Topic: iPod manager (Read 2269076 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
[seemingly abandonware] iPod manager
Reply #750
Hi again everybody!
Well, I think this is more requests than questions, but, anyway, I just want to know if it is possible.
I'm trying to free mi ipod from any pc.  Actually, I have my music in a portable HD as a backup, and I have foobar in this HD.  I use to sync my ipod with this database.  But what I want is to be able to use my ipod as my main music database and have my HD just as a backup.  It is not problem at all in use Foobar2000 directly from my ipod, but there are two small things that I think are gonna make this more like my HD experience.
First:  There is no a way to retrieve back the artwork from the ipod to foobar.  I can't see any of mi artwork in foobar, so, I don't know if an album already has artwork or not without seeing directly in the ipod.  Actually, I see that floola can do that (that's the reason it is still in my ipod) So I wonder.... ¿Why foo_dop can't?  this wolud be a great feature.
The other one is the time that foobar takes to retrieve the ipod database.  I know this depends of the number of files you have, but I was thinking that it would be great that foo_dop give us the option to save a "pseudo-media library" (I mean, a playlist    ) that will load faster than the database, and I can recreate, or update any time I read the database from ipod.  Actually I do this by hand, but, well, I lose nothing asking for this
thanks for this wonderful plug in and regards!
Reply #751
musicmusic - great plugin, great updates  Thank You!
Here are couple of suggestions:
- Could the playlist created by "Load library" be sorted? Now it seems to be in dates order, that may be useful in some cases but I find myself always sorting it by general string so albums are grouped.
- I think there should be info about doing transcode from lossy source, perhaps it could be presented the same way as when gapless info cant be determined?
- As stated above by Adi Corrales finding missing covers isnt easy. Maybe give that information in similar way to new playcount plugin so it will be possible to use it in tagz for custom columns?
- I would really like to have an option to resize cover (instead of adding black bars) if the width to height ratio isnt huge. In most cases this is unnoticable on small iPod screen and would look better than bars.
And finally one thing that bothers me - I have a few movies send to ipod by itunes so they have names like EKKP.mp4 without any tags. When foo_dop will erase info about them from database and replace it with own data (ie filename)? It happened to me once and that was confusing  I tried "Refresh iPod library metadata" but the info its still on the iPod. Don't really want to experiment with rewrite database now
Reply #752
I was meaning to post that one myself one day, but you were faster...
I guess it's sorted by path and filename now, which thanks to the iPod's silly file storage scheme doesn't make much sense at all for everyday use...
NB: I'm playing files directly off my iPod at work, so sorting files by Album automatically is the first thing I do before putting together a playlist in Foobar2000...
np: 4'33"
Reply #753
What exactly are you trying to do? Anyway, there is a column in 'Browse iPod' that tells you if a track has artwork.
It builds a metadata cache which takes time the first time. It should be faster afterwards though. Which part of the process is slow?
1. It's currently unsorted: it is just the order they are in the iPod database. In general that is the order they were added to the iPod. I use this so I may add an option to control the sorting.
2. Well, the copy on the iPod isn't meant to be a backup, and it is basically using the settings you provide.
3. Without background loading of the iPod database it isn't exactly possible directly in the foobar2000 playlist.
4. Basically, it is slightly complicated. Some iPod models / artwork image formats request cropped images, but foo_dop doesn't provide those which can result in black bars. In other cases, foo_dop provides info on how much of the image is padded out but some issues there may have resulted in some small black bars. Which iPod model do you have?
5. Yes, that is what "Refresh iPod library metadata" will do. Add some metadata to the file and run 'ipod/update metadata...' in contextmenu instead (that does the same as the main menu command but limits it to the selected items)
Reply #754
Anyway, now that I know this info is in browser column there is no problem for me
Hmm I see, I have 3G Nano.
BTW - there is helpful tool from microsoft called contig. It allows defragmenting only certain files, for example .ithmb ones.
Reply #755
I cant find a volume normalization feature in foo_dop. Can it be added? TIA
Without it I frequently have to adjust the volume on my nano.
Reply #756
Strangely enough, on my iPod Classic tracks really seem to be in this order (in the iPodDB), but on a 3G Nano they are exactly in reversed order (in the iPodDB). Is there a reason why the files are written in a different way? Both iPods are managed by foo_dop 0.5.3.
Also, I have a bug to report, using 0.5.3 and an iPod Classic: I have two albums, with a different album artist but the same album title. In the "Cover Flow" and "Albums" views I see both albums separately in the list, but when I click on either one, all songs from both albums are listed under each one. In the "Artists" view they are properly separated. Do you maybe have an idea why this might be? Can this be corrected?
