Topic: foo_run 0.3.8 (Read 489669 times) previous topic - next topic
foo_run 0.3.7
Reply #125
You should be able to set the runservice path box to something like:
x:\path\to\player.exe /play
Remember that if you are going to link a button to this service, set the item group to "Current playlist selection" when you set up the button.
I cannot for the life of me find this setting.
I have set foo run with the correct x:\path\to\player.exe /play for all the buttons but all it does is blank my playlist & bring up the error message box.
Any help would be appreciated.
Cheers
foo_run 0.3.7
Reply #126
There's seems to be a problem with paths that contains "()" symbols,for example i was trying to set a command for batch rename in Irfanview:
"C:\Program Files(x86)\IrfanView\i_view32.exe$replace(%path%,%filename_ext%,*.png)
/convert=$replace(%path%,%filename_ext%,$d.png)"
What it does it opens C:\Program files directory (on WinXP x64 there are Program Files(x86) and Program Files
directories all together),so as i understand it only executes the command till it meets "()" symbols,any ideas on what symbol i could replace the "()" with to get it working?TIA.
Favourite artist:CD-R
Favourite album:700MB
foo_run 0.3.7
Reply #129
Can somebody help me on this:
I'm trying to implement a command that will run Irfanview image conversion from foobar to rename any present image to "%directoryname%.png".Now the problem is the image paths contain spaces and therefore
must be enclosed with "",but when i'm trying to add those it screws up the whole thing.Any help appreciated.
"C:\Program Files '('x86')'\IrfanView\i_view32.exe $lower($replace(%path%,%filename_ext%,*.png)) /convert=$lower($replace(%path%,%filename_ext%,%directoryname%.png))"
foo_run 0.3.7
Reply #130
$char(34) should work, to create ".
How about just using cmd /c ren, eg.
cmd /c ren $char(34)$lower($replace(%path%,%filename_ext%,*.png))$char(34) $char(34)$lower($replace(%path%,%filename_ext%,%directoryname%.png))$char(34)
foo_run 0.3.7
Reply #131
It worked!Thanks a ton!
foo_run 0.3.7
Reply #132
Where are foo_run's settings located? how can I manually edit/delete them?
I've made a change to on e foo_run command a few hours ago, and all of a sudden I can't run Foobar unless I remove the component.
If I try to run it with foo_run.dll installed, I get this crash message:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 044E606Ah
Access violation, operation: read, address: 00000004h
Call path:
entry=>user_interface::init
Code bytes (044E606Ah):
044E602Ah:  4C 24 0C 8B 01 FF 10 85 C0 75 14 68 7C FC 4F 04
044E603Ah:  FF 74 24 14 E8 FD BD FF FF 84 C0 59 59 74 19 8B
044E604Ah:  4C 24 04 8B 01 6A FF 68 60 D7 4F 04 FF 50 08 8B
044E605Ah:  44 24 08 83 20 00 B0 01 C2 10 00 A1 00 47 50 04
044E606Ah:  8B 40 04 8D 48 18 8B 01 FF 20 8B 44 24 04 56 57
044E607Ah:  BE 6C D6 4F 04 8B F8 A5 A5 A5 A5 5F 5E C2 04 00
044E608Ah:  32 C0 C3 6A 08 E8 F7 56 00 00 85 C0 59 74 0F 8B
044E609Ah:  4C 24 04 C7 00 10 D7 4F 04 89 48 04 EB 02 33 C0
Stack (0012E5B0h):
0012E590h:  7FFDF000 EC58B518 EC58AEB4 00000001
0012E5A0h:  EC58B11C 0000003B 00000083 00782B38
0012E5B0h:  04A6B80C FB72320F 0012E6C8 069A3D1C
0012E5C0h:  00000000 0012E5D8 77D4882A 0000044D
0012E5D0h:  00000020 75D1DD87 4AAC9E48 25AAA98A
0012E5E0h:  BD5AC0D6 00000000 04AA6320 00000000
0012E5F0h:  00000000 00000000 04AE0000 0012E63C
0012E600h:  7C90EE18 7C910570 FFFFFFFF 00000001
0012E610h:  0001C771 00000004 0012E574 04A7C790
0012E620h:  04AA5D44 04AED738 0000001C 0000000B
0012E630h:  04524100 00000022 003D9BD8 04504748
0012E640h:  04A7C790 00000000 0012E6AC 04A93953
0012E650h:  00000004 0012E6B8 04A6C7B0 069A3D1C
0012E660h:  069A3D2C 0012E6C8 00000001 0012E6C8
0012E670h:  069A3D10 04A6D920 0012E6C8 77D4B8BA
0012E680h:  04AEAED0 04A6DCCD 0012E6C8 FB7232E3
0012E690h:  0012E918 04AEAED0 0012E918 00000000
0012E6A0h:  00000000 00000000 00000000 0012E784
