel
What it does:it visualizes the compression of the music file you're listening to+tells you what quality is it.
It's better to have it in separate trackinfo panel,this way you'll be able to set the font and font size without
messing up your existing trackinfo design,but again it's optional and up to you.
(The font you see at the image is Lucida Sans Unicode 8pt)
$if(%isplaying%,
//change to the desired symbol
$puts(symbol,$char(9610))
//1-bar+comment,0-bar only
$puts(verbal_mode,1)
Bitrate:$info(bitrate)KB/s$char(10)
$puts(precent,$div($mul(100,$info(bitrate)),1411))
$puts(yellowtr,$muldiv(250,$get(precent),13))
$puts(greentr,$muldiv(250,$get(precent),34))
$puts(redsh,$muldiv(100,$get(precent),13))
$puts(greensh,$muldiv(100,$sub($get(precent),13),24))
$if($greater(14,$get(precent)),
$transition($repeat($get(symbol),$get(precent)),$rgb(250,0,0),$rgb(250,$get(yellowtr),0))
$transition($repeat($get(symbol),$sub(13,$get(precent))),$rgb(100,$get(redsh),0),$rgb(100,100,0))
$transition($repeat($get(symbol),21),$rgb(100,100,0),$rgb(0,100,0))
$rgb(100,100,100)$repeat($get(symbol),3)
$if($and($greater($get(precent),13),$greater(35,$get(precent))),
$transition($repeat($get(symbol),13),$rgb(250,0,0),$rgb(250,250,0))
$transition($repeat($get(symbol),$sub($get(precent),13)),$rgb(250,250,0),
$rgb($sub(250,$get(greentr)),$get(greentr),0))
$transition($repeat($get(symbol),$sub(34,$get(precent))),$rgb($sub(100,$get(greensh)),100,0),
$rgb(0,100,0))
$rgb(100,100,100)
$if($greater($get(precent),34),
$transition($repeat($get(symbol),21),$rgb(250,250,0),$rgb(0,250,0))
$rgb(250,250,250)$repeat($get(symbol),3)
$ifequal($get(verbal_mode),1,
$char(10)
$if($greater(161,$info(bitrate)),'Poor quality')
$if($and($greater($info(bitrate),160),$greater(201,$info(bitrate))),'Average quality')
$if($and($greater($info(bitrate),200),$greater(251,$info(bitrate))),'Good quality')
$if($and($greater($info(bitrate),250),$greater(321,$info(bitrate))),'Excellent quality')
$if($and($greater($info(bitrate),320),$greater(501,$info(bitrate))),'Insane quality')
$if($greater($info(bitrate),500),'CD quality'),
It works for me,but if you have problems with it plese tell me,enjoy
P.S. if i'll get a nice feedback i'll also write a column version of this code  but feel free to do it yourself
Favourite artist:CD-R
Favourite album:700MB
You need to switch the [/code] and [code] to make a codebox.
Is over the of = % over 100
Thanks, nice idea. I will definetly use it!
Columns version.This way you can tell the quality of all the files in your playlist without even playing them.
Create a new column and copy paste this code into "style" tab,just remember to check the
"use custom style spec" box for this column in the display tab just put any character you like
(i used $char(9608) with Franklin gothic medium font)
[a href="http://img243.imageshack.us/my.php?image=22229pl.png" target="_blank"]
Hey could you please post your whole track info config?
Hmm,i'm really surprised somebody would like to have my config (it's not so fancy like the others)
$puts(AltColour,$rgb(126,16,16))
$puts(pbarColour1,$rgb(126,16,16))
$puts(pbarColour2,$rgb(170,170,170))
$if(%_isplaying%,
$get(pbarColour2)'Codec:'$rgb()
$if($strcmp(%codec%,'ATSC A/52'),'            Dolby Digital AC3',
$if($info(lame_version),'            Lame MP3',
$if($strcmp(%codec%,'PCM'),'            PCM uncompressed',
$if($stricmp($ext(%_path%),ogg),'           Ogg '%codec% '('$cut($info(tool),9)')',
'           ' %codec%)))) [$info(codec_profile)]
$char(10)
$get(pbarColour2)'Encoding:       '$rgb()$caps($info(encoding))
$if($stricmp($codec(),Musepack) ,' [VBR]'  $puts(Avg,$info(bitrate)))
$if($stricmp($codec(),Mp3) ,$if($not(%__extrainfo%),' [CBR]',
' [VBR]'$puts(Avg,$info(bitrate))),)
$if($stricmp($codec(),vorbis),' [ABR]'$puts(Avg,$info(bitrate)))
$if($stricmp($info(encoding),'lossless'),' '$info(bitspersample)' bit/sample',)
$char(10)
$get(pbarColour2)'Bitrate:         ' $rgb()[' '%bitrate%' kb/s']
$if($get(Avg),' ('$get(Avg)' avg'[','$info(bitrate_nominal)' nom']')')
$char(10)
$get(pbarColour2)'Samplerate:   '$rgb()[%samplerate%' Hz']$char(10)
$get(pbarColour2)'Mode:           '$rgb()$ifgreater(%channels%,2,' '%channels%' channels',
$if($stricmp(%codec%,mp3),$caps('  '%__mp3_stereo_mode%),'  '$caps(%channels%)))
$char(10)
$get(pbarColour2)'Playing:          '$rgb()%_time_elapsed%[' of '%_time_total%]
$puts(precent,$sub(100,$div($mul(100,$info(bitrate)),1411)))
$char(10)
$get(pbarColour2)'Com/Q:          '$rgb(250,250,250)
$if($not($or($stricmp(%codec%,'pcm'))$stricmp(%codec%,'CDDA')),
$puts(qwerty,$div($mul(250,$sub(91,$get(precent))),35))
$puts(qwert,$add($get(qwerty),155))
$rgb()$repeat($char(171),4)
$transition($repeat($char(171),$mul($sub($get(precent),67),1)),$rgb(0,250,0),$rgb($sub(250,$get(qwerty)),$get(qwert),0))
$puts(show,$sub(1000,$muldiv(1000,$info(bitrate),1411)))
$puts(rest,$substr($get(show),3,3))
$substr($get(show),1,2)
$if($greater($get(rest),0),'.'$get(rest),)'%',
$rgb()'Uncompressed media')
$char(10)
$progress2(%_time_elapsed_seconds%,%_time_total_seconds%,
33,
$get(pbarColour1)$char(9679),$get(pbarColour2)$char(9679)
),$char(10)$char(10)
$char(10)$get(pbarColour2)'                        No data to display')
Nothing fancy with black, white and red elements is exactly what I need. Thanks!