And one other thing, which might not even be a problem your plugin caused: I wanted to check out Floola for iPod management, and when I started it up, it complained that my iPod is not set up correctly (after using it managed by foo_dop for weeks), and if I want Floola to set it up for me. I did not allow this, of course, but my iPod's DB was reset nevertheless (now this is probably a Floola bug). Luckily, foo_dop managed to rewrite the DB, and all's well now. Do you have an idea why Floola, and sometimes iTunes complains about my iPod Classic not even being initialised for use?
And a third thing comes to my mind  Is there a way to detect if I want to send duplicates to my iPod? And to prevent it? (i.e. I have an album on my iPod, but I forget about it and send it again later. All tracks will then show up twice on the iPod  )
Nothing else for now!  Just to thank you for creating and maintaining foo_dop!
Life is Real...
(But not in audio :) )
Reply #757
Yeh, I have a Classic and that mainly wants cropped images, Nano 3G is probably the same. I will sort this one day..
I have the whole Sysinternals suite on my drive but I didn't notice that  Thanks.
If your files have Replaygain data that will be converted to SoundCheck data by foo_dop.
It doesn't do anything different on those models. Bear in mind files may be re-added during a sync (that puts them at the end) also if you send multiple files at once they will all be at the end but in an undefined order. Again, I guess it's complicated
I don't think this is my issue (but rather an issue with the iPod). If they are compilations setting them as so may help. Does the artist field vary between the tracks/albums? I have seen issues similar to this, I may check it out or alternatively you could try adding the same songs via iTunes. Also make sure you are using the latest Classic firmware.
iTunes shouldn't complain if you've just been using foo_dop. But other 3rd party apps may cause issues. The rewrite command just reads (parses) the database and writes it out again. So if that fixed it floola must have written a bad db (iTunes/iPod perform some additional security checks when reading the DB which foo_dop doesn't care about).
BTW: I have had the Classic do odd things. Basically after disconnecting it from the computer, I have had it reconnect once the "OK to disconnect" progress was completed and then disconnecting and repeating.. This also resulted in the iPod service giving a message along the lines of "Your iPod needs to be reformatted for use with Windows". That message can be ignored in this case, just disconnect it in the small "OK to disconnect" window.
Not really yet.. I'll make some changes there at some point though. Personally I just use sync.
Welcome
Reply #758
i have a request: it would be nice if it was possible to exclude certain filetypes. i have a lot of .dts files and everytime i sync my ipod i get a list of errormessages that these files can't be converted because they have more than two channels.
Reply #759
I usually just send the files to both iPods. And when sending multiple files they seem to end up in their original playlist order on the iPod Classic, and reversed on the 3G Nano. Not that this would matter much
I have the latest 1.0.3 firmware. Both albums are non-compilation albums, and each album has tracks only from one artist (which is different between the albums). I will check the same tracks sent from iTunes, though that would leave me without covers...
I think this is basically the same behaviour I'm getting. Maybe Floola is also checking some stuff for itself...
I've been using sync as well, but I lost the playlist I was syncing to. And I have 2 computers with no possibility to share mp3s between them, so I tend to just "send" tracks from either one.
Life is Real...
Reply #760
Firstly, thanks alot for this plugin... foobar is my music player/manager of choice and using it to sync my iPod is a natural choice. Keep up the good work!
However, I'm getting alot of "I/O Error" messages when trying to add gapless data for my tracks... some albums succeed, others fail. Albums that fail consistently fail, but if I fire up iTunes it adds gapless data for all those that foo_dop fails for. I know for a fact that these files have gapless tags in the id3 tags, as I just ripped them myself (LAME 3.97).
FYI, I am running Windows XP 64 with an iPod classic 160Gb.
Reply #761
Basically foo_dop is having trouble parsing the file, typically caused by some junk at the beginning of the file before the audio data, such as a second id3v2 tag or some other junk.
Are you using any other programs to tag/modify the files?
If you upload a sample file (e.g. yousendit.com) I can check what the problem is (PM me the link).
Reply #763
It has two id3v2 tags. One seems to have been added by LAME, and one by EAC. I think you've probably set both of them to tag the file.
You can remove the first tag by loading the file into foobar2000, from MP3 Tag Types in the context menu deselect id3v2. That should remove only the first tag.
Reply #764
Wow, that's odd... EAC is set to tag the files when I rip them, if I decide to change something after ripping (i.e. genre) then I use foobar to edit the tags. I've no idea why foobar is adding another ID3V2 tag instead of editing the existing one. If it does need to create a new one for padding purposes, why leave the old one?
One other question... how can one easily add album art to albums that don't already have album art? How about those for which I have replaced the art with a better or corrected picture?
Reply #765
No I think you've set Lame to add a tag, I think it has some options to specify artist etc. through command line. It seems EAC has added a tag instead of using the existing one. The contents of the tag makes that clear (one has a TSSE field specifying LAME 3.97 alpha, the other has a TENC field specifying EAC. So it seems clear they have each added a tag).
I think this has been covered in the posts above.