0012E6B0h:  04A93C4A 00000004 0012E790 0004067C
0012E6C0h:  00000083 00000000 04AA5D44 069A04F0
Registers:
EAX: 00000000, EBX: 00000000, ECX: 04524100, EDX: 04520608
ESI: 04524100, EDI: 0012E6C8, EBP: 0012E654, ESP: 0012E5B0
Crash location: "foo_run", loaded at 044E0000h - 0450B000h
Loaded modules:
foobar2000   loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F5000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt   loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 77D40000h - 77DD0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1D5000h
ole32 loaded at 774E0000h - 7761D000h
shared   loaded at 10000000h - 1002A000h
comdlg32 loaded at 763B0000h - 763F9000h
LPK   loaded at 629C0000h - 629C9000h
USP10 loaded at 74D90000h - 74DFB000h
UnlockerHook loaded at 003E0000h - 003E4000h
foo_abx   loaded at 009E0000h - 00A14000h
foo_ac3   loaded at 00A30000h - 00A5C000h
foo_adpcm loaded at 00A80000h - 00AD2000h
foo_AdvancedControls loaded at 00B00000h - 00B31000h
foo_alarm loaded at 00B50000h - 00B6C000h
foo_albumlist loaded at 00B90000h - 00BD7000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_albumlist_autoupdate loaded at 00C00000h - 00C17000h
foo_audioscrobbler   loaded at 00C40000h - 00C70000h
WS2_32   loaded at 71AB0000h - 71AC7000h
WS2HELP   loaded at 71AA0000h - 71AA8000h
foo_autoplaylist loaded at 00C90000h - 00CC2000h
foo_browser   loaded at 00CF0000h - 00D2B000h
foo_burninate loaded at 00D50000h - 00D86000h
VERSION   loaded at 77C00000h - 77C08000h
foo_cdda loaded at 00DB0000h - 00DE6000h
foo_channel_mixer loaded at 00E10000h - 00E3B000h
foo_common   loaded at 00E50000h - 00E8A000h
foo_converter loaded at 00EB0000h - 00F19000h
foo_dbsearch loaded at 00F40000h - 00F9C000h
foo_dsp_continuator   loaded at 00FC0000h - 00FF2000h
foo_dsp_std   loaded at 01020000h - 01061000h
foo_dsp_vlevel   loaded at 01090000h - 010B4000h
foo_dumb loaded at 010E0000h - 0113F000h
foo_explorer loaded at 01160000h - 01178000h
foo_freedb2   loaded at 011A0000h - 011E0000h
foo_freedb2_fix   loaded at 01200000h - 01215000h
foo_gep   loaded at 01240000h - 012D8000h
MSIMG32   loaded at 76380000h - 76385000h
foo_highlightplaying loaded at 01300000h - 01321000h
foo_infobox2 loaded at 01350000h - 0138E000h
foo_input_dts loaded at 013B0000h - 01415000h
foo_input_monkey loaded at 01440000h - 01489000h
foo_input_shorten loaded at 014B0000h - 014DE000h
foo_input_std loaded at 01500000h - 01614000h
foo_lnk   loaded at 01640000h - 01659000h
foo_lock loaded at 01680000h - 01699000h
foo_lunar2   loaded at 016C0000h - 016E2000h
foo_managedWrapper   loaded at 01710000h - 017B2000h
mscoree   loaded at 79000000h - 79045000h
MSVCR80   loaded at 78130000h - 781CB000h
MSVCP80   loaded at 7C420000h - 7C4A7000h
msvcm80   loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D1000h
mscorlib.ni   loaded at 790C0000h - 79BA6000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh   loaded at 0FFD0000h - 0FFF8000h
System.ni loaded at 7A440000h - 7ABFE000h
System.Drawing.ni loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni   loaded at 7AFD0000h - 7BC56000h
foo_masstag   loaded at 03DD0000h - 03E20000h
foo_menu_addons   loaded at 03E40000h - 03E50000h
foo_midi loaded at 03E60000h - 03F08000h
foo_osd   loaded at 03F30000h - 03F65000h
foo_osd2 loaded at 03F90000h - 03FC6000h
gdiplus   loaded at 4EC50000h - 4EDF3000h
foo_playcount loaded at 04000000h - 04028000h
foo_playlist_bind loaded at 04050000h - 04075000h
foo_playlist_manager loaded at 04090000h - 040D6000h
foo_playlist_tree loaded at 04100000h - 04163000h
foo_pqview   loaded at 04190000h - 041AC000h
foo_prettypop loaded at 041D0000h - 0421D000h
foo_preview   loaded at 042D0000h - 042F1000h
foo_psf   loaded at 04300000h - 043E2000h
foo_random   loaded at 04410000h - 0444F000h
foo_rgscan   loaded at 04470000h - 044B8000h
foo_run   loaded at 044E0000h - 0450B000h
