Topic: iPod manager (Read 2270969 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
[seemingly abandonware] iPod manager
Reply #2500
But the strange thing is that itunes' database doesn't need ~2min delay to sync successfully.
You might be right there and I have an idea of what's going wrong... but I need to check.
Please give 0.5.6.9 a try
And for ALBUMSORTORDER too, please  I prefer to use %date% to sort albums.
I don't really want to add it until I have some sanity checking on sort fields in place. I'll keep it in mind though.
Are you averse to setting the MEDIA KIND field though?
What exactly does the MEDIA KIND field do?
Set it to Audiobook and it does roughly what you want.
Reply #2501
I was waiting for this fix. Yes, it works correctly now! Thanks a lot !!!
Iphone 3G FW 3.1.2
Reply #2502
I try 0.5.6.9, sortorder field not supported?
I set TITLESORTORDER, and send to iPod 5G.
But, not reflect iPod databases
Reply #2503
First things first:
Thank you very much for this superb component, musicmusic!
This is so much better than this crap Apple calls iTunes.
Now, I've got a (hopefully) small feature request:
Could you please make mapping to the %comment% field possible?
Background is as follows:
I've tagged my mp3s quite extensively. I have fields like %singer%, %live%, %source%, %language%, etc. What I would like to do is to fill the %comment% field with these fields when transferring to my iPod, so I can have quite a "super tag" containing all the different information. I need this "super tag" because neither iTunes nor foo_dop can use my custom fields for autoplaylists...
btw, I'm running iPhoneOS 3.1.2 on my iPod touch 3G 32GiB without any problems whatsoever.
NinjaN
IDE? This is S-ATA!
Reply #2504
I recently started converting the music I sent to my iPod, to aac. Now, won't show up because they're, I'm assuming, still in the %unsynced lyrics% field. What can I do to change this? I tried changing my parameters to
-q 0.30 -lc -ignorelength -if - -of %d && "D:\Users\Rikard\foobar2000\aac\win32\Neroaactag.exe" %d -meta:lyrics="%unsynced lyrics%"
, which didn't help.
Reply #2505
NinjaN
Do you need the %comment% tag clean when the files are in the media library? If not, you can run a script with the masstagger to copy all the tags you want to the comment. I did that with one of my tags. If it works with one tag I think it will work with more.
Reply #2506
@eradumvelhinho:
I know of the possibility using Masstager with custom scripts. I'd like to have an automatic mapping so I don't have to do this myself...
IDE? This is S-ATA!
Reply #2507
Sorry, I've fixed it for the next build. But I don't believe the 5G has proper support for sort fields, unless it was fixed by one of the last firmware upgrades. (The 'big letter scroll' thing wouldn't function correctly on anything other than the artist list.)
OK.
fb2k maps the lyrics field to "LYRICS" for mp4 but "UNSYNCED LYRICS" for MP3 (ID3v2), so it doesn't end up in the right place in the file after that conversion. You won't be able to work around it like that because the component tags the file after executing the CLI command (so what you did would be lost).
I can probably write a workaround for when you are doing that conversion, since if the mapping changes I will need to make changes on my side anyway. Could you confirm your source file format though (MP3?)
Reply #2508
That would be great! Yeah, converting from MP3 to AAC/MP4
Reply #2510
Pls help me i heard of this player and its really good to play music from ur ipod i downloaded 'it' and 'foo_dop-0.6.5.9.7z' moved the dll file into 'C:\Program Files\foobar2000\components' but now how am i ment to finish it off i cant get the music from my ipod WHAT AM I MENT TO DO PLS HELP ME!!
Reply #2511
Anyone using an Intel P55 chipset with an iPhone or iPod touch, please ensure you are using the latest BIOS version/look out for upcoming BIOS updates to avoid USB communication problems with the device (documented on the FAQ page for this component).
ASUS have released a updates for their boards, on their FTP site (it's not on their download page yet). I verified that the problem is gone for me.
I DON'T KNOW WHAT DID YOU TRY.
Start reading here.
Reply #2512
i'd like to amplify my files with the "soundcheck adjustment" feature. my car hifi system is a bit weak so i have to set the volume to max most of the time. how do i find out which adjustment value is safe to use? (i don't want to introduce additional clipping of course)
Reply #2513
It simply depends on the ReplayGain value of the tracks. You can safely boost the SoundCheck volume up to the amount ReplayGain previously decreased it... any more is likely to cause clipping. For most modern pop/rock music you could probably set it to +8db, but include a properly mastered classical record and you'll get clipping for sure. I've set mine to +2db and very, very rarely get any audible clipping. But if I'd listened to classic mostly I woudn't adjust it at all (some rare classical records even clip at the default 89db ReplayGain value)
Btw, musicmusic, does foo_dop fall back to track gain if album gain is chosen and there's only track gain, like Foobar does?
Reply #2514
the website isn't available right now, could you please upload the file again?
and does this plugin support the 3.1.2 version iphone 3gs?
Reply #2515
Yes, always did.
It's fine now but it might depend on your DNS server updating.
Yes
Reply #2516
Hello! I have the problem.
When i make file  - Ipod- Synchronise - i have this:
http://img690.imageshack.us/img690/593/clipboard01lb.jpg
I have MobileDeviceSign.dll in folder components....
I have Ipod Nano 5°gen.  8GB
Help me!!
Excuse me for my bad english
Reply #2517
Then you didn't install it correctly  Check the download page again.
Reply #2518
Just installed foo_dop with zlib and mobiledevicesign.
My iPod Touch 2G 3.1 is properly recognized, the following appears in the console :
iPod manager: Apple Mobile Device: New device detected.
iPod manager: Connected to Apple Mobile Device (PID: 1293, UID: b1e0314f065644424805167502075cc9f6163b82)
iPod manager: USB AMD enumerator: Found USB\VID_05AC&PID_1293\B1E0314F065644424805167502075CC9F6163B82
iPod manager: Apple Mobile Device: detected DBVersion: 4
iPod manager: Apple Mobile Device: detected SQLiteDB: true
iPod manager: 240 post process SQL commands, version 8
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1293\B1E0314F065644424805167502075CC9F6163B82
However, whatever action I try, I have the following error :
Error reading iTunesDB : Invalid format; expected header marker "dshm" got "ÝìÚx"
The iPod works well with other software...
What am I missing ?
Reply #2519
Does iTunes recognise it OK?
Reply #2522
Download again?  It does not work....problem not resolved...
Well no, doing the same thing again won't help  It says "Extract to your main foobar2000 application folder" - that's not the components folder, but the folder one level above.
Reply #2523
Excuse me, I do not speak English...
Ok! Resolved!! Thanks!