Reply #767
Thanks for your help so far MusicMusic, as ever I've a few more questions :
1. Is there a quick and easy way to add radio shows using foo_dop? I often download mp3s of talks, discussion shows etc and would like to add them to my iPod such that they appear in the "Radio" area, and not amongst the main artist section. If I use iTunes, it seems to routinely remove album art which is painful to fix.
2. Have you considered opening up the source to foo_dop? There is huge potential for this plugin and as popularity grows there will probably be more feature requests / bug reports than you can easily handle. Not to mention that the half-life of foobar plugin develpments in general seems to be terribly short and one ipod plugin has already died off (foo_pod). Collaborative efforts have a much greater chance of success. I'm a software engineer by trade and whilst I have never participated in an open-source project, this is the first one I have felt I would like to contribute to.
Reply #768
Sorry for the delay... actually I think that show the covers in an albumart panel would be could, but i can live without that jejeje...  I just like to see the cover of what I'm playing
Upsss!  Forget this....  It was mi Foobar instalation.  For some reason, it was deleting  ALL the playlist  when it closes, so I have to reload the iPod library every time I open it....  I reinstall foobar and now, it seems to keep the playlists the way I leave when it closes....  I guess that I just have to change the drive letter of my ipod to be sure the playlist is correct in every PC...
Reply #769
1. Do you mean podcasts? No there isn't really much support for those.
2. I am against it. Anyway, if foo_pod didn't die off there wouldn't be any foo_dop
Well the cache is independent of driver letters and keeping playlists open. It should take only several seconds or so (longer with like a more than a few thousand songs/videos) to do a load library if everything is cached.
Hello,
sorry for being so annoying, but do you mean to publish a new release (with the fixed album art function) still in 2007?
Best regards,
qwerty85
If you are browsing the forum not logged in could you log in please...
Reply #770
Put simply, I was wondering how easy it would be to trick the iPod into categorising an mp3 in the radio section of the music browser (which presumably refers to podcasts), akin to the "VARIOUS" flag and compilations. A bare minimum implementation which does the necessary to achieve that would be cool.
That is a great shame. If foo_pod hadn't died then we wouldn't need the retrograde step of a ground-up reimplementation.  I can only ask that if you ever abandon foo_dop or development tails off that you release the source in recognition of what inspired you to write it in the first place.
Reply #771
The only radio menu I am aware of refers to actual radio (via the radio remote).
A chunk of foo_pod was actually based upon some iPod database library with public source code. From my point of view I really don't think there was anything that I could have salvaged from foo_pod source, even if I had it. This stuff about foo_pod isn't actually that relevant, but anyway I don't plan to do any disappearing acts.
BTW: Anyone else with a 5G iPod and non-square artwork black bar problem?
Reply #772
foo_dop is working wonderfully on my iPod Classic. The only annoyance is that the harddrive spins up to load the cover-art every time I browse to a new iPod. I'd assume that this is an issue with the iPod itself, and not foo_dop (since storing all the art in RAM would leave no room for caching MP3s), however I can't be sure as I've never used this iPod with iTunes, except to update the firmware (1.0.3).
Hi again everybody!
........ But what I want is to be able to use my ipod as my main music database and have my HD just as a backup.  It is not problem at all in use Foobar2000 directly from my ipod, but there are two small things that I think are gonna make this more like my HD experience......
Don't. Your iPod will soon die. Ideally you should access the iPod harddrive as little as possible, ie. don't use a harddrive iPod as your USB drive. Of course, if you have a flash based iPod there's no problem, but I'd assume you have more than 16GB of music .
Reply #773
Errr, what exactly makes you think that a hard drive in an iPod is more crash-prone when used as a hard drive than flash RAM? That's the first time I heard of this...
Constant use hasn't killed any of the hard drives in my PC lately, so why should the one in my iPod be any different? Not to mention that by setting foobar's "cache files up to" option high enough should make it access the hard drive once per song, just like using the iPod as a mobile player does...
np: 4'33"
Reply #774
OK, I understand (the radio option disappeared when I updated the firmware)... so I think what I really want is some sort of podcast support.
I do have a further suggestion regarding my gapless problem... I am currently going through the painful process of fixing all my mp3s (roughly half of my 76Gb of MP3s are affected and foobar is little help in identifying them!).
It occured to me, why are you parsing the "accurate stream data" from the file yourself? Surely it would be much faster to use the cached data that foobar can provide. In order to add files to the iPod, they must be in a playlist which means foobar has already parsed them. That data is available via the TAGZ engine and presumably there are internal hooks in the API as well. Not only would it circumvent problems like mine, but it should also be much faster...?
ENC_DELAY    LAME proprietary MP3 enc_delay value (e.g. 576)
ENC_PADDING   LAME proprietary MP3 enc_padding value (e.g. 1536)
MP3_ACCURATE_LENGTH    mp3_accurate_length supported (LAME proprietary header)? (e.g. yes)
Also, according to this multiple id3 tags are to be expected.