foo_sendtodevice loaded at 04530000h - 04542000h
foo_sic   loaded at 04560000h - 045B7000h
foo_sid   loaded at 046E0000h - 04762000h
foo_tradersfriend loaded at 04790000h - 047CD000h
foo_uie_albumart loaded at 047F0000h - 04827000h
foo_uie_albumlist loaded at 04850000h - 0488F000h
foo_uie_explorer loaded at 048B0000h - 048ED000h
UxTheme   loaded at 5AD70000h - 5ADA8000h
foo_uie_playlists_dropdown   loaded at 04910000h - 0494A000h
foo_uie_quicksearch   loaded at 04970000h - 049B8000h
foo_uie_trackinfo loaded at 049E0000h - 04A0E000h
foo_ui_columns   loaded at 04A30000h - 04ACB000h
foo_ui_std   loaded at 04AF0000h - 04B47000h
foo_unpack   loaded at 04B70000h - 04B9E000h
foo_unpack_lha   loaded at 04BC0000h - 04BE1000h
foo_utils loaded at 04C10000h - 04C49000h
foo_winamp_spam   loaded at 04C70000h - 04C8F000h
ctagent   loaded at 04EA0000h - 04EA6000h
CLBCATQ   loaded at 76FD0000h - 7704F000h
COMRes   loaded at 77050000h - 77115000h
SETUPAPI loaded at 77920000h - 77A13000h
appHelp   loaded at 77B40000h - 77B62000h
cscui loaded at 77A20000h - 77A74000h
CSCDLL   loaded at 76600000h - 7661D000h
USERENV   loaded at 769C0000h - 76A73000h
libpng13 loaded at 06950000h - 0696C000h
zlib1 loaded at 091A0000h - 091B2000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP   loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 04A6B80Ch, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D4882Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000163h)
Address: 04AA6320h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 04A7C790h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04AA5D44h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04504748h, location: "foo_run", loaded at 044E0000h - 0450B000h
Address: 04A93953h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A6C7B0h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A6D920h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D4B8BAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000000h)
Address: 04A6DCCDh, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A93C4Ah, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 0112E948h, location: "foo_dumb", loaded at 010E0000h - 0113F000h
Address: 04A6DF54h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D48B26h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 04A37220h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D488D1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D488DAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 04A93CA5h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A37398h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B4C0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D4FD29h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UserClientDllInitialize" (+000007F1h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 04A30000h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A9D8D8h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D4B473h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D5013Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateWindowExW" (+000001EEh)
Address: 77D50104h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateWindowExW" (+000001B4h)
Address: 77D4B3F9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 77D4B393h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 77D4B3A7h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77455CB0h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal389" (+0000A4CDh)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 7C910F46h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+000004B7h)
Address: 7C910D5Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+000002CDh)
Address: 7C910E91h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000402h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 04A7C85Ah, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A3188Fh, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 7C910833h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000025Fh)