Not to sound like a dick, but this is pretty pointless. Even if all of your music was encoded in the same exact format with the same exact encoder of the same exact version, it would still be impossible to simply use bit rate as an indicator of 'quality'.
For example, it's perfectly conceivable that one lossless file (let's say encoded in Monkey's Audio) will have a good compression ratio and result in maybe a 700 kbps file, whereas another lossless file (let's say encoded in SHN) will have a worse compression ratio and result in maybe a 1000 kbps file. (I'm making the numbers up, but you get the idea.) Although the SHN would have a significantly higher bit rate, both files are the same quality.
And that doesn't even get into comparisons between lossy codecs -- you can not assume that, e.g., a 320-kbps Xing-encoded MP3 is 'better quality' than a 192-kbps LAME-encoded MP3.
Thats why the color shades changes only in the range of lossy formats,after which it doesn't make any difference,it's lossless and displayed in solid white colour.
P.S. Later on when i'll have some time i gonna do a little studying about formats and their quality
factors and add the correction to the colour sheme.For example the mp3 and mpc file with same bitrate
won't be displayed in the same colour.
P.S.S. BTW it's almost impossible to dermine what file have better quality by technical measurements
that's why blind listening tests are performed (where most of the testers cannot tell if there's any difference)
that's why i assumed that the bitrate is the only possible way to determine quality in more or less optimal way,but if there's others please point me out
Very creative idea, thanks
And if you believe theres not a chance to die...
Thats waaay cool, but is there any way to make it not so long?
This is pretty cool, man.  Cheers.
Using the default font makes it alot smaller.
You have two options:
1-Choose smaller symbol
2-Tell me what length do you want it to be
Do you know if there are any symbols like the one used in that script in other fonts? Id like kind of a small font. My current trackinfo panel is tahoma 8pt and id like something about that size and looks good.
I'm using @Arial Unicode MS 8pt and it is nice sized and look quite good.
Well,sorry to tell you but that kind of symbol is commonly found in almost every font except Tahoma.
Tip:use ../WINDOWS/system32/charmap.exe to find a font that looks nice and also contains the symbol
you like
you like
Alright, ive settled on Arial 8pt. Can you make the bar 22 charaters long with no spaces between them?
Thanks a bunch!
Thanks a bunch!
You mean like this?
//22-cahracter long version
$if(%isplaying%,
$puts(symbol,$char(9608))
$puts(precent,$muldiv($get(precent),20,34))
$puts(yellowtr,$muldiv(250,$get(precent),8))
$puts(greentr,$muldiv(250,$get(precent),20))
$puts(redsh,$muldiv(100,$get(precent),8))
$puts(greensh,$muldiv(100,$sub($get(precent),8),12))
$if($greater(9,$get(precent)),
$transition($repeat($get(symbol),$sub(8,$get(precent))),$rgb(100,$get(redsh),0),$rgb(100,100,0))
$transition($repeat($get(symbol),12),$rgb(100,100,0),$rgb(0,100,0))
$rgb(100,100,100)$repeat($get(symbol),2)
$if($and($greater($get(precent),8),$greater(20,$get(precent))),
$transition($repeat($get(symbol),8),$rgb(250,0,0),$rgb(250,250,0))
$transition($repeat($get(symbol),$sub($get(precent),8)),$rgb(250,250,0),
$transition($repeat($get(symbol),$sub(20,$get(precent))),$rgb($sub(100,$get(greensh)),100,0),
$rgb(0,100,0))
$rgb(100,100,100)
$if($greater($get(precent),20),
$transition($repeat($get(symbol),12),$rgb(250,250,0),$rgb(0,250,0))
$rgb(250,250,250)$repeat($get(symbol),2)
$char(10)
For Arial 8pt use $char(9608)
Thanks a bunch!
You mean like this?
Oh dude, thats perfect! Thank you so much!
Thats a pretty radical bar, nice idea - I'll probably adapt this if I ever make infosexual layout like I used to.
hi
2 tool++
can you explain please what "infosexual" means?  Maybe i'm having infosexual layout without even knowing it?
(is it connected to the colours in some twisted way?)
I think it means you're destroying the sanctity of foobar.
Well,speaking of sanctity i think that every custom made modification is "destroing" it.
If you wish to stick to sanctity you should not change anything and leave things as they are,but wasn't
Foobar created the way it was just so people could modify it?