Address: 04AB45D4h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A30100h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 7C910838h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000264h)
Address: 77D501F7h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateWindowExW" (+000002A7h)
Address: 04A7C771h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D4FF83h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateWindowExW" (+00000033h)
Address: 04A37095h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A43CD6h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A5F46Fh, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04AA62D0h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A92A41h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04AA5D60h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A9CD01h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04AB4398h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A5F61Fh, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A59935h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04AB3C0Ch, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A9EE5Ch, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A922F9h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A5A232h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A5A7F8h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A5A561h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A5BBA4h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D4B3B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 04A5BBBCh, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 7C9168AEh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+00000193h)
Address: 7A2ED654h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Address: 79E7A5E6h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "DllUnregisterServerInternal" (+00006DC6h)
Address: 79E7C7C3h, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "DllUnregisterServerInternal" (+00008FA3h)
Address: 04A924D0h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 79E9C35Eh, location: "mscorwks", loaded at 79E70000h - 7A3D1000h
Symbol: "LogHelp_LogAssert" (+000097DAh)
Address: 79062D98h, location: "mscorjit", loaded at 79060000h - 790B3000h
Address: 04A9C4E8h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 04A9C96Ch, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 77D533B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateIconIndirect" (+000006AEh)
Address: 00460020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C915041h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "bsearch" (+00000046h)
Address: 7C915233h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "bsearch" (+00000238h)
Address: 04A9C536h, location: "foo_ui_columns", loaded at 04A30000h - 04ACB000h
Address: 7C9155C9h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlHashUnicodeString" (+00000164h)
Address: 7C915152h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "bsearch" (+00000157h)
Address: 7C91554Ah, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlHashUnicodeString" (+000000E5h)
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Game Emu Player 1.3  (foo_gep)
ADX decoder 1.0  (foo_adpcm)
DTS decoder 0.1.7  (foo_input_dts)
Winamp API Emulator 0.90  (foo_winamp_spam)
Album List 3.2.0  (foo_albumlist)
OKI-ADPCM decoder 0.14  (foo_adpcm)
Playlist Manager 1.0  (foo_playlist_manager)
Albumlist autoupdate 0.1  (foo_albumlist_autoupdate)
On-Screen Display GDI+ 1.52  (foo_osd2)
LHA unpacker 1.0  (foo_unpack_lha)
Lunar 2 PCM decoder 0.5  (foo_lunar2)
Channel Mixer 0.9.3 preview  (foo_channel_mixer)
sidplay2 1.13  (foo_sid)
Audioscrobbler 2.1  (foo_audioscrobbler)
BRR decoder and converter 0.7  (foo_adpcm)
Send to Device 1.0.3 [Apr 27 2006 - 08:47:11]  (foo_sendtodevice)
Quick Search Toolbar 2.8g  (foo_uie_quicksearch)
WMA Decoder 1.1  (foo_input_std)
Freedb2 characters fixer (masstagger addon) 0.02  (foo_freedb2_fix)
Continuator 0.4.0  (foo_dsp_continuator)
ZIP/GZIP reader 1.0  (foo_unpack)
AC3 decoder 0.7  (foo_ac3)
Album Art Panel 0.2.5.1  (foo_uie_albumart)
GCN DSP decoder 1.2  (foo_adpcm)
DUMB module decoder 0.9.7.1  (foo_dumb)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Masstagger 1.6  (foo_masstag)
Live show tagger 0.6.1  (foo_tradersfriend)
Common services 0.1  (foo_common)
Shorten decoder 0.4.2a  (foo_input_shorten)
Audio CD Writer 2.0  (foo_burninate)
Default User Interface 0.9acc  (foo_ui_std)
Run services 0.3.2  (foo_run)
Track info panel 0.8  (foo_uie_trackinfo)
VLevel 20060324.0  (foo_dsp_vlevel)
Playlist tools 0.5.7  (foo_utils)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
ReplayGain Scanner 2.0.2  (foo_rgscan)
ABX Comparator 1.3.1  (foo_abx)
kode's ADPCM decoders 1.2  (foo_adpcm)
Standard DSP array 1.0  (foo_dsp_std)
Converter 1.0.1  (foo_converter)
Pause on Lock 0.4  (foo_lock)
MIDI synthesizer host 1.6  (foo_midi)
Menu Addons 0.2.1  (foo_menu_addons)
CD Audio Decoder 2.1.1  (foo_cdda)
Explorer Tree 1.04.6a  (foo_uie_explorer)
foo_explorer 1.31  (foo_explorer)
FooBar2000 Advanced Controls 0.5.9.0  (foo_AdvancedControls)
On-Screen Display 1.52  (foo_osd)
RAR reader 1.1  (foo_unpack)
Shell link resolver 1.1  (foo_lnk)
Playback statistics 1.0  (foo_playcount)
Playlist Tree Panel 2.0.7 [May  5 2006 - 13:10:05]  (foo_playlist_tree)
freedb Tagger 0.5.2a  (foo_freedb2)
Highly Experimental 2.0.5  (foo_psf)
Interplay ACM decoder 1.0  (foo_adpcm)
foo_managedWrapper 0.3  (foo_managedWrapper)
Pretty Popup 1.2.3  (foo_prettypop)
Music Browser 1.2.2c [Jul  6 2006 - 09:42:02]  (foo_browser)
FLAC Decoder 1.1.0  (foo_input_std)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Preview 1.2  (foo_preview)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Randomized playlist entry 1.2.3  (foo_random)
Special file info box v2.0.0  (foo_infobox2)
Database search 1.3.1 beta 11  (foo_dbsearch)
RAC decoder 1.0  (foo_adpcm)
Alarm 1.03  (foo_alarm)
foosic music database 1.0 beta 10  (foo_sic)
foobar2000 core v0.9.4.1  (Core)
XA ADPCM decoder 1.1  (foo_adpcm)
Highlight playing 0.1.0  (foo_highlightplaying)
Playlist Bind 3.1  (foo_playlist_bind)
Still waiting for an answer. Eagerly. This is one of the best components I've seen, and I still cnnot use it again until I'll be able to manually edit its settings, apparently.
:grunt:
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Changed [ code ] to [ codebox ].[/size]
foo_run 0.3.7
Reply #133
does anyone have a script to run the tag & rename "open in tag&rename" context menu item, or any equivalent to open up containing folder in tag & rename?
I think I fixed it  I have the program on my "D" drive but you'll figure that out.
"D:\Program\TagRename\TagRename.exe" "$substr(%_path%,0,$strrchr(%_path%,'\'))
foo_run 0.3.7
Reply #134
Thanks a lot for plugin! I use it for viewing nfo and open dir in total commander.
I wonder if its possible to make smth like 'Add directory to Nero' While browsing playlist you click on single track (or multiple tracks from different directories) then nero launches in data project mode and the whole directory (or directories) goes (go) to the project. Preferably to add directories to one and the only project session in nero. You return to foobar after adding directories, add other one and it goes to the current nero project. I hope my explanations are not very complicated
I guess the answer to my question is no. Maybe it is possible to burn data project with foo_run and nerocmd.exe but it will be without nero gui and possibility to edit current project :/
foo_run 0.3.7
Reply #135
situation: I have a mp3 and a mpg both named the same.
The mp3 in a music folder and the mpg in a Video folder within the music folder
i want to be able to use foo_run to launch the video. The problem is there are different file formats
request:
to be able to leave the filename ext off (not specify) - err its hard to explain something like this:
$replace(%path%,%filename_ext%,Video\%filename%.*)
foo_run 0.3.7
Reply #136
can some1 help me out, ive been trying to figure out how to open mplayer with a path which is inside a %video% tag
I've been using:
I:\Apps\MPlayer\mplayer.exe %video%
An exmaple %video% -  I:\season 6 preview.asf
I tried the above in "" it didnt work either. When i tried to do it in VLC it replaces the '\' with a ',' any ideas? its frustrating because the following work:
I:\Apps\MPlayer\mplayer.exe I:\season 6 preview.asf
edit: if i have a run service named VLC how can i add it too a button? i tried:
$button(700,0,0,0,0,0,images\arrow.png,images\arrow.png,"Run Service/VLC",) with no luck
^^ ok i figured the button out
foo_run 0.3.7
Reply #137
You tried:
"I:\Apps\MPlayer\mplayer.exe" "%video%"
Can you be more specific about how it didn't work; did mplayer run at all? Did it report what the file it tried to open was, and any reason for faliure?
foo_run 0.3.7
Reply #138
What's the code to go one level higher because I can get in the now playing folder but I need to go to a level higher.
For example
D:/Music/cd1 when I enter the %path% code I get into cd1 one (this is where the now playing song is located) but I need a code to go into music.
Is this possible?
Sorry for my bad english and thanks in advance
ok found that out
is it maybe possible to go to 2 paths like the album art window does?
If the program can't open the file in the first path that run goes to the second path...
Is this possible? and how do I do this??
foo_run 0.3.7
Reply #139
You tried:
well i got it to work using:
I:\Apps\MPlayer\mpui.exe "$replace(%video%,', ','\')"
although i still dont understand why the %video% tags "\" gets replaced with a ", "
Edit: How can i have one foo_run script to do 2 tasks ie Stop foobar and launch mPlayer:
E:\Apps\MPlayer\mpui.exe "$replace(%video%,', ','\')"
foobar2000.exe /command:"Stop"
^ this will obviously tell mplayer that the foobar2000.exe Stop is part of the file name, any ideas?
foo_run 0.3.7
Reply #140
you could use a batch file. (.bat file) should be quite simple, you can use notepad to write it. just imagine you would enter the command in DOS command line window. then point foo_run to the batch file.
the problem would be though, to get the %video% into the batch file, so mplayer knows which file to open... don't know how to do that
foo_run 0.3.7
Reply #143
If the batch file is for example "mplay.bat"
Use this command MPLAY "argument"
Then in the batch file refer to this as '%1'
e.g. echo %1
Batch File Article
Here's a batch file I created and use all the time, it passes a file to the batch to be uploaded to an ftp of my choice before copying the URL to my clipboard. It uses batch file arguments and I have successfully integrated it into foobar to allow one-key mp3 uploads. Putting this in the SendTo folder also makes uploading of any file painless.
foo_run 0.3.7
Reply #144
Is any way to send all playlist songs to Nero Burning Rom 7 ?
foo_run 0.3.7
Reply #145
2PonasX
Search for NeroCmd.exe on your computer. Open that in a Command Prompt window to see its options. The rest it's up to you
foo_run 0.3.7
Reply #146
e.g. echo %1
Batch File Article
Thanks a lot i managed to get it to work using this in a batch file:
@echo off
E:\Apps\MPlayer\mpui.exe -compact -autoquit %1
endlocal
exit
One question though, how can i have the cmd window close on executing mplayer?
At the moment i have the mplayer window open as well as a cmd window.
foo_run 0.3.7
Reply #147
I understood foo_run is used to execute an external program
but what application can be used thru foo_run ??
Anybody give me some examples usage ?
foo_run 0.3.7
Reply #148
adriannmak: foo_run can be used to run anything that can be run from a command line or the Start> Run prompt.
Example loading this forum:
http://forums.foobar2000.org/
Example loading your foosic stats:
http://www.foosic.org/query_user.php?user=YOURFOOSICNAME
Most of my usages for foo_run involve URLs, but you can also do things like pass currently playing song information to programs like album art downloaders:
Example using Cover Downloader:
"C:\Program Files\foobar2000\components\coverdownloader\albumart.exe" "%album artist%" "%album%" "$replace(%_path%,%_filename_ext%,)$if2(%cdid%,[%album artist% - ]%album%).jpg"
foo_run 0.3.7
Reply #149
This plugin doesn't work is no file is playing.
Is there any way to make it work?
